Question about Troy Garden
I have a troy bilt horse xp. Won't go in gear at all. Have checked everything. All belts, brakes and everything looks great. Still won't go in gear. Starts and runs fine blades engage fine .
SOURCE: belts slippin on troy bilt horse
Have you adjusted the locking cam for forward. This cam is held in place with one bolt. The further you move it down the tighter it will make the belt
Posted on May 05, 2009
  • 3074 Answers
SOURCE: 5.5HP Briggs and Stratton engine
spark plug or the coil/magneto
Posted on May 07, 2011
SOURCE: Troy-Bilt Colt XP zero turn
my blades wont come on, what do you thing the problem is.
Posted on Jul 18, 2011
waynepwelker
  • 25 Answers
SOURCE: I have a troy bilt riding mower blades will not engage in the 1 or 2 deck setting
There is a spring attached to a tensioner that probably came unhooked while changing the belt. Higher deck settings push the deck backwards enough to spin the blades, the lower setting need the spring tensioner to take up the slack in the belt.
Posted on Jun 27, 2012
  • 6468 Answers
SOURCE: I HAVE A 2010 TROY BILT LAWN TRACTOR. WE HAVE TO CHANGE THE BLADE AND TRANS BELT. ONCE WE CHANGED IT, WE PUT IT IN GEAR AND GO ABOUT 10 FT. THEN IT STOPS AND WON'T MOVE. IT IS A 17.5, 42 IN. CUT,
sounds like you missed a pulley or belt guide and the belt fell off
Posted on Jul 13, 2012
Troy-Bilt Horse XP, Model 13bx79kt011 - Won't Move
You need to check the belt to the hydro units is connected properly and is tentioned and not slipping in the pilleys
May 31, 2013 | Garden
Brand new Troy-Bilt XP Horse, model 13bx79kt011 - Won't Move
Confirm the park brake is off. If a hydro-static drive tractor starts but engagement of the operator controls for the transmission drive results in neither a forward or reverse drive of the mower itself, the operator should check that the manual bypass controls have not been left in the activated (bypass) position.
Look in to where the lever connects and confirm the movement. You should be able to hear the hydraulic oil with a slight whine as you activate the drive forward pedal!
See page 18 for bypass setting?
Cut and paste link
http://www.troybilt.com/wcsstore/TroyBiltUS-CAS/Attachment/ownersManuals/riders/HorseXP_2012_769-07569[1].pdf
Jun 27, 2017 | Garden
Troy bilt xp self propelled not switching gears
Check transmission fluid. Ensure belt is good or replace. Check belt tensioner if installed.
Apr 21, 2013 | Troy Bilt 5.5hp Self Propelled Mower
Adjustment for belt for 8 horse power horse. Really need to find a manual. Where can I locate one?
http://www.hammerwall.com/Manuals/Troy-Bilt/Description/21A682J766/Troy-Bilt%208%20HP%20Rear%20Tine%20Tiller%208%20HP%20680%20Series%20Briggs%20and%20Stratton%20Engine%20Manual/275092/
May 29, 2011 | Troy Bilt 21A682J766 Horse 8 HP Rear Tine...
My troy-bilt 8.5 horse 26 inch wide snowblower wont move anymore.
Take the belt cover off that covers the drive pulley on the engine. You should only have to loosen two bolts. Inspect the belt to see what it looks like. I am not sure if it drives a gear box or if it turns a friction wheel that drives the wheels. If the belt looks good check for shear bolts that might have sheared off and replace them.
Dec 19, 2009 | Garden
Can i see the models from 1983 to 1985,i need a belt so i can use reverse again but i dont now my model or size. my husband died 3 years ago. if i could see some pictures from the 1980's mine has a potatoe...
Your question doesn't give enough detail to properly answer. Do you know if the tiller is a Horse model or a Pony model? Troy Bilt made both models back in the timeframe you noted. The Horse model had tires that required air to inflate. The Pony model likely had hard rubber tires in that era. The Horse models had a reverse disc, no belt. The Pony had a belt.
Once you know which model you have - look for your closest Troy Bilt dealer and see if they can track down the part for you. They might appreciate it if you could provide the serial number - which is located on the pipe connecting the tiller transmission front half to the back half, where the tines are located. It's stamped right into the metal tube on both models.
Jul 17, 2009 | Troy-Bilt Garden
I have a Troy-bilt tiller horse with no serial #.
Bring the old belt to the parts store and they will be able to measure it and get you the belt by size.
Apr 19, 2009 | Garden
Belts slippin on troy bilt horse
Apr 02, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Garden Logo
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
