Question about Nikon Cameras
My Nikon L110 will save videos but not pictures. I've formatted the card and checked it on my computer. It's a new card also. I've tried changing the card but still the same issue. Please help!!
  • Nikon Master
  • 10,291 Answers
Did you format the SD card on the computer? If you did....format the card in the camera and make sure the lock on the SD card is off.
Posted on May 04, 2017
Testimonial: "I've done that. It recognizes the card but still won't save pictures."
  • Lawrence Oravetz May 10, 2017
    Make sure your save settings in the camera are set to SD card only. Otherwise, pictures will save to the camera memory until it's full then it will save to the SD card
If my Nikon Coolpix L110 does not accept the memory card, whilst the card works in the computer, what is the problem with the camera, and how do I fix it?
Your camera is SDHC compliant, so the card should work in your camera. There are two things you must do. Check if the Lock "switch" is NOT in the lock position and second before using the card in your camera, you should format it in the camera. Although FAT32 is supposed FAT32 for every device, camera's can be very "picky" when it comes to formatting and saving pictures. Even when a card is formatted in a Coolpix L110 from someone els, it could be your camera can't work with it.
I hope al the contacts in the camera are still clean and shining and not one os bent or has (even the smallest) dent. Check this with a stri=ong light and eventually with a magnifying glass.
Jan 30, 2015 | Nikon Coolpix L110 Digital Camera
Picture format
Yes go in your menu and select jepeg not raw go to your computer and download Picasa for free plug your camera to the computer and picasa will see them and put them in a folder for you.
Feb 23, 2014 | Nikon Coolpix L110 Digital Camera
LOST CD FOR L110 TO DOWN LOAD TO COMPUTER
You may download the current versions of all (free) Nikon software from here.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Nikon Transfer or Picasa.
Oct 02, 2012 | Nikon Coolpix L110 12.1 Megapixel, 15x...
PC cannot recognise usb for nikon l110
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa or Nikon Transfer.
May 07, 2012 | Nikon Coolpix L110 Digital Camera
I cant see good enough to read my manual, and my camera keeps saving my pictures to my camera memory instead of to my memory card. i want to know how to change this. also i only have like 10 pictures on...
To get your card to work, you must get rid of the pictures in the internal memory. Here's how: with no card in the camera, go into the menu and find "format" and follow the on-screen instructions to erase the internal memory. Then, insert your card and it should work properly.
Sep 05, 2011 | Nikon Coolpix L110 Digital Camera
I HAVE A COOLPIX L110 AND I WANT TO DELETE ALL MY PHOTOS AT ONCE , HOW DO YOU DO THAT?
If the photos are on a memory card, format it. Memory cards should be formatted each time you finish downloading your pictures. FixYa is full of people asking how to salvage photos from cards that hadn't been formatted recently.
If the photos are in the camera's internal memory, format it.
The format command is setup menu. Press the MENU button, select the wrench icon, then select the camera-slash-card symbol. Full instructions are in the "Format Memory/Format Card" section of the manual (page 109 in my copy). If you need a manual, you can download one at
http://support.nikontech.com/app/answers/detail/a_id/13948
Jul 13, 2011 | Nikon Coolpix L110 Digital Camera
Loss of picture and video file while transferring to a computer... how to recover data?
I have had success with this article...
Digital camera recovery
You have to use a usb card reader either on your computer or an external USB card reader. Put the camera memory card in the card reader, open the recovery program, then select the drive where files are deleted, then press "Start" and wait for it to do it's magic.
Jun 18, 2011 | Nikon Coolpix S4000 Digital Camera
When I use my camera it just says "memory card full" even though I deleted all the pictures/video on the card. I did research and found I should reformat my memory card but when I try to use my...
Use the memory card on your PC card reader and check the properties, if the card can be formatted then do so after removing all the files/pictures.
Now try this on the camera, if another card works well with the camera the card is faulty , if not there are issues with the interface within the camera and must be probed .
Jun 15, 2011 | Nikon Coolpix L110 Digital Camera
How to get nikon coolpix L110 driver for win7?
You don't need a driver.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery, Picasa, or Nikon Transfer.
Nov 27, 2010 | Nikon Coolpix L110 Digital Camera
Cameras Logo
59 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
