Hello I go through all the stages on the Avanquest VHS to DVD process on my laptop- get to stage where I have the video preview playing but when I press the record button it stops. .Thanks
  • 1003 Answers
SOURCE: INSIGNIA DVD Recorder/VHS Recorder NS-1DRVCR
yes it has to be finilized use very compatable media by memorex DVD-R this wil solve everyones problems
Posted on Feb 02, 2008
josephjoin
  • 4 Answers
SOURCE: DVD locked in and door is not opened
might have stuck inside...u got to open up the system onlly
Posted on Apr 01, 2008
  • 9 Answers
SOURCE: How to record a VHS tape to a DVD disc
Read your manual first to make sure the unit will do this.If it does chances are it won't record unless it has a decoder built in.Most VHS tapes have macrovision protection that prevents you from copying them.It will however,record homemade VHS tapes.There are decoders out there you can buy to enable you to copy VHS tapes.
Posted on Jan 03, 2009
SOURCE: dubbing VHS to DVD
You have to go into the Home menu and select setup. At the bottom left there should be an icon that looks like a dvd disc. Select that and then go to finalize and select that to finalize the disc. After that is complete it should play on any dvd player. I had this problem and I got through to LG's customer service line and had them talk me through it. After I finalized the disc, it worked.
Posted on Feb 05, 2009
atang1
  • 734 Answers
SOURCE: Magnavox ZV427MG9 DVD Recorder VCR Combo plays vcr for about 5 second then stops and shut off, when turned back on it ejects the tape.
This combo has a problem with the vcr unit which take up wheel will stop working and spill the tape. the unit will stop and eject the tape. You have to replace the whole vcr assembly.
Posted on Feb 21, 2012
Avanquest VHS 2 DVD Converter: Process hangs at downloading Mpeg codec
It sounds like you are missing some codecs. Try installing them first. Then restart pc, and try record again.
There are several MPEG codec packs out there. This one is free:
Media Player Codec Pack
Feb 16, 2016 | Televison & Video
Roxio vhs to dvd not receiving video signal
this is because some VHS players have copy protection. for example some VHS manufactured by disney has copyright protection and is imposible to be compied to a DVD format.
Feb 06, 2012 | Roxio Easy VHS to DVD for PC
Last week I purchased Roxio's Easy VHS to DVD for Mac. It worked well with my MacBook Pro for some days, but since that time the recording process always freezes in the final stage when the display shows...
Hi.
This is a known issue with this product and Roxio has not officially released a solution for this. A temporary solution is to wait a couple of minutes and disconnect the USB connection.
Hope this helps.
Thank you for using Fixya!
Jan 12, 2011 | Roxio Easy VHS to DVD for PC
I dont have picture for recording
Welcome to Fixyah,
If yo can't see any picture please check your video cable connection.
>checked if the video cable is properly connected from dazzle to your camcorder.
>if you connect you camcorder,vhs,VCR using S-video then go ahead and click on option on step number 1 click on video input and then click on S-Video click also VHS input and then click okay.
>If RCA the same thing click on option then video input and then select Composite.
>Turn your camcorder,VHS,VCR on and then hit played button.
>checked your preview screen if the video image is now showing, If showing then start recording.
Regards.
Mar 11, 2010 | Pinnacle Dazzle DVD Recorder
I am running on a Dell XPS and my dazzle dvd recorder wont work.
Hi and Welcome to fixya!
I suggest to you to double click on Instant DVD Recorder Icon and choose go directly to Advance mode. Click next. On step number 1 click the pull down arrow and choose dazzle DVC 100. Click on options and choose video input. If your cable connection is the yellow red and white cable then choose Video composite, If S-video cable then choose Video S-video. If you have a VHS player click VHS input and click okay.
Next when everything is done turn your camcorder,vhs,vcr and then hit the play button.
That is the time that the video image is showing to the preview screen of the computer. Still not showing disconnect the dazzle device and place to another usb port.
If your dazzle device is not showing under step number one, you need to download and install the driver to Pinnacle Website.
Dec 31, 2009 | Pinnacle Dazzle DVD Recorder
Copy from vhs to dvd- want to speed process ???
I'm afraid, VHS tape have to be playback on standard speed for good picture and sound and dvd would also burn accordingly.
Noo way for fast dubbing because VHS tape video is analog signal that changed into digital signal in circuits to write on dvd disc.
I hope you understand how this dubbing works.
Nov 08, 2009 | Emerson EWR20V4 DVD Recorder/VCR
When using the Dazzle DVD recorder I am not getting a picture in the preview window. How do I capture the video from a VHS to the computer?
Disconnect your dazzle then connect at the back of your computer. Click on Start>Control panel>system>hardware>device manager>sound and video games controller> right click on video capture device and uninstall it. Restart your computer. Open your IDVDR then choose the advance mode, on step number 1 click the pull down arrow and then choose your dazzle device thing. Turn on the power of your VHS and then hit the play button check if the image transfer to the preview screen of your computer.
Oct 10, 2009 | Pinnacle Dazzle DVD Recorder
Problems with previewing/capture with ADS DVD Xpress DX2
I'd suggest removing all your other USB devices. I had heard that a Netgear wireless internet transmitter in another USB port could interfere with the ADS recognizing the signals from the video player or camcorder.
I had no picture preview at first. Then I tried unplugging my internet transmitter from the other USB device on my computer. It worked like a charm and started previewing right away.
I also found I had better luck with the old-fashioned composite video cable versus the S-video cable. Picture still looks great though after transfer, so sometimes old fashioned still does the job.
Good luck.
Jan 02, 2009 | A D S DVD Xpress DX2
Burn dvd from vhs
i'm assuming you have a vcr to play your vhs tapes, just plug your audio/video cord from your vcr(out), plug into the audio/video vc10(in), start playing vcr and press rec botton whenever you want to start to record. make sure you can only use dvd+r. choose the quality for the length of time, at the end press 'function' to finalize the disc, then you are done.
Sep 06, 2008 | Sony VRD-VC10 DVD±RW Dual Layer...
Downloading music tracks to a blank CD using Sony Sonic Stage software
go into the settings for sonicstage and select your dvd drive. that should be it. but you may have to do other things(i have a sony player too, but i have found sonicstage to be a waste of space and time. it is rather a pain. try looking through the manual and seeing if you have any options for the location of the cs drive. if not, then get a usb cd burner and connect it to the laptop. that should work properly.
Aug 29, 2008 | Acer Aspire 3610 Notebook
Televison & Video Logo
Top Televison & Video Experts
