Code error 66 yale electric - Office Equipment & Supplies
Error code 66
conflicting info
http://www.obd-codes.com/trouble_codes/gm/gm-2-digit-codes.php
66- pressure sensor or circuit air conditioning
http://www.cadillacfaq.com/faq/answers/dtccode.html
DTC 66 - Driver Air Bag Deployment Commanded
Apr 09, 2016 | Cars & Trucks
What does fault 108-1 mean on a Yale forklift
Troubleshooting Yale - Forkliftaction.com
www.forkliftaction.com/forum/threadbybrand.asp?brid=97
No Trans Braking Error code 524264-14. Discussion started: 5 .... Error code 108-1displayed. Discussion ... Yale forklift has perkins 4203.2 engine oil capacity?
Oct 23, 2015 | Cars & Trucks
How to install blade?
I found this doing a search:
If you have any questions about this Martin Yale 1648 Automatic Letter Opener or any of the other binding machines , binding supplies , binding covers or laminating supplies that we carry please call us toll free at 1-800-944-4573 or email us at sales@mybinding.com
Jun 19, 2014 | Martin Yale 1648 Automatic Electric Letter...
Eror code 66 how to fix it
you might want to unplug the set and plug it back, my list does not show a code or error code 66 for this set. Power it up and let it fail and check for the error, if the wrong model was posted here that may be the reason.
Dec 23, 2012 | Mitsubishi WD60735
Mitsubishi wd60735 error code 66
No such error code that I can find, try to unplug and let it fail again, then do the check again.
Dec 23, 2012 | Mitsubishi WD-60735 Projection Television
Machine says "I need service"
66. (01000001) Pressure Transducer Error [Ptx Frequency > 90 kHz]
Note: this supersedes Fault code 65 from V41 Motor controller code onwards.
The Motor Control module has received signals from the water level sensor (Ptx)
above normal frequency values.
Primary Source: Motor Control module
Action: Replace Motor Control module
I took this from the service repair manual. Hope it helps.
HI error code 66 means you have a pressure transducer out of range error.This means that the control module is faulty and needs replacing.please confirm that the error code is numbered 66. On some machines the pressure switch is seperated and sometimes the plastic tub for the switch gets clogged up and blowing through it will sometims clear this fault. Not sure about this particular machine, but you can try adjusting water level to see if it will work at a different level of water.
Mar 24, 2011 | Fisher and Paykel (IWL12)
Hello -Just looking for help on fixing a service code 66 which comes up when you turn the power on. Unknown age on machine. Fisher and paykel intuitive eco model IW811
HI error code 66 means you have a pressure transducer out of range error.This means that the control module is faulty and needs replacing.please confirm that the error code is numbered 66.Please reply for further help and clarification of this fault code.Hope this helps.
Jun 02, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
k24674
