Question about DISH Network Televison & Video
Dish network remote codes for admiral tv using the 52.0 device
  • 298 Answers
SOURCE: remote control code
Dish Netork does not have the code for Olevia
but you can scan for the code using the infformation
here
Remote Code Power Scan
If your brand is not listed, use the following procedure to scan through all codes.
If you start the and do not press a button within 20 seconds, the remote will end the scan automatically.
1. Turn ON the unit you want to program the remote to control.
2. Press the Mode button on the remote until the appropriate mode light is flashes
3. Press the Address button. The mode light will start flashing slowly.
4. Press the Power button. The mode light will stop flashing and stay lit.
5. Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
6. When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
7. Press the Address button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
8. Turn the device back ON by pressing the Power button.
9. Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
10. If the other buttons work, follow the current settings procedure below to determine the current remote settings.
11. If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
12. The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Posted on Nov 23, 2007
ward_knutson
  • 64 Answers
SOURCE: dish network remote with a element tv
Since you dont have a popular brand set you should try using the scan method. Here is a link with a video to help program your dishnetwork remote to work with your set. http://www.disheez.com/videos/dish-network-video/programming-dish-network-remote/
Posted on Nov 25, 2008
  • 362 Answers
SOURCE: remote code for dish network remote to control olevia tvs
Please follow the steps below to program your remote control to equipment other then your DISH receiver:
Note: If you start this procedure and at any time and do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over again. Use the TV button for your TV, the VCR button for your VCR or DVD player. These Mode buttons are located at the top of your remote control.
1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release.
2. Press the numbers 5-0-0 on the remote control.
3. Press the Pound (#) button on the remote.
4. Press and hold the correct Mode button until all mode button backlights illuminate, then release.
5. Press and release the Power button on the remote control.
6. Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
7. Press the Pound (#) button. If the code entered is valid for the remote, the mode light flashes three times.
8. To verify the code works try several different functions for that equipment.
We cannot guarantee our remotes will work all other devices. If this does not correct the issue, unfortunately our remote will not work for that device. We apologize for any inconvenience this may cause.
Lone99star. Please rate this solution.
Posted on Feb 14, 2009
SOURCE: dish network remote code for Disney 13" TV
On your dish remote, press and hold the tv button until all 4 buttons light up, then release. push either of the power buttons once. Now start pushing the down channel button, It's the one right below select, continue pushing it until tv turns off. When tv goes off push down button one more time then push up button, when tv turns back on stop and press # key, tv light will flash 3 times and should be set. Note....if u press down button and tv does not turn off after going through all codes( tv light will start flashing) press cancel and try again only channel up this time. hope this helps.
Posted on Mar 09, 2009
SOURCE: whad code do i hse to control my sanyo dp19649 tv
Hi! I will be more than glad to assist you in this concern. this are the tv codes for sanyo. 542, 589, 590, 591, 592,
609. this is how to reprogram you remote to the sanyo tv. you need to press and hold the tv button that is on the upper portion of the remote, on the right side of the sat button. wait until all mode lights lit up, once all lights lit up, release it and then press number ex.. 542 then followed by the pound button, then you will see that the pound button will flash 3 times, it means that the code is program to the remote. note: while your doing the reprogramming of the remote you need to be in front of the tv about 2 to 3 feet away and the tv should be on.. granting u try all the code and none of them works.. try to scan the code of the tv by pressing and hold the tv button wait until all mode light lit up, then press 500 then pound, tv button will flash 3 times, lets say the last code is 500 and it did not work, press again the tv button and wait until all mode lights up, press on the re tv button if you have, but just incase u have only 1 red button for the power, press it once, then press the up button every 1 sec for 5mins. once the tv turn off then press the pound button and the tv button will flash 3 times, it means that you got the code for the sanyo tv, to check the code: Press the POUND (#) button twice. The mode button
flashes the number for each digit of the device code, with a pause between the groups of flashes. A quick flash is for zero. For example, if the code is 570, the mode button flashes five times, pauses, flashes seven times, pauses, and flashes once quickly... lets say that this remote works before with the sanyo and suddenly it quit working , pls call 1-800-333-3474 and ask for the replacement for the dishnetwork remote, remote is bad. please feel free to get in touch if you have any query..
Posted on Sep 08, 2009
I need a dish network code for a 52" Sharp Aquos.
Hi deidrapleasmy name is Mike Houston of DISH Network and I was going over your post and thecodes for your 52" Sharp Aquos are 628, 739, 521, 629, 741, 679, 112, 605, 625,111, 608, 740, 526, 585, 607, 652, 654, 655, 658, 669, 670 and 674. I will sendthe link to help with the setup for the remote to TV. http://www.dishnetwork.com/SupportSection/remote-control
Feb 14, 2011 | DISH Network IR Remote Control
Tip
DISH VIP612 Program AUX Remote Code
DISH Solo DVR VIP612 Program AUX Remote Code
Would you like to program the Universal Remote that came with your Dish Solo DVR VIP 612 to control your receiver, tuner, stereo, second TV or second VCR using your remote's AUX mode? (Instructions to setup a primary TV or a VCR are a little different, but can be found here.)
To setup your Dish Solo DVR VIP 612 Universal Remote, follow these steps to enter the remote control codes to control a device with the AUX mode:
  1. Turn the device you would like to control on.
  2. Find the brand name of the device you would like to control in the control code tables on page 112 of the Dish Solo DVR VIP 612 User Manual.
  3. Press and hold the AUX mode button until all the other buttons light up, and then let go. The AUX mode button will flash.
  4. Press 0 for a TV, 1 for a VCR, or 2 for a receiver, amplifier or tuner.
  5. Enter one of the three-digit codes from the tables in the manual.
  6. Press POUND (#). The mode button will flash three times.
  7. Press POWER to turn off the device. If the device does not turn off, skip to step 9.
  8. Turn the device back on and try some of the other buttons to make sure they work. If the code works, stop here.
  9. If the code didn't work, repeat steps 3 through 7 with the next device code from the tables in the manual.
Your device control codes for your amplifier or other AUX device are now programmed into your DISH Solo DVR ViP 612.
Now you probably want to set your Dish Solo DVR VIP 612 Universal Remote up so that it always controls the volume of your stereo, rather than of your TV, regardless of whether it is in SAT, TV, VCR or AUX mode. Help for this remote control programming can be found here.
(Help for programming a TV or VCR using the TV or VCR mode buttons can be found here.)
I hope that helps.
________________________________________________________________
DISH Solo DVR VIP612 Manual Download
DISH Solo DVR VIP612 Quick Reference Download
DISH Solo DVR VIP612 Remote Code Scan
DISH Solo DVR VIP612 Program TV VCR Remote Codes
DISH Solo DVR VIP612 Program AUX (Stereo/Receiver) Remote Codes
DISH Solo DVR VIP612 Amplifier Control
DISH Solo DVR VIP612 What Is Limited Mode
DISH Solo DVR VIP612 Change Limited Mode
on Jul 05, 2010 | DISH Network ViP 612
I have dish network. my remote to the tv is missing, so i bought the gamechanger remote thinking it would solve the problem. i need to be able to turn on the tv with the game changer remote so then i can...
I would be happy to help get your DISH Network remoteworking with your TV. This will allow you to have a one remote solution.
To address other equipment using a DISH Network remote:
  1. Press and hold the desired Mode button until all mode button backlights come on, then release.
  2. Use the number buttons to enter the device code corresponding to the equipment.
AUX Mode: Before entering the device code:
    • Press 0 for a TV
    • Press 1 for a VCR/DVD
    • Press 2 for any other device.
  1. Press the pound (#) button
Note: The light will blink off after each digitis entered and then return to a steady light.
  1. Press the POUND (#) button.
If the code entered is valid for the remote, the mode lightflashes three times.
For a listing of all the codes we have for TV's, please visit:
http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/Remote_Codes_Web_Page.pdf
Feb 06, 2011 | Universal Remote Control GAMER Remote...
Need code to operate TCL tv with Dish remote
I have the 32" TCL and the 645 code also worked with the 722 dish network dvr remote (remote 20.0 IR). For that remote, press and hold tv button until all device buttons light up, enter 645 and press # key.
Jan 15, 2011 | DISH Network IR Remote Control
I need the programming codes for a Magnovox DVD player. I have a dish network remote. I've searched dozens of sites with no results. =(
jlhakes2,
I saw your post. Are you still having problems programming your DISH remote to the Magnavox DVD player? Some of the codes are different for the different remote models. I have supply some codes for you. The codes are 829, 685, 533, 554, or 556. The instructions are also included below. I hope this helps.
Address To Other Equipment Using Code
  • Remotes: Multiple Mode Buttons (TV,VCR, AUX)
    2. Use the number buttons to enter the device code corresponding to the equipment. AUX Mode: Before entering the device code:
      • Press 0 for a TV
    3. Press the pound (#) button Note: The light will blink off after each digit is entered and then return to a steady light.
    4. Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
Ray Calo
DISH Network - Executive Offices
Sep 27, 2010 | DISH Network EZ Remote Remote Control
Remote codes to use dish network remote with emerson tv model lc320emxf
We would be happy to help you with getting your DISH Networkremote to control your TV. Pressand hold the TV button located on the top of your remote until all mode buttons at the top of the remote light up, then release. Use the number buttons to enter thecodes for your Emerson TV; here some of the codes we currently have: 764, 632, 648, 672, 654, and 516.Press the pound (#) button. To check that the code works try several differentfunctions on the remote to make sure it will properly operate the TV. Keep inmind that some codes may not be compatible with your equipment. If this is thecase, please try the other codes listed for that device until you find one thatis compatible with your equipment.
We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Jul 25, 2010 | Emerson LC320EM8 32 in. LCD TV
Looking for remote codes
Hello rcbriggs, my name is Michael Hurst with DISH Network. We would have remote codes for you home theater system but it would depend on the model of the DISH remote that you have to give you the right one. What model DISH receiver/remote do you have? You can also try a Power Scan to get the volume to work with your DISH remote. Here are the steps for a Power Scan: With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release. Press and release the Power button. AUX Mode: Before pressing and releasing the Power button. Press 0 for a TV, Press 1 for a VCR/DVD and Press 2 for any other device. Then Press STAR (*). Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off. Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
Jul 18, 2010 | DISH Network IR Remote Control
Cannot find code for dish network remote to control emerson 32 in
Phillip with DISH Network here. We would be happy to help with that.
Step 1:
Press and hold the TV Mode button until all mode button back lights come on, then release.
Step 2:
Use the number buttons to enter the device code corresponding to the equipment. In your case we are going to use the Emerson codes: 764, 632, 648, 670, 699, 194, 537, 537. Then press the pound (#) button.
You should be able to control the volume and turn the TV on and off, if not try another code. Although we try to facilitate you in controlling both devices with one remote we cannot guarantee that we have codes for all the different brands and models of TV's.
Phillip Chang
Dec 12, 2009 | DISH Network IR Remote Control
Program sony remote to operate dish vip722
The Sony RM-YD029 Remote control will work with the Dish Network VIP722 DVR HD Satellite Receiver, but the Dish Network VIP722's Primary remote address must be set to 1.
The procedure below will allow Sony RM-YD029 remote control to operate Dish VIP722.
Using the Dish Network Remote Control -
1. Press menu 2 times to get to system info page
2. In the system info page the primary remote address is in a white box (bubble) followed by a Green TV (1)symbol that says IR and indicates you the channel your remote control one is configured. The Sony RM-YD029 will work when this primary remote address number (in the white box) is set to 1.
If the Primary Remote Address of your VIP722 Remote control 1 is not set to channel 1, here is how to change it:
1. While displaying the system info page, press and hold the SAT button on your dish network remote until all other modes are flashing, about 3 seconds.
2. then press the '1' button on the numeric pad of your dish remote
3. then press the '#' button on the numeric pad of the dish remote
4. then press the 'record' button (red dot button - stores setting)
5. At this point you should see a number 1 in front of the primary remote address on the dish system info page
Ensure you enter the corresponding IR code into your Sony remote control per the instructions in the manual or Sony's web site. My 722 works with Sony IR code - 01775.
Sep 08, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Sv2000 code for dich network
daulton13
I have provided instructions on how to program your remote to your player. Simply follow the instructions below. I have also provided codes for you to try. I hope this helps.
Funai: 500, 527, 532, 541, 569, 587, 618, 640, 657, 677, 679, 682, 694, 733, 756, 758, 777, 781, 783, 795, 797, 798, 829, 837, 838, 839, 841, 844, 846
      • Press 0 for a TV
Ray Calo
DISH Network
Aug 29, 2009 | DISH Network IR Remote Control
Televison & Video Logo
94 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
