Question about Peavey Music
I have a electric Peavey guitar T-15 I and the strings was off when I got it.I was told that I need to put the strings on it to keep the neck from warping,and just snug them up.Is thattrue or not?
    Top Expert:
  • Peavey Master
  • 26,198 Answers
Not true, the strings pull against the steel bar in the neck when tuned but otherwise no damage will occur. The steel bar takes the tension and is adjustable.
Posted on May 04, 2017
Electric guitar or Acoustic guitar,Which is hard to play?
Electric and acoustic these two types guitar are most useful than any other kind guitar. From my way electric guitar is not so hard to play than acoustic guitar If you can play acoustic guitar then you can play electric guitar too.There is some epic guide of playing electric guitar http://www.musicskanner.com/best-electric-guitars-2016-epic-guide
Oct 30, 2016 | Electric Music
Trying to look up serial number for 6 string electric guitar
It would help if you told us more about:
1.) What do you want to know about this guitar?
Nov 26, 2013 | Peavey Music
My neck of the guitar is broken. Please suggest a poosible way to repair this. Guitar is Samick Avion AV 3.
This is very serious as a broken neck means a lot to the guitar. It depends on the section broken and if the fret is also damaged.
Since the neck needs to be quite strong as the strings are tightened and must not in any way bend or be soft-- as the TUNING WILL KEEP ON CHANGING- the neck must be wedged back and then maybe the use of a counter steel reinforcement might be needed.
It is best to get this done professionally , if you intend to get this guitar to retain the quality.
Sep 13, 2011 | Samick Greg Bennett Avion AV-3 (Black)...
How to tune the peavy guitar
well. this may sound retarded but every guitar is the same google or youtube how to tune a guitar, also get yourself a guitar tuner there cheap and affordable
Jun 15, 2011 | Peavey Electronics Peavey Predator Plus...
How do I lower my strings closer to the fretboard
There are a few different ways to do this, and unfortunately if you have not done this kind of work before you could end up damaging the guitar more than fixing it.
A few things to look for:
Sight down the neck from the top of the guitar looking down along the edges. If you see a concave (banana shaped) bow in the neck, it needs adjustment. Almost all guitars including yours have a neck adjustment rod that can alleviate some of the bow. If however the neck is convex ( higher in the middle) the neck would need adjustment too. You want a very slight bow in the neck to allow for weather changes as wood expands and contracts with the weather.
Other adjustments are down on the bridge. There are usually very small allen or hex key adjustments for each string to raise and lower the action (height) of the string. Again, any adjustments here can also affect the tuning of the string up and down the neck (intonation). The guitar may not end up being tuned at one place one the neck while in tune on another.
I would highly recommend taking this to a music store with a qualified person to adjust it. Many times the action can be lowered and the string height adjusted for better playing ability. You can inform the technician now what you see and what you want done. Also let them know if you have a heavy or light touch on the strings as this can make a difference when they adjust it too. At the same time a lot of them also restring your guitar for you and you may request a lighter gauge of string allowing for better play too. Good luck.
Feb 21, 2011 | B.C. Rich BC Rich Kerry King Wartribe 7...
How do I change the strings on my Dean Vendetta
How to Change Strings on a Dean Vendetta Guitar
Dean Vendetta is a company that makes a wide range of electric guitars. These guitars are used by famous musicians and bands such as Alice in Chains and Megadeath. If you own a Dean Vendetta guitar, you will need to change the strings periodically in order to keep your guitar sounding bright and crisp. Without changing the strings, your instrument will sound dull due to dirt and oil build-up on the strings.
Instructions
Things You'll Need:
* Dean Vendetta guitar
* String winder
* Guitar strings
* Electronic tuner
* Wire cutters
Locate the high E string. This is the string that is highest and thinnest and closest to the ground when you play the guitar.
Loosen the high E string by turning its tuning key counterclockwise. Use a string winder for this if you have one. Pull the string off of the tuning peg and out through the bridge.
Insert a new high E string through the hole in the bridge, up the neck, to the head of the guitar.
Thread the string through the hole in the tuning key so that about two inches extends beyond the hole.
Hold the string at the top end of the neck in one hand as you turn the tuning key clockwise with the other hand. A string winder makes this task much easier.
Continue to wind the string until it tightens to pitch. Use an electronic tuner to check the pitch.
Clip off the excess string with wire cutters.
Repeat these steps to install the B, G, D, A, and low E strings.
Tips & Warnings
Expect to re-tune often for the first few hours after installing the new strings, as they tend to stretch quite a bit at first.
Hope it helped.
Thanks for using fixya..
Jan 14, 2011 | Dean Vendetta XM Electric Guitar
Buzz at the e6 string 11th fret
Have you changed strings on it? Old strings get worn spots in them from rubbing on the frets that will cause these type of symptoms. If you put new strings on and get the same issue, check your neck relief (the amount of bow in the neck) to do this, hold your low E string at the first fret, and at the 12th or 14th fret. The neck should have a slight bow in the middle that puts it between 1/16" and 1/8" or so away from your string. If it does not have enough bow in it, you can adjust the truss rod. Most guitars use an allen wrench for this, it will be inside the soundhole on an acoustic usually, and on an electric it is normally on the headstock under a cover. There are many how-to's online about adjusting a truss rod, the key is to do it very slowly, only do about a 1/2 turn a day, retune, check it again the next day. Loosen the truss rod to put more neck relief, tighten to straighten the neck. If this still doesn't fix you up, let me know, and I'll tell you where to go from there.
Apr 24, 2010 | Washburn D10sbc Acoustic Guitar
Washburn guitar B and high E string sound real buzzy-tinny. am fretting it clean. It just started doing it. Any Help?
Probably time for string replacement !!! They do go bad...
Get a set and try the E string... if it fixes that one, change ALL the strings at one sitting, but do them one at a time and tune each as you go... this keeps the tension and minimizes the interaction when you do the final tuning.
Feb 27, 2010 | Washburn Idol Series WI18QT Electric...
String buzzing
Dont give up on the neck. One tec you saw may not know what another that has had many years in the repair of gtrs knows !. But for the time being you can fix this your self. Find a alan wrench that came with your Gtr.thats your ntail pice. This is the bridge that each string cross,s over. Now slowly rase up the height of the string untill its high enough to stop the buzzing. Just half turns at a time. . All so if you keep the humitdy up near your gtr. it may correct its self, no **** just like magic. keep on playing DFD
Apr 10, 2009 | Yamaha Electric Guitar
Dean razorback DB problem
If the neck of the guitar is a bolt on neck (their will be a plate holding the neck onto the body of the guitar with several screws) then this is typical. Some strings will give off small vibrations. Nothing is wrong with the guitar, usually with a string change or with time the tone will fade as the strings change to the shape.
Hope this helps,
-Aaron C.
Jan 25, 2009 | Dean Razorback Db Electric Guitar
Music Logo
22 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Peavey Music Expert? Answer questions, earn points and help others
