Question about Jabra Radio Communications
I cannot get my contacts from my phone to work with jabra freeeway
I forgot how to get my Jabra tell me from my contacts names instead of the phone just ringing in my ear.
?? your contacts list isn't stored in your earpiece , its stored in your phone that the earpiece connects via Bluetooth too , so if your "phone" doesn't verbally announce whos calling to you then I don't see how your ear piece is going to ??
Apr 14, 2016 | Jabra STEALTH Bluetooth Headset Packaging
My jabra bt 160 wont work after a long time of not using it, and how to pair it to a device?
Your battery may be completely discharged. contact Jabra to fix this problem. Jabra has a lot of problems with their batteries!
Feb 22, 2010 | Jabra BT125 Headset
Setting up Jabra VBT2050 Bluetooth
I took my husband's suggestion and used 0000 and it worked. My husband claims it is the factory default for all bluetooth headsets. Try it and let us know if it works.
Dec 26, 2008 | Jabra BT350 Bluetooth Headset Headset
Jabra bluetooth adapter A210
hi,
you have to connect the jabra audio jack to the audio source, to the speaker output of your receiver for example. If jabra detects the source it will work. If you cut the connection, jabra watch for a while if something happend and than stops the transmittion. Hope that helps
Oct 26, 2008 | LG Jabra A210 Bluetooth Adapter for...
How to hook up a Jabra BT350 bluetooth
Make sure your cell phone's bluetooth is activated. Once you do that, you should be able to hold down the main button on the Jabra and once it turns on, it will connect with your phone.
Also, go to this site for Jabra. It links directly to the manual.
Jun 22, 2008 | Jabra BT350 Bluetooth Headset Headset
Jabra BT2010 Bluetooth Headset help
Hey guys, hold the button pressed for 6 sec. until led is solid. then search bluetooth devices on phone click on Bluetooth headset insert '0000' press OK now it should work, or check http://jabra.com for compatibility. Best wishes, htmlfreak.
Jan 03, 2008 | Radio Communications
Jabra ear piece
Call the Jabra Support hot line they will send you replacement earhooks free
Takes less then 5 mins to get them sent
Sep 30, 2007 | Jabra Bluetooth Headset with Adjustable...
Radio Communications Logo
Top Jabra Radio Communications Experts
Greg Cann
Greg Cann
Michael Vincent Cruz
Jerry Greenberg
Jerry Greenberg
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
