Removed screws from cover it still will not come off?
    New Friend:
  • 3 Answers
It comes off...just work at it. The side cover will slide back with some finger force. If not, get a small blade from a thin screwdriver and wedge it between the rear case and the side gently prying the cover back. Start at the top and move along the frame until it slides back.
Posted on May 04, 2017
  • 140 Answers
... sometimes tabs that are very well hidden prevent it from coming immediately, if you see them they may have to be pushed in or out in order to have the cover come off completely ... caution is they are in plastic so they don't break off ..
Removing steering column shroud on a 2006 sierra 3500, no screws where videos show to remove them there's a recess area but no screws in the locations indicated
Steering Column Trim Cover Replacement
Important: You must check for 2 pan head tapping screws (1,2) in the lower trim cover before removal.
If necessary, remove the 2 pan head tapping screws (1,2) from the lower trim cover (3). Remove the lower trim cover (3).
If screws are not present in the lower trim cover, proceed to the next step.
Gently unsnap the lower trim cover from the upper trim cover.
Important: You must check for 1 TORX® head screw (1) in the upper trim cover (2) before removal.
If necessary, remove 1 TORX® head screw (1) from the upper trim cover (2).
If a screw is not present, remove the upper trim cover (2).
Dec 01, 2016 | 2006 GMC Sierra 3500
How to remove dvd drive on aspire 5720
A) Remove the AC adapter (Charger) and Battery
B) Laptop closed turn it over, lay it down on a soft cloth on a table, Battery Bay Compartment AWAY from you.
C) The Thermal Cover is the largest cover on the bottom of the laptop. Goes from the right side to the middle, and very close to the Top and Bottom.
There are four Philips head screws to remove in the cover, before the cover can be removed.
1) Under the middle of the Battery Bay Compartment, and at the Top/Left corner of that rectangular vertical vent, in the Thermal Cover.
2) At the Bottom/Right corner of that vertical vent, in the Thermal Cover.
3) In-between the two horizontal vents, located at the Bottom of the Thermal Cover.
4) Straight above the screw removed in 3), is the last screw to remove. There is a round shaped vent, inside a square at the top right of the Thermal Cover. The screw to be removed is at this vent's Bottom/Left corner.
Once all the screws are removed, ease the Thermal Cover up from it's left side, (Middle of laptop), at an angle, then remove.
D) In the opening with the Thermal Cover removed, there is one Philips head screw to remove, then the ODD can be removed.
(Optical Disk Drive. The DVD drive)
This screw is located..............ack, ack,.......fzzzt.......ffffzzzt,......
Jun 02, 2012 | Acer Aspire 5720 Notebook
Highbeam switch
  1. If equipped, disable the SIR system. Disconnect the negative battery cable.
  2. Remove the upper steering column cover.
  3. Remove the lower steering column cover screws and lower the steering column cover.
  4. Remove the 2 switch mounting screws and remove the switch.
  5. Detach all wire connectors from the combination switch. Push locking tabs to remove the wires.
To install:
  1. Attach all wire connectors to the combination switch.
  2. Install the combination switch to the column with the 2 attaching screws.
  3. Install the lower steering column cover screws and lower steering column cover.
  4. Install the upper steering column cover and attaching screws.
  5. Connect the negative battery cable.
  6. Enable the SIR system, if equipped.
Dec 04, 2011 | 1999 Pontiac Sunfire
Wind top AE1900 AIO MS-6638. how to replace hard disk
To remove back leg: pull off round end caps where leg connects to back (pressure fit). Then remove black stickers covering screw holes at base of leg. Under stickers are 4 screws - remove and lift off leg assembly.
Remove back cover: remove 7 black screws from back (one hiding under warranty sticker). Lift back from bottom edge (pressure connections on top edge). Back cover will catch on cd/dvd tray door - bend slightly to get around.
Under back cover is metal cover. Remove screws from around edge holding back cover on (note that most screws you will see in pairs - only remove the one holding the metal cover, not the one holding the chassis). Lift off metal cover.
You should now see hdd. One screw holding in position - remove screw, slide out hdd (it will have a metal frame around it). HDD is a 2.5" laptop style.
Swap out hdd from its frame, then re-assemble.
Oct 13, 2011 | Office Equipment & Supplies
How do we get the plastic cover off the machine? We have removed all visible screws on cover and plate, removed cover over light bulb area, and plastic extension around plate area. We are trying to...
Is this a sewing machine? Plastic covers can be tricky to remove. Look for deeply set screws in deep holes, as well as screws that might become visible after removing covers. Sometimes the screws holding the rubber feet on will also secure the cover.
Aug 20, 2011 | Vacuums
Braun 4166 household blending mixer How do you take this apart?Disassemble?
1. Remove two small plugs on top, digging a wood screw into the soft plastic. They cover two screws.
2. Remove the screws.
3. Remove the cover.
4. Remove two screws holding the motor housing to the foot.
Dec 21, 2009 | Braun MR 300 MultiQuick Blender
CMOS Battery dead, No Post, No System Beeps
bloody hell! All the ones I have used (IBM, Compaq and Dell) have clear access to the battery!
That sounds very frustrating!
My Solution, drop kick it out the window if you have to replace another!
Mar 18, 2009 | EliteGroup ECS DESKNOTE A929 Notebook
Error 57.04 - how to replace DC Controller
you may have this resolved already or possibly you just decided to purchase a new printer or have it serviced somewhere.. so if someone happens to care:
Remove fuser
remove front top cover by removing stay on leftside and screw on right side slide cover to right and remove
remove rear cover 2 screws
remove top rear cover 3 screws along forward edge use flat blade screw driver to lift sides
remove left side cover 2 screws and 2 clips
remove metal cover 10 screws (3 left 2 top 2 right 2 botom 1 botom right from rear of printer
Oct 29, 2008 | HP LaserJet 9040mfp All-In-One Printer
LCD Monitor
1st remove the base cover by by squeezing to release the clips and remove the 6 base mounting screws. 2nd remove the 5 screws in the back cover. 3rd push and pry at the parting line to release the clips. 4th remove the base mount by removing the two attaching screws and sliding it down about a quarter inch. 5th remove the steel cover by removing the 4 wires, two screws from power outlet, two bolts from vga plug, and the other screw in the cover. and there you have it.
Oct 26, 2008 | Acer AL1717 17" LCD Monitor
Ignition lock removal
if you want to remove the plastic cover, look for some screws from the bottom part of that plastic cover. there are about 4 screws. you ,may need a long philips screw driver. after you remove the screw, the top cover could slide out off the key lock assembly.
tnx 4 using fixya,
Oct 14, 2008 | 1998 Pontiac Grand Prix
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
