Question about GE Kitchen Ranges
How to rest clock on GE free-standing gas convection range
  • 213 Answers
SOURCE: frigidaire convection free standing range
new ranges come set for natural gas. in the installation instuctions there should be instruction for converting the range to lp. some models require that the orafice for the burners be replaced as part of the coversion, if so the there should be a pack of them with the new range. others you just have to tighten the orafices that are all ready in the range. you installation guide will tell you which one you have to do
Posted on Nov 25, 2007
  • 22 Answers
SOURCE: Claibrating the temperature of a GE gas oven
First of all, do not use the oven thermometers from a grocery store. they can be off by 20 degrees or more. These directions may help you for electronically controlled ovens. The older manually controlled ovens have a small screw head in the center of the oven temperature knob that can be adjusted in usually 10 degree increments.
To Adjust the Thermostat
Touch the Bake and Broil Hi/Lo pads
at the same time for 3 seconds until the
display shows SF.
Touch the Bake pad. A two digit number
shows in the display.
Touch Bake once to decrease (-)
the oven temperature, or twice to
increase (+).
The oven temperature can be adjusted
up as much as 35°F. or down as much
as 35°F. Touch the number pads the
same way you read them. For example,
to change the oven temperature 15°F,
touch 1 and 5.
When you have made the adjustment,
touch the Start pad to go back to the
time of day display. Use your oven as
you would normally.
NOTE: The thermostat adjustment for Baking
will also affect Convection Baking or Convection Roasting.
Posted on Dec 03, 2007
reg501
  • 413 Answers
SOURCE: pf code on frigidaire professional series free standing range
"PF" indicates the electronic control detected a Power Failure.
This could have been caused a brief power outage OR may be an indication that the connections to the oven, either at the stove or at the plug are loose.
Posted on Jun 10, 2008
TheMobilian
  • 8220 Answers
SOURCE: I just converted my GE Cafe? 30
Did you tighten the spuds down and open the air shutters?
Posted on Mar 11, 2010
wiringlunati
  • 576 Answers
SOURCE: I have a GE Profile free standing gas range
Sorry, usually that is a bad control board. It looks like they are available at www.appliancepartspros.com for $121.50 You'll have to decide if it is worth fixing.
Posted on Apr 26, 2010
Kenmore Convection free standing range F2 code oven not working
Actuall because Sears/Kenmore has so many manufacturers we really need you model number to translate your F2 code to the manufacturer. However.... most F2 Codes are pretty common and all point to a bad temp sensor. Most temp sensors read 1,000 to 1,100 Ohms at 70 Deg F if they are functioning. See this link and note the very bottom sensor by GE will read differently. http://www.applianceaid.com/oven_temp_sensors_help.html
You also did not mention if this was a gas or electric range. If you need more assistance, please provide a model; number and I will help you.
Kelly
Oct 01, 2010 | Whirlpool WFW8300SW
I need the wire diagram for a GE range M# JB680SPSS
  1. Type in this Model # JB680SPSS "Only" on the website: http://genet.geappliances.com/DocSearch/Dispatcher
  2. This is what they have to offer you free to download on this website. (Manual's)
  3. JB680SPSS
    GE® 30" Free-Standing Electric Convection Range
    Quick_Specs, Use_and_Care_Manual, Installation_Instructions
Hope this helps you out. wvrain2006 :)
Sep 29, 2010 | GE JB680SPSS Stainless Steel Electric...
I have a GE Profile free standing gas range JGB920sefss, the display for the clock & oven temp etc doesn't work so we can't use the oven, but the burners and interior oven light work any ideas???
Apr 26, 2010 | Kitchen Ranges
My Frigidaire FGFL67DBF gas oven does not reach the temperature set. I tried to calibrating the control, but it did not work. Any suggestions?
I believe that you have a convection oven.... by design, convection ovens built by GE come up to temperature....at 25 degrees below the set level .... when the Convection function is enabled.
Oct 15, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Installation of gas convection oven range
check the specs on the oven you are planning to buy(the retailer should be able to provide this imformation)they should give you a recommended location for the gas feed in relation to the oven.the feed will need to be relocated to this location.if you are not comfortable doing this yourself (always use caution & common sense when working with natural gas).i would call in a proffesional,alot of times your local gas company will do this for a nominal fee,somtimes for free.hope this helps.thanx for using fix-ya!!!
Nov 29, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Frigidaire convection free standing range
Nov 24, 2007 | Tappan MGF500PBW Gas Kitchen Range
display shows SF.
increase (+).
touch 1 and 5.
you would normally.
Nov 22, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
