Question about Boating
What does a transom bracket for a seagull outboard model 40 plus look like ?
4 Suggested Answers
  • 10 Answers
SOURCE: bow mount 80lb to transom mount
Parts can be purchased from this dealer...There are schematics on the site for review....
http://www.northlandmarine.com/MinnKotaQuickRef.htm
Posted on May 08, 2009
SOURCE: Starting Insructions for a seagull outboard
engine runs but prop doesnt turn ?
Posted on Aug 27, 2009
AndrexT
  • 19031 Answers
SOURCE: how to change the throttle cable on my seagull outboard?
Remove the screw on the top of the throttle lever and insert the end of the new cable. Remove the top of the carb by unscrewing it and remove the cable and insert the new one with adjuster.
Here are the cables complete
http://www.sheridanmarine.com/product/british-seagull-outboard-throttle-cables
Here are some videos and one guy says he has changed his.
change the throttle cable on my seagull outboard Google Search
Posted on Nov 24, 2016
Testimonial: "Does the end going into the carburetor with spring etc,just pull out,this end should be attached?"
I have a Yamaha 115hp AETO 6E5 outboard on my boat and would like to know the year of the motor and the best place to buy a tilt/trim repair kit please
Beginning in 2005 Yamaha stopped including the year information in the model number. The production date can be found on the transom bracket of post 2004 motors.
Nov 27, 2017 | Yamaha Boating
How to change the throttle cable on my seagull outboard?
Nov 24, 2016 | Boating
Seagull water pump failure
Or if you want to do it yourself. There are videos to at the bottom link
  • British Seagull Outboard TRN40700 Water Pump Kit ... www.sheridanmarine.com > ... > British Seagull Outboard Spares The British Seagull Outboard TRN40700 water pump kit including the rotor, the joint plate and fixing bolts.
  • Tips & Tricks - Seagull Outboard seagulloutboard.com/?page_id=74 These tips & tricks are ideas contributed by a variety of Seagull Outboard enthusiasts ... This is best done by substitution of the thick pink water-pump gasket with ...
  • Seagull Fourty Plus, & Cooling Modification - YouTube www.youtube.com/watch?v=cfjpVoazL2Q
    • BY RTEDA
    • 3 MIN
    • 7.3K VIEWS
    2009-08-22 ยท British Seagull, GFPL series N7 (Dec. 1977). Added a siphon-effect water coolant improvement. With an added tube from the original water ...
  • Seagull FAQ www.britishseagullshop.com/faq.html Does the engine pump water? ( If it does its most likely the cooling system is fine) 4. ... HOW CAN I SOLVE THE ELECTROLYSIS PROBLEMS ON MY SEAGULL?
  • Seagull water pump failure Bing video
    May 09, 2016 | Boating
    Where is serial number on a 25 hp Mariner outboard?
    model number and serial number are on the transom mounting bracket. Trim up your engine and look on the right side
    Mar 04, 2016 | Boating
    What year is my outboard motor
    It appears you have a Johnson, 40 horsepower, electric start, long shaft (20 inch transom) 1973.
    May 14, 2014 | Light Outboard Motor Boat Bass Fishing...
    18502s-e10616
    MODEL# AND SERIAL# ARE USUALLY FOUND ON TRANSOM BRACKET. I AM ASSUMING THIS IS AN OUTBOARD
    Jul 05, 2013 | Boating
    The serial number on the boat is located on the back (transom) right hand side near where the hull meets the deck. On the outboard motor it's on the bracket that attaches the motor to the transom and usually on the engine block as well.
    May 21, 2013 | Nitro Boating
    Serial Number 1001499 Model Mark 25 Mercury Outboard what year?
    pinched rom another website:
    Every Mercury outboard has a serial number label located on the transom bracket area of the engine. The latest serial number labels display a 2-digit number in a box at the lower right portion of the label. These digits coincide with the last two digits of the year in which the outboard was manufactured. For example, if an outboard was manufactured in 2010, the number "10" would appear in the box at the lower right portion of the label.
    Jan 06, 2013 | Boating
    Yamaha outboard 8 horse power tilt removel trouble
    Trouble removing it from the transom? Is it C clamped into the transom? Or a bracket built of the transom?
    Nov 07, 2011 | Light Outboard Motor Boat Bass Fishing...
    Want to replace the trim/tilt motors on my 1995 Yamaha TXRT 200hp outboards... do I have to remove the motors from the boat?
    no. a unmodified transom bracket may need to be moved not removed. Since the tilt motor is out you will need to manually lift the engine. you can see the picture diagram at www.yamaha-motor.com. click on outboard motors,parts and service, view parts catalog. find your year make and model by following steps listed at top. select power trim and tilt assembly. in the picture you will see the location of the Manuel release valve on the starboard side. turn the Manuel release valve then lift the engine. tie it up or use a stand to keep it up,do not use the tilt lock. with the engine in full tilt position, you can see the motor. some brackets are modified were you can remove the motor without moving the transom bracket. If unmodified you'll need to follow these steps. (1) lower the engine back down.the steering arm needs to be removed from the steering cable and swung forward. do not remove steering arm from engine. on the starboard side of the engine you will see the steering cable going into the steering cable tube. (2)a 1 1/6 nut secures the cable to that tube remove it and slide cable out do not remove it.(3) lift engine again and secure it. your about to remove the motor mount bolt so make sure you secure the motor completely (4)remove upper and lower transom to bracket bolts remove bolts on the port side only.(5) you will see three bolt that go through the transom bracket to the trim and tilt assembly. remove them.(6) if all bolts are removed you will be able to slide the port transom bracket to the left out of the way(7) remove tilt/trim motor.
    Sep 13, 2009 | Boating
    Boating Logo
    Top Boating Experts
    Steve
    Steve
    ray gallant
    Fabrice Wolters
    Are you a Boating Expert? Answer questions, earn points and help others
