I HAVE A AFFINITY TOP LOADING WASH MACHINE AND I HAVE A LC CODE POPPED UP
  • 662 Answers
SOURCE: front loading wash machine
Plug off the mains. First drain out all your water by lowering the exit hose into a bucket or drain. You have to look for screws below the front kick-panel, the panel comes down & out. (You may find the drain hose here, on left) The pump is on the right side. Be prepared for dirty water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out. Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter.
Pl give me a nice rating for the free help!
Posted on Jun 08, 2010
SOURCE: Top loading kenmore washing machine frozen water loaded
Could it be that it has overheated? My mom's washing machine isn't a kenmore, but it has a mechanism that causes it to stall when it is overheated from constant use. After about 15 minutes it cools off and starts again.
Posted on Aug 07, 2009
  • 146 Answers
SOURCE: can you tell me what a code E20 is for an
that is a drain code, you may have a clog in the catch tube,, sorry to tell you this but the tube is inside the hose that comes off the bottom of the drum, , you should be able to take the back cover off and find the black soft rubber hose coming off the bottom of the tub,, take it loose and look down in it , there is a white plastic trap in there to collect things such as coins and socks,, if coins get in there then lint will start to build up and then it slowes the drain down
Posted on Feb 10, 2011
  • 6277 Answers
SOURCE: Top loading Washing machine giving
On many different makes/models 'dE' stands for 'drain Error' anyway! On others it can stand for 'door Error which is why it is important to remember to state the make and model- but not everybody does ;-0)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Aug 14, 2011
SC Cobra
  • 15 Answers
SOURCE: our kenmore elite oasis top loading wash machine has a LD error code anyone know what this means and how to fix
Type the code into Google search bar
Posted on Nov 09, 2014
Front loading wash machine
Apr 07, 2010 | Frigidaire ATF6000ES Front Load Washer
It buzzes and error or pause comes on wont spin, wash anything water is in the machine. I tried lightening load. not matter what cycle I try. Tried turning it off. Door is shut dispenser is...
Since your machine is not giving an error code, your problem is probably a defective door switch. They fail fairly often in your model. It's an easy repair, at least! The electrical switch is what "catches" the latch (striker) from the door and holds the door shut during operation. To replace, first remove the top lid by removing the two screws in the back and sliding backward. ( Looking down from the top/front, you can see the switch.) Then, remove the two screws holding the door switch from the front of the machine. This will allow you to bring the door switch up. Note how it's wired and reconnect the wires the same way, one at a time, to the new switch. Replace the two screws from the front, reinstall the top lid, and you are ready to wash!! Good luck.
Mar 27, 2010 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Mold on gray rubber seal in Bosch washing machine
I use to sell bosch front loading washers for about 3 years, its a common problem on all front loading washers. Try a hot wash through the machine, if no joy then remove the seal and wash in hot soapy water. Make sure you replace the seal while its still hot from wasing if you take it off.
If still no joy, the call a service person and replace the seal. Its just one of those things.
Jun 12, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Beko wm1510w bearing?
Hi there.....this rattle can usually be associated with failed or failing bearings.......simple test to follow....with machine switched off and door open...put your hand in and try lifting the inner wash drum...there should be NO MOVEMENT...movement indicates failing or failed drum bearings
regards Sir Galahad
Nov 09, 2008 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Roper by whirlpool model # RAX4233PQ0
i assume that's a top load and not a front load as pictured..ck wiring connections to motor try turning coupler between motor and gearcase by hand if locked remove pump(2 clamps from motor) try again if turns free clean pump if not gearcase ..if turns free with pump attached and wires look ok suspect timer
Jun 20, 2008 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Affinity Washer: Will only display 56...Pau, Err on any button
This was exactly what was wrong with my washer!!!!!!!!!!!!!!!!!!!! Stupid Easy Fix! I would recommend leaving it unplugged until you are ready to undo the plug for the door lock. This was a perfect solution!!
Feb 27, 2007 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Washing Machines Logo
Top Washing Machines Experts
