Question about Get Home Security
I have a Defiant motion sensor light, model DF 5416 BK A...How do I get it to turn on when only motion is detected?
    Top Expert:
  • Get Master
  • 41,838 Answers
Try Googling (defiant)(DF 5416 BK A)(manual) without parens to get instructions.
Posted on May 04, 2017
  • 193 Answers
SOURCE: hi have a ir-tec ir 580q motion sensor is it
yes you need to cut some tracks on the pcb look for the power relay and remove the track that sends the mains into this relay also note you can also run the whole unit an 12 v d.c by removing the voltage dropping cap and current limiting resistor.if you can send me an email with photo of the electronics i may be able to give more info.
P.hampton25@yahoo.com.au
Posted on Jun 07, 2010
johnjohn2
  • 5763 Answers
SOURCE: my honda odyssey 2003 model
The tcs light will come on whenever the engine light is on, this is because the tcs cant operate correctly when engine is not running good so its shut down by the computer, the code if the only code means there a problem with the knock sensor, you will need to check the connection and make sure the wire is good and if it is then you will need to replace the knock sensor, heres a diagram to help you locate the knock sensor good luck, hope this helps,johnjohn2_69.gif
Posted on Feb 20, 2011
johncorde40110
  • 720 Answers
SOURCE: My Defiant LED outdoor white Blade Motion Security stays on all night
You may need to set the parameters once chosen which means you need to hold the set button in for at least three seconds once you have selected your choices.i usually set new up in the house and then check the duration of the light before installing in situ.
Posted on Jan 28, 2015
bwcolq
  • 59 Answers
SOURCE: Defiant flood light 180 degree led: 1. Instruction manual says to put a maximum of one such light on a wall switch. Why can I not have 2? 2.it has photo sensor in addition to a motion sensor? Thx.
Maybe two light fixtures each with photo sensors and the lights being near each other, might trigger both sensors to react to each other and turn lights on and off rapidly.
Posted on Jul 10, 2016
blogcnm2345
  • 469 Answers
SOURCE: Have a defiant motion security light done everything comes on blinks goes off back on blinks pc of junk have 3 more work fine any ideas
New contacts occur everyday and with a little initiative, the person may be able to near a sale or be referred to someone who may need it. AmanStino Lightning Cable Apple MFi Certified 1M Nylon Braided Charging...
Posted on Jan 09, 2017
Defiant motion security light. When I installed dimmable LED flood light, it no longer goes dim as it did previously
That is probably because LED lamps draw very low current compared with incandescent lamps and a standard dimmer requires a load to work correctly..
Nov 07, 2017 | Office Equipment & Supplies
Lost manual to program defiant daylight adjusting indoor digital timer
videos and text manuals.
49814 Program Guide Defiant Daylight Adjusting Indoor Digital Timer ...
? 16:31
https://www.youtube.com/watch?v=yxZKNVddNU0
Jun 24, 2015 - Uploaded by Jasco Products Company
49814 Program Guide Defiant Daylight Adjusting Indoor Digital Timer. Jasco Products Company. Loading ...
Defiant Daylight Adjusting Indoor Digital Timer with Motion Sensor ...
https://www.homedepot.ca/.../p.daylight-adjusting-indoor-digital-timer-with-motion-s... Easily automate indoor or outdoor lights with the Defiant Daylight Adjusting Indoor Digital Timer. Program up to 7 on and off times per week. Auto adjusts to ...
DEFIANT 469-637 QUICK START MANUAL Pdf Download. - ManualsLib
https://www.manualslib.com > Brands > Defiant Manuals > Timer View and Download Defiant 469-637 quick start manual online. DAYLIGHT ADJUSTING INDOOR DIGITAL TIMER. 469-637 Timer pdf manual download.
[PDF]Home Depot Defiant Timer - A-1 Electric Co., Inc.
www.a-1electricco.com/technical/timers/defianttimerprogramming.pdf We appreciate the trust and confidence you have placed in Defiant through the purchase of this daylight adjusting indoor digital timer. Visit us online to see our. defiant daylight adjusting indoor digital timer Google Search
Mar 13, 2017 | Hardware & Accessories
I bought and installed the light below at home depot. It worked for a week. Now it still has power, bulbs work but the motion sensor doesn't activate the lights
Take it back, its faulty.
There is a sensitivity setting somewhere, try moving all the way up and then down a bit.
Dec 13, 2016 | Home Security
Jul 09, 2016 | Home Security
Jan 28, 2015 | OUTDOOR Home Security
My motion security light keeps blowing only the left side bulb.
I assume you mean that the light bulb is failing. This can be caused by a faulty connection at the base of the lamp which causes the bulb to heat at the connection point. Remove the bulb and (with power off!) examine and clean the bulb socket.
Jan 19, 2014 | Defiant Flood Lights. 180 Degree Outdoor...
Wiring motion sensor light
Hello Lesco1, first check the bulb, second I need Mgfr & model, third attempt BK from house to R of sensor & BK from sensor to BK of bulb.
Nov 06, 2008 | Electronics - Others
Home Security Logo
171 people viewed this question
Top Get Home Security Experts
ray gallant
Beniptec
Level 1 Expert
R.A. Ellis
R.A. Ellis
Are you a Get Home Security Expert? Answer questions, earn points and help others
