Question about Refrigerators
The freezer half is not working
The feezer defosted itself whilst we were at work and leaked water from the dispenser. has not made a difference overnight on express freeze and highest temperature. The door was not left open. Fridge is ok.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,810 Answers
Sounds like the defrost timer is stuck to me
call the fridge man or bur a new fridge
parts should be arround 50 plus 50 to install
but call and check first
Posted on Jul 25, 2009
How do i fix ice maker
Could be 2 different problems. Inlet water valve is a dual valve (2 halves). 1 half feeds water to the door dispenser, the other half fills the icemaker. The icemaker half could be bad or blocked up with sediment causing a no fill situation. 2nd problem could be the icemaker itself which sends power to the inlet valve when it needs filled. Usually the inlet valve fails first but you need to test and see.
Apr 14, 2015 | Refrigerators
Frozen potatoes and soft butter, fridge not working
Anytime one of the cooling tubes is blocked it forces the cold air from the freezer through the open cooling tube or tubes so you will have spot freeze ups. Suggest you use a flexible wire like a guitar string to attemp to clear the blockage. If you heat the wire with a hair dryer, it will make the job faster.
As far as the unit resetting itself, it could be a preset condition. If the sensor are telling the control board one thing and you are trying to change settings, then the preset conditions could be over riding your commands. Get the cooling tubes cleared and see if things go back to normal.
The water dispenser - could be you have a leak in the water line running into the door or it could be the water depenser itself. Not enough data to tell - suggest you localize the leak. Sometimes flour will tell you where the leak starts.
Jan 08, 2012 | Refrigerators
GE Side By Side Ice Machine & Water dispenser not getting water
you may have a pin hole in your water line to your dispenser or you could be leaking at the water valve itself on the water dispenser side. you'll have to pull the refrigerator out from the wall and look where the main water line goes into the back of the refrigerator. you will probably have to take the back off to see. be sure you put the back of the refrigerator back when you are through.
Jun 05, 2010 | GE Profile PSW26P Stainless Steel Side by...
Fridge Not Working
Your problem could be one of the following:
* compressor
* attachments to compressor (e.g.: relay, capacitor (if applicable) or overload protector)
* refrigerant (e.g.: restriction or leak)
* temperature control assembly
Contact an appliance service company.
Feb 19, 2010 | LG LRTBC1825T Top Freezer Refrigerator
The power supply to our whirlpool american fridge feezer is still there but the fridge freezer is not working, no lights are coming on the freezer is defrosting and the water dispenser has stopped working,...
Check the circuit breakers , or , use an extension cord to a plug that you know is working ( extension cord is for test purposes only ) . Or , unplug refrig , and plug in a small lamp etc to check refrig plug . Make sure the plug is not a G F I plug .
Oct 10, 2009 | Refrigerators
Ice/Water dispenser not working correctly
hi,,
it is a thermostat problem,,because of it heating is not done properly ..u should replace or fix it,,it is not a big amount....
thank u,,,
Jul 01, 2009 | Admiral 26 cu. ft. Side-By-Side...
Freezer and fridge not cooling (halfway)
SxS Amana upper half of feezer and Refrigerator not working
Jun 22, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Water leak @ bottom front left with water turned off
this quite simple, inside the freezer compartment lower half there is a removable inspection cover, or what you may call the rear interior wall. remove this cover/wall and underneath the cooling coils is a drain hole for the defrosted water to escape to the pan located under the refrig. This hole is obviously blocked with some object, possibly just ice. As it is blocked the defrosted ice in the form of water cant exit the normal way so it is over flowing onto the freezer floor. everytime the defost element comes on more water will leak. solution is to clear the drain hose possible with hair dryer , or gently running a firm but flexible plastic tube through the drain tube to push any blockage on through. This has to be done very slowly and carefully.
May 19, 2009 | Jenn-Air JSD2789GEW Side by Side...
New water valve not filling the ice maker.
take the supply line to water valve and blow into it
you will feel it if it is clear if blocked remove tube
and clean
Apr 13, 2009 | Refrigerators
Water Dispensor
The water line is frozen inside the freezer door. Open the freezer door and take a hair dryer to warm the inside of the feezer door. Check the water dispenser every 5 minutes to see if the line is unfrozen. Water line is ran from the bottom to the waterr dispense unit. Usally take 10-20 minutes to unthaw water line inside of freezer door. Good luck.
Nov 07, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
Refrigerators Logo
80 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
