Question about Apple MacBook PC Notebook
It doesn't accept my discs
Whenever i enter the disc's when i start to think that it has been accepted it comes out ten seconds later
  • Z Laws May 11, 2010
    What disks? Being more specific about your problem will help. What model of laptop, what operating system, what disk? Burned or original?
    Brigadier General:
  • 4,090 Answers
The disk is damaged or dirty, ( thumb print or grease) clean the disc and try reinserting it
Posted on Jul 25, 2009
I have put a windows xp disc into the laptop & it goes to windows start. Then it will not respond to the 'enter' button. I just cannot get it any further.
Could be a dodgy disc. I suggest testing it on another computer.
I had a similar problem with a Dell computer while trying to load XP onto a clean hard drive. It would go so far and simply wouldn't go any further. I think it had something in the bios preventing it accepting anything other than than the official disc.
By experimenting I found if the hard drive already had an operating system on it then XP was accepted without trouble. I have a suspicion if I had removed the bios battery it might have worked with the clean drive.
Mar 26, 2016 | Computers & Internet
I think something is wrong with my optical drive. Whenever I put a CD into it, my laptop will just eject it right back out. It worked before, but it won't let me play the disk. Usually the disk image would...
troubleshooting advice below-try steps in order until the problem is resolved.
  1. Be sure to check your disc to make sure it is flat. You can check this by putting the disc upside-down on a flat surface. If the disc is bowed up on any side or in the center, do not use the disc as it may get stuck in the drive.
  2. Make sure you are inserting the disc far enough for the drive mechanism to activate. Discs must be inserted at least three-quarters of the way into the drive, and often nearly all the way in, before the drive will pull them in.
  3. Make sure the disc is completely inserted in the drive. The disc-insert cycle runs the motor for about 6 seconds. If, for whatever reason, a disc is not completely inserted, the drive will reverse and push the disc back out of the drive.
  4. Since the entry slot can be tight at first, give the drive 1 or 2 seconds to accept the disc and pull it in on its own. If the drive struggles with injecting discs or injects them part-way then stops, inserting a disc multiple times should correct the issue.
  5. Restart the macbook.
  6. Do not use discs that have anything attached to them or dangling from them (such as "sweeper" or cleaning discs).
  7. If the drive repeatedly does not insert media fully, or accept media at all, please contact Apple, contact an Apple-Authorized Service Provider, or make an appointment with an Apple Retail Store for additional troubleshooting, evaluation, or service.
Jul 14, 2010 | Apple MacBook Mac Notebook
Playstation wont take any disc it'l eject but not insert
i have seen this before... there is a little eye inside the ps3 bluray drive that senses when a disc enters and starts turning wheels with rubber feet on them to pull the disc in. when that eye goes bad for what ever reason the only way to get it to accept discs is to force it in slightly and it will spread the acceptance arms and pull it in. if it will not eject the disc correctly then the drive has been disassembled and needs to be reseated until it function right.
the acceptance eye is fairly cheap to buy online but can be a pain to replace if you dont know what you are doing.
Mar 07, 2010 | Sony Playstation 3 (PS3) Console
My LG LHB977 home theatre Displays NO DISC whenever I insert any disc.What could be the problem???
It may be a dirty "laser lens". It is possible to clean this lens w/rubbing alchohol and a Q-tip.
Disconnect all power b4 disassembly.
Aug 20, 2009 | LG LHB977 Theater System
Doesn't accept md's
The manual says "C13/Disc Error: The system cannot read the disc information correctly. mEject the MD once, then insert it again."
It seems this error turns up when the system cannot read the disc properly, one reason for which is a dirty/dusty lens. Try a minidisc lens cleaner if you haven't already.
Tom
May 02, 2009 | Sony CMT-MD1 Shelf System
Wont accept disc
Try this....after a lot of frustration and research, what i found on the internet for this problem was usless. I tried holding down the eject button for 15 seconds to reset the disc drive, still it would'nt accept the disc. As i literally picked up the phone to ring sony, as the ps3 was on standby i pressed the eject button multiple times and heard 2 beeps each time, still the system stayed on standby. After that i then tried just putting the disc in as normal as its on standby and the system booted automatically and accepted my disc. I hope this helps others, as mine now works perfectly.
(PSN ID is Burnsy333)
Jan 04, 2009 | Sony Playstation 3 (PS3) Console
Ze2000
Do you have a recovery disk?
Insert the recovery disc, (if auto run starts up, just close it)
Go to Start>Run and type cmd and hit enter.
In the DOS command window, type sfc /SCANNOW and hit enter.
That will check your Windows files against the Windows files on the disc. If it finds corrupted or missing ones, it will repair or replace them. You will not lose any data or files this way. (If it will accept the disc again)
Jan 09, 2008 | HP Pavilion ze2000 Notebook
Dvd writer wont accept dvd-r
If you have posted the correct model of writer, then it only supports the writing of DVD+R and DVD+RW discs, but CD-R and CD-RW disc writing are supported, and it should play all forms of DVD, so it won't burn DVD-R and RW discs, but if it wont play all types then try a cd/dvd cleaner, but to be honest when writers start playing up the lens is normally faulting and a replacement drive will be required.
Jun 18, 2007 | HP DVD Writer (ds703a) (DS703A) DVD+RW...
Apple MacBook PC Notebook Logo
149 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
