Question about Building Materials
I can not program my garage door entrance on my garage door opener
SOURCE: i have a pmx300IC genie
palm treo 700w off no open
Posted on Jan 19, 2009
  • 118 Answers
SOURCE: jag xj6 1996 97 programming the garage door openers
1. For first time training, press and hold the two outer HomeLink buttons, releasing only when the HomeLink indicator light begins to flash after 20 seconds. (Do not perform this step when training the additional HomeLink buttons.) 2. Position the hand-held transmitter 1-3 inches away from the HomeLink surface (located on your visor), keeping the HomeLink indicator light in view.
3. Using both hands, simultaneously press and hold both the desired HomeLink button and hand held transmitter button. DO NOT release until the HomeLink indicator light flashes slowly and then rapidly. When the indicator light flashes rapidly, both buttons may be released. (The rapid flashing indicates successful training.)
property_damage_symbol_sm.gif Note: Some garage door openers may require you to replace step 3 with the “cycling” procedure noted in the “View Canadian Instructions” section.
4. Press and hold the trained HomeLink button and observe the indicator light.
  • If the indicator light is solid/continuous, training is complete and your device should activate when the HomeLink button is pressed and released.
  • If the indicator light blinks rapidly for 2 seconds and then turns a solid/continuous light, proceed with the following training instructions for a rolling code device. A second person may make the following steps quicker and easier. Please use a ladder or other device. Do not stand on your vehicle to perform the next steps.
5. At the garage door opener receiver (motorhead unit) in the garage, locate the “learn” or “smart” button (usually near where the hanging antenna wire is attached to the unit). If there is difficulty locating the training button, reference the garage door opener’s manual or contact us. 6. Press and release the “learn” or “smart” button (the name and color of the button may vary by manufacturer). NOTE: Once the button is pressed, there are 30 seconds in which to initiate the next step. 7. Return to the vehicle and firmly press and hold the trained HomeLink button for two seconds and release. Repeat the “press/hold/release” sequence up to 3 times to complete the training process.
Posted on Jan 30, 2009
  • 1348 Answers
SOURCE: programming garage door opener
there are three buttons on the opener.hold the 2 outside ones down for 25 to 30 seconds to erase the program. once the light (if equipped)flash rate changes,let go.
then push any one of the the three buttons and hold it in. and then push your remote. when the flash rate changes,the code is now in the homelink transmitter.the slt and slt plus had that feature.
Posted on May 14, 2009
  • 18 Answers
SOURCE: program instruction garage door opener in 2005 chrysler pacifica
if your garage motor have rolling codes you need to put your car inside garage near the motor leave ignition on go to the motor locate learn button press it then quickly go to the car and press and hold one of the buttons for approximately 30 sec or until it start blinking rapidly, if you have a regular motor take one hand held opener go inside car ignition on same time press open button on handheld remote and on the car button 30 sec and it should be programmed.
Posted on May 18, 2009
SOURCE: programming the garage door opener
Homelink Garage Door Opener Programming Procedure:
The procedure described below was successfully applied to a 2005 Jaguar S-Type.
To begin with, several attempts were made using the programming instructions contained in my Jaguars owners manual. Though the procedure described in the owners manual was straight-forward and understandable, I was unsuccessful in getting the vehicles remote to make my garage door opener function. The particular garage door openers I have are both made by Genie. Both openers utilize the Rolling Code feature.
To begin with, be sure to clear previous codes on your Jaguars garage door opener by first turning (rotating) the ignition key to the I position (first notch). Next, simultaneously hold button 1 (left most button) and button 3 (right most button) down until the middle buttons red light changes from continuous on to a rapid flash. This process takes approximately 20-25 seconds. What follows is a two part process. In the first part, get your Genie portable remote and hold it near (approximately 3 inches away from) your Jaguars garage door opener console buttons. Choose which button on your Jaguars remote you wish to dedicate to your Genie door opener and simultaneously press and hold your Genie opener button and your Jaguars opener button. The red light on your Jaguars center button (button #2) will light up and within 1-2 seconds will begin to flash rapidly. You have just completed part 1 of the two part process.
Part two: Now it is time to utilize the Learn function on your Genie garage door opener. Press the Learn button on your Genie garage door opener. The red LED adjacent to the Learn button will begin to flash. You now have 30 seconds in which to program your Jaguars opener button. Using the same button you just used in the part 1 procedure, press and hold the same button for several seconds. As before, your Jaguars red light in the middle button will light up and within 1-2 seconds, it will flash rapidly. Release the button you are programming. Now, here is the key piece of information! Once again, press and hold that same button. Once again, the center buttons red light will flash rapidly. Release your newly programmed button. This procedure proved successful in my application. Here is what has just happened. The first time you pressed your Jaguars remote button tells the Genie opener that it exists and that it is a viable candidate for making your life easier (opening the damn door). The second time you press your Jaguars remote button confirms to the Genies rolling code that your Jaguars signal is legitimate and is to be trusted from then on.
Posted on Dec 23, 2009
How do I program the garage door opener receiver on the garage after programming the garage door openner on the vehicle?
after you do the programing for the car you have to go back to the opener and press your learn button once. Then go back to your car and press and HOLD the button you just programmed your should see your light bulb blink on your opener after about a second or two.
Jan 27, 2015 | Building Materials
Cant get into garage.neither opener will work and keypad just blinks over and over when i try to change code or use current code
You cannot change the code on the keypad without first entering the garage. Sounds to me like the receiver has quit working. It is a part of the logic board. If the large door is the only entrance to the garage you will have to call a door company. They can get you in by drilling a hole in the door and using a special tool to pull the manual release.
Mar 09, 2011 | Sears Craftsman LiftMaster Chamberlain...
Somehow my garage door Sensors (at the bottom of door opening) had debris which caused the Sears Door to go down and then go back up. I carefully removed the debris and now the door is stuck in the down...
There isn't a way to bypass the remote. If you call out a door technician he can drill a hole in the door and use a tool to pull the release handle. They can then install an emergency release using the hole they drilled. This will prevent the problem you are having in the future which is not as uncommon as it may seem Every time you have a power outage you are unable to get into your garage.
Sep 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door will only close with keypad code it will not open
Mar 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
3 bootons on the key opens both garage door at same time
Reprogram one at a time with others power no programming will be received...pretty simple.
Mar 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman garage door keypad
The blinking on your keypad simply means that a code of some sort was sent. Whether it be the right on or not. Lets try to reprogram the unit. Press the colored learn button on the motor head and then within 30 seconds enter in the 4 digit code followed by the up/down action button. The light bulb should flash to let you know it has been accepted. Wait 5 minutes and try. If it does not work replace the keypad.
Jul 17, 2008 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
169 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
