Question about Grilling
Where is the battery located on this grill?
For a Maxfire 2 burner grill
  • 10,045 Answers
No battery. The igniters are piezo style that doesn't use batteries. If it has failed, you can get a replacement at any store that sells BBQ grilles or home improvement stores.
Posted on May 04, 2017
None of the materials I received with my Char-broil Model 463270611 include an illustration of the gas knobs and the meaning of the symbols they display. Can anyone help?
After reviewing the Owners Manual for your grill, I see it has only 2- burners and possibly electronic ignition and an optional side burner (if you have the kicked up model). This grill is not difficult to operate, as it only has 2-burners, which translated into 2- burner knobs, which control the lighting of the burners and the flame height adjustment, once the burner(s) are lit.
But, as they say, "One picture is worth a thousand words". So I am providing a link to your model grill, that not only has the Owners Manual link, but also links on how to use, operate and cook on a gas grill. In fact, there are a couple of videos you might find of interest.
http://www.charbroil.com/ProductSupport/463270611/Quantum-Infrared-Urban-Grill.aspx
Be safe and enjoy your grill.
May 10, 2011 | Char-Broil 463232103 Grill
I have a stainless steel grill. The Rotisserie will light, but the burners will not. I purchased the grill in 2005.I have taken the grill apart and the tubes are clear. There is NO spark going to them. I...
The ignitor wire to the burners my have come loose or has lost full contact. Trace the wiring from the Ignitor Button to the main burners. Note if it loose or has come completely off. Also, check inside the grill at each burner to see if the ingnitors are covered with grease. If that's the case, clean them with alcohol and either a rag or a cotton ball. If all this fails to solve your problem, change the battery in the Ignitor Button with a brand new Alkaline type battery.
Hope this helps solve your problem. Happy Grilling!
Feb 12, 2011 | Ducane 30400040 Stainless Steel Grill
First two burners work fine but when I turn on third burner (back) it cuts out the whole grill on the Weber genesis
This is very common with faulty regulators. The regulator is located on the hose (it is a metal silver disc located at the end of the hose where the hose attaches to the propane tank.)
To replace the hose and regulator, you need to detach the hose from the grill. Your local grill store should have replacement hose and regulators.
Hope this helps.
-Ben
Tanks 2 You Propane
propanetanks2you.com
Jan 27, 2011 | Weber Genesis Silver B Grill
I now have a 3 burner weber gas grill and am thinking of buying a 2 burner weber gas grill - how do you use indirect cooking on the 2 burner grill - will there be one burner that is turned off under the...
Well, I personally, wouldn't want to go from a 3-burner to a 2-burner because I think Weber designed the 3-burner grill to perfection, and as you know, all you have to do is turn off the middle burner.
At any rate, indirect is harder with the two-burner because of the placement of the burners. You can try to put some 1" thick ceramic bricks directly on the flavorizer bars in the middle, or if you are using a rotisserie, put a pan under your meat.
Aug 06, 2010 | Weber Genesis Silver B Grill
Genius maxfire g-08xu game controller
yes it can all u have to do is plug it and start playing iv tried it my self
May 28, 2010 | Genius MaxFire G-08XU GamePad
How do I install replacement burners for my Charmglow 720-0036-hd-05 grill
Replacing Burners on Charmglow 720-0036-HD-05.
1. Disconnect the gas line to the "side burner".
2. Remove the two "side shelves", each of which is held on by 4 large phillips screws.
3. Remove the "control panel" that is held on by two smaller phillips screws at each side of the "control panel".
4. Remove the "front baffle" located directly behind the "control panel that is held on by 4 phillips screws.
5. Lift off the "cooking grills" and the "flame tamers" (the plates over the burners) so that you can see the burners.
6. Now you can slide each of the burners forward and then left them out of the grill.
Replace everything in the reverse order.
Apr 07, 2010 | Grilling
New brinkman gas grill---side burner lights on ignition control but main burners do not light with ignition control---am able to match light the main burners----any ideas anybody
Clean or replace the main igniter. The backs corrode and need to be cleaned or replaced. Home Depot carry replacement parts.
Apr 25, 2009 | Grilling
Viking grill will not light but the burners are working
Do the igniters spark?
Have you replaced the batteries in the spark modules, they arer located behind the drip tray at either side of the unit?
Jan 19, 2009 | Viking DVGBQ532-3RTL (LP) All-in-One Grill...
Burner replacement on Ducane 30400040
Remove the 2 grill wire cooking racks by lifting them out of the top of the grill, next lift out to remove the 3 heat deflector panels which exposes the 3 burner tubes. Remove the 4 screws located on the outside flanks (2 on each side) of the 5-knob control panel assembly - then gently slide the knob control assembly outward and away from the grill just about an inch or two. You can now remove the old burner tubes and replace them with the new units. Then simply slide the control assembly back into the grill frame and replace/tighten the 4 screws. Voila`
Jul 04, 2008 | Ducane 30400040 Stainless Steel Grill
Grilling Logo
158 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
