Question about Air Tools & Compressors
Manual for mech 90002 air compressor - Air Tools & Compressors
    Top Expert:
  • 44,045 Answers
Try Googling (mech)(90002)(manual) without parens.
Posted on May 04, 2017
Mech. Asked me to change AC condenser&valve to solve lose of AC air after 30mins drive as I found AC clutch stop rotating,he told me due to high temp of compressor;sensor Disconnect to save't.shall I?
So you used a vacuum pump to evacuate the system and did everything according to standard? The compressor stops because the Freon is lost.
Jun 11, 2016 | AC Cars & Trucks
I have a mech power 2hp twin tank air compressor..m90002. It only generates to 120psi then shuts off. Can I get it to go up to 150psi? If so how? Thanks
It is what the max pressure is to handle before the safety valve can have if it concept is for 10 bar then you have a 10.5 bar safety valve or if its 8 bar its 8. . 8.5 look at the tank itself its in most case there you can read what it can handle.
May 18, 2016 | Air Tools & Compressors
Looking for manual for sanborn B51-A24-80V1 model
PDF]Sanborn Black Max 5hp Air Compressor Manual B51 A24 80 1
intrigante35hindu.strictlyyouth.org/rzsatzo_sanborn-black-max-5hp-air-...
Jul 16, 2015 - Sanborn Black Max 5hp Air Compressor Manual B51 A24 80 1 ... Black Max Portable Air Compressor - 5 gallon Item #: 81527 ' Model #: BS0880504 ...Compressor Manual: $4.95: Buy Now: B51-AT24-80V,B51-A24-80V1.
Aug 28, 2015 | Air Tools & Compressors
Can you replace the pulley on the airconitioner compressor without replacing the compressor
There is no pulley on the air conditioner compressor. There is one on the fan motor
Aug 19, 2014 | Sharp AF-S60RX 6,000 Cooling Capacity BTU...
AC blowinghot air
Locate wires coming from compressor clutch and trace to nearest plug that you can unplug. Turn on A/C to max cooling. If clutch not engaged (center of compressor drive pulley not spinning with pulley), unplug compressor clutch wires and use multimeter to check voltage going to compressor clutch. If voltage is around 12 volts or more, then clutch should be engaged when plugged in. Plug clutch wires back in (with motor still running and ac set to max). If clutch still not engaged, then clutch definitely bad because 12V signal should engage it.
May 08, 2010 | 2002 Lincoln LS
Air springs not receiving air out of solonoids
I had the same problem. i even went as far as to have a shop convert it over to regular springs in the back. but before they did it their mech. checked it out and it was only bad fittings to the rear bags. Mt advice is lift the back of your car and check them. if you cant (like myself) take it to a shop you trust and have them check it out. my shop only charged me 1 hour labor and nothing for the parts. happy hunting
May 08, 2009 | 1991 Lincoln Town Car
A/C compressor on a 1998 Ford Explorer XLT 5.0 V8 not engaging.
Low pressure in the system and the clutch will not engage. The low pressure sensor is on it for a reason.
Apr 27, 2009 | 1998 Ford Explorer
Refrig. Problem
have you checked the start relay ?
Sep 03, 2008 | Whirlpool GC5SHEXNS Side by Side...
Air Tools & Compressors Logo
126 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
