Question about Marantz Audio Players & Recorders
I have a Marantz SR-96 THX receiver, which sounded powerful and sweet up until 6 months ago. The right front channel now sounds crackly & scratchy in the mid-high area... I nearly replaced my whole front audio speakers but, I tried another amp from a mate and they sounded great again. So the problem points to the right output stage. Is it the caps or pre-amps? or something else.?
jack_daniels
  • 304 Answers
SOURCE: No Sound in Right Front Speaker- Denon AVR-1508
hi there,
have you check the system settings for each of the speaker..? should be set and balance all output of the speaker
`jack
Posted on May 24, 2008
SOURCE: Marantz sr 500 going to "protect" mode when on.
Change the audio amplifiers IC´s because are on short circuit
Posted on Oct 02, 2008
  • 4234 Answers
SOURCE: no audio output - Marantz 2238
This can be as simple as a poor connection somwhere in the voltage regulator circuit or a defective driver transistor or output transistor. In any case, this is a simple repair for any shop that works on vintage receivers. If it is the outputs, that will be the most expensive repair from a parts perspective. The outputs will cost in the $5-$10 range for each one and it could be 2-4 pieces. If you wish to attempt this repair yourself, you will need a multimeter that has a diode checker. Let me know and I'll provide additional details and instructions.
Dan
Posted on Apr 06, 2009
mlapres
  • 757 Answers
SOURCE: Pioneer audio receiver pre-amp output
It is possible then that the root cause may not be electrical, but acoustic if you're noticing the issue from your listening position.
If you can run a channel test signal identically one channel at a time by positioning your meter less than a foot away and exactly the same distance with each speaker and the level differs by more than 1/2dB, then it's not the acoustics.
Posted on Dec 24, 2009
  • 3 Answers
SOURCE: my Marantz sr 4001 receiver has no output. Is
my friend has the same problem with an SR 4001. the tech said it was an internal fuse soldered to the board. the display showed an error code that clued in the tech of the problem. I am trying to find the fuse on the board, and trying to get a value(Volts-amps) of the fuse
Posted on Jul 28, 2010
I am not getting sound from the marantz 5009 receiver to the tv. I am using hdmi cables from receiver to the tv
Huh? why? would you not want to get sound from the lousy TV speaker to the receiver and it speakers instead? That's how I have my Onkyo THX system set-up. My Samsung TV actually has decent speakers but even they are junk compared to a real speaker system. Even $500 worth of real speakers can sound better then the speakers on a $5000 TV. Do not do it.
Apr 16, 2015 | Marantz SR-5009 7.2 channel home theater...
Marantz SR-18 NO Sound No Data error for DSS (Directv) only
You need to check the connection of the lead that carries the audio from the DSS to the amp, move it to one of the other channels ie vcr and see if it can be heard when set to and switched to vcr. Then we know if we are dealing with the Amp or the source..
Dec 23, 2007 | Marantz SR-18EX Receiver
Marantz a/v reciever sr-96 users manual i canot find it.
I found a partial copy, first 9 pages in pdf format. if you want it can email me here:
nasa.info@mail.com
Dec 17, 2014 | Marantz Sr-96,dp870, And Rc2000 Packa 5.1...
I want to connect my bravia lcd to my marantz sr770 i can only get two chanel sound from my two front spearker i cant get the surround working
Let's break this into little pieces. Disregarding the TV, does the Marantz otherwise provide multichannel sound?
How is the TV-related audio getting into the Marantz? Analog RCA yields only 2-channel audio.
Two front speakers are only capable of two channel sound.
Jan 24, 2011 | Marantz SR-770
What would work better for Marantz SR 4200 Apple Composite or component cable? In order to play music through the amp as well as watching videos
Component Video is a big step up the food chain in quality. Component Video inputs are for video only, not for audio. I don't see Component Video inputs on the Marantz SR-4200; only Composite and S-Video. S-video would be a step up from Composite and it carries analog stereo sound.
You don't give any clues as to the source's audio capabilities.
Digital Audio of either flavor is preferable. Grab the best possible TV-related audio from your Cable/Satellite box to the Marantz and run a pair of RCA audio cables to your TV just in case you want to watch the weather channel without hi-fi sound.
Mar 18, 2010 | Marantz SR-4200 Receiver
Center channel goes muffled after a while of use.
It is likely that something overheating is causing the problem, but nothing should be overheating. Cleaning won't hurt and may help but it is likely to require repair of the faulty component, perhaps a failing capacitor or amplifier.
Dec 29, 2008 | Marantz SR-19 Receiver
SR4300 Centre Channel
Hi...
Try another GOOD speaker on your centre channel.
If the buzz ....buzzes off, it's a bad speaker.
If not , It's in the power amp section on the unit.
Sep 14, 2007 | Marantz SR-4300 Receiver
No output from left channel after crackling sound
Marantz SR 5200/6200 lost audio or crackling on left or right channel except in mode s-direct is now fixed !
The root cause is a defective inegrated circuit on DSP board (the one with digital inputs). To fix it change the chip CS4391 by a new one or better by the improved version CS4392. On my device a capacitor was cut close to this IC : replace one 1uF after changing the IC. For any question search me with my callsing "F5RCT"; i have a spare IC for the one who is able to change it !
I'm amateur radio and engineer
Jul 08, 2007 | Marantz SR-4200 Receiver
Marantz SR 7200
It is likely that the PA stage has developed an offset voltage in the output stage. The faulty amplifier channel can be found by progressively disconnecting the collectors of the of the power transistors until the protection fault disappears. Once the faulty channel is found the the cause of the offset has to be traced to the faulty transistor or resistor. Don't forget that if you can smell smoke or burning then there are likely to be components(esp transistors) that have been damaged by the fault.
I had a Luxman unit that destroyed 5 transistors in the output stage that was due to an open .5W resistor in the driver stage.
Good luck.
Jan 29, 2007 | Marantz SR-7200 Receiver
806 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
