5130 stopped working
Neither remote or the switch on heater will not work
My heater suddenly stopped working with my remote. Heater says remote no demand
if no demand maybe bad temp sensor disconnect heater connect firemans switch or take it out of t stat if runs on its own bad temp sensor for system if same error bad temp sensor on heater replace
Jul 14, 2015 | Raypak Pool & Spa
My heater fan won't work when car remotely started with Bulldog remote starter
The yellow wire at the ignition switch is not connected to the remote start system. Once it is connected to the accessory output of the remote start, it should work properly.
Jan 08, 2013 | Remote Starter with Keyless Entry
When my truck start with remote starter my heater does not work
Whoever wired the remote starter didn't wire one of the output wires to the wire from the ignition switch that goes to the heater controls.
Sep 06, 2011 | Chevrolet C1500 Cars & Trucks
I have an Optimus radiant heater dish with the remote control. I love it, but it's broken. It will not turn on. It is fairly new. What can I do to repair it?
It may be the remote control. Have you tried operating the heater without the remote? If you haven't give it a try. This will tell you if the problem is with the remote of not. If works without using the remote, the remote may need new, fresh batteries. If that doesn't solve the problem, turn OFF the Master Switch on the heater to OFF. Unplug the heater and wait 12 to 15 minutes before plugging it back in.
Turn the Master Switch on the heater ON. And try operating it. Hopefully, that time out, gave it enough time to reset itself.
Mar 18, 2011 | Optimus H-4436 Electric Heater
My new rieker fan stopped blowing heat- the fan works --not the heater
I had the same problem with my fan and solved it with a reset. The reset button is on the back of the remote next to the dip switches. You have to take the battery cover off to see it.
Turn on the fan with heat, even though the heat doesn't work. Then, leaving the remote on, turn off the fan at the wall switch (or circuit breaker box). Wait a few minutes. Then turn on the power and within 30 seconds, press the reset button. You should be able to see a countdown from 5 to 0 on the remote screen.
Once I did this the heat started working again.
Jan 05, 2011 | Reiker Ceiling Fan/Heater Combo Utility
NEED AN ON OFF SWICH FOR A TWINSTAR ELECTRIC FIREPLACE HEATER SWITCH PART NUMKBER IS SR22N
If your On-Off is not working ? Go to GRAINGER and get Light Rocker Switch SPST,3 connections 2VLN1 or the Light Rocker Switch SPST, connections 1A824
both will do the job.
Nov 12, 2010 | Leisure HOMEPRIDE Electric Fireplace...
Heater doesn't work right
You will need to consult your directions or your owners manuel.Their are probally dip switches that need to be set for remote so the heater can communicate with your remote. These will be small switches on your board that you will need a knife point or smaller to switch. They should be marked but get your glasses out to read them. good luck
Nov 30, 2009 | Pool & Spa
I cannote get my remote to operate the fireplace. I have installed 3 new batteries and it still does not work.
The remotes are often a problem...I would advise against repairing it....sometimes the sensor for the vent isn't visible enough for the remote...the wires or sensor can be melted....The best/cheapest solution is to run a wire from the same two contacts the remote sensor are hooked up to on the gas valve...and install a switch on the wall....Turn the fireplace on with the flick of a switch....a Thermostat can also be connected to operate the fireplace using the same contacts as the remote
Oct 26, 2009 | Desa International Unvented Gas Space...
Heater and lights not working
i to have an oldsmobile intrigue mine is a 2001 i heard remote starts can really mess a car up this one is tricky **** it could be bad wiring since the remote start have your wiring looked at then if needs replacing replace it fast before any more problems occor
Dec 20, 2008 | 2002 Oldsmobile Intrigue
Reiker ''room conditioner'' heater stopped working
i have of course the same problem......5 times now in 3 years.
i have discovered that for some reason if i disconnect the fan and put it back up it works again for another 8 months or so.
Nov 16, 2008 | Reiker Room Conditioner Ceiling Fan with...
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
