Question about Maytag Washing Machines
Maytag 4000 front load washer displays F28 - Maytag Washing Machines
What is f28 error code on may tag 4000 washer.
Google Maytag error codes .or contact maytag or go see a dealer of maytag Durable Kitchen Laundry Appliances Maytag
Dec 05, 2016 | Washing Machines
It starts and then stops and then F28 flashes
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3708-whirlpool-washing-machine-fault-codes.html
Not good! Probably motor control board or motor or wiring harness from control board to motor.
This leads to a Kenmore Video
Whirlpool, Maytag, Kenmore. Same machine different name different trim.
Whirlpool Duet f28 YouTube
Sep 21, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Error Code F24 Maytag 4000 Series Front Load Washer
This video will show you how to open your Maytag 4000 series washing machine door that is stuck shut
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 04, 2013 | Washing Machines
F28 code on a whirlpool duet sport model # wfw8300sw03
There is also a safety switch on the bottom compartment, if the cover is off it will display F28.
Aug 11, 2012 | Kenmore HE2 Plus Front Load Washer
My Maytag washer has a flashing F 15. What does that mean?
The following list of codes indicates an electronics communication problem with the washer: * EpicĀ® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
* Epic ZTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Hope this helps.
Jun 24, 2011 | Maytag EPIC MFW9700S Front Load Washer
F28 error / water starts to fill then quits in 15 sec's
F28 is a communication error which usually means there is a connection that has come loose.Check the wires on the control board.
Nov 22, 2010 | Maytag EPIC MFW9700S Front Load Washer
I just purchased a floor model Maytag Epic Z front loading washer and it's giving me the error code F28, What does that mean?
hi there,
you may have a shorted thermistor.
can you tell me when this problem happens?
also, can you provide me with a complete model #?
thanks
Sep 27, 2008 | Maytag Washing Machines
Washing Machines Logo
37 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
