Question about Samsung Dryers
Samsung dryer runs and runs on sensor settings.
I have Samsung gas dryer model DV410. no heat, replaced two thermal fuse and hi low limit. Now it only works with timed cycle mode. the rest mode, it runs only for least the 5 minutes and shut off.
timed cycle mean dryer not on sensor dry mode. check wire connection on moisture sensor bars (i think you forget to put 2 wire connector put together). when you use other cycle dryer use moisture sensor to dry cloths so sensor not working dryer will stop in 5 minutes or so because dryer think there are no wet cloths to dry. hope this help you.
May 02, 2017 | Samsung Dryers
Samsung gas dryer takes to long to dry
long drying is usually due to a bad venting set up or a bad moister
sensor, a bad cycling thermostat? it is constantly
running though right? if not a bad safety valve and coils can causit to go off and on and not dry well.
Sep 08, 2014 | Samsung DV218AG Gas Dryer
Samsung DV5451AEW electric dryer will not heat up when on any of the "automatic" modes. The dryer dries perfectly when set to a time dry, so it's heating up, but it will not dry when set to normal, heavy...
I would recommend calling a technician. Could be as you said a bad sensor. Make sure the sensor bars are clean. Use an alcohol pad or cloth and clean them.
Sep 26, 2013 | Samsung White Dryer Dv5451aew/xaa
Dryer starts but shuts off after a minute, and only does it on sensor dry
Clean the gunk off the sensors where they can sense wetness is what I would try
Samsung dryer
Oct 20, 2012 | Samsung Dryers
DV448AEP sensor drying doesn't seem to work
I had the same problem with mine. My wrinkle free setting some how got turned off. As soon as I turned that back on machine kept running and dried the clothes fine.
Feb 19, 2009 | Samsung DV448AEE Electric Dryer
DRYER RACK DOES NOT DRY CLOTHES
try timed dry cycle instead of the auto-sensing setting. In your drum if you have auto dry such as less dry normal dry and more dry, There is a sensor sometimes in the drum and sometimes in the exhaust right after the blower. If in the drum then your clothes brush by this and if moisture is sensed then it keeps on drying. With your rack the clothes can't touch the sensor so it tells your dial to turn and that items are dry which in fact are not. Try this and see how it does.
Feb 17, 2009 | Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer...
Dryers Logo
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
