Question about Sharp Office Equipment & Supplies
Sharp mx-m453 toner replenishment in progress how to solve this problem
3 Suggested Answers
  • 148 Answers
SOURCE: F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
Posted on May 26, 2008
  • 31 Answers
SOURCE: "TONER REPLENISHMENT IN PROGRESS
please remove the waste toner stored in the waste toner content box
Posted on Jan 12, 2011
Sharp copier Mx 5000N is doing continuous toner replenishment I changed toner cartridge drum developer still replenishment what do I do
If the machine is still trying to add toner after the toner cartridge has been replaced & the developer is new then I would look at the toner supply motor for that particular colour. Also check for a blockage within the small tube between the toner cartridge & the developer unit. You could try swapping the toner supply motor with one of the other colour motors as they are all identical. If the fault switches to another colour then the motor is at fault.
You can also check the operation of the toner motor in simulation 10.
Hope this helps.
Dave.
Jan 09, 2017 | Sharp Office Equipment & Supplies
Error code F2-40 in Sharp mx m314n photocopier
using third party toner or drum replace toner and drum with OEM
Jun 04, 2015 | Sharp MX-M314N Copier
What is code F2-40in a MX-M264N Copier?
F2-40 = ATC sensor abnormality ,
your toner is depleted , or is unable to replenish toner level in developer after X amount of time . a simple crop 14 should clear the error , but if it persists then you have bigger issues , try to check developer unit gears if they still function as they should, and check your toner level, and check your toner motor,
and if all is said and done try another toner cartridge, but be aware that the F2-40 usually fries the chip on the toner cartridge (not always though)
Jan 22, 2015 | Sharp MX-M264N Copier: MX264N : M264N
After powering on, it will show F2 on the Sharp SF 2540 Copier, So please, I need a programme code to clear it or any other solutions to solve it problem
You need to take it to a Sharp technician to check machine , usually a toner issue that toner is unable to replenish in developer unit and so blows the chip on toner cartridge ,
replacing toner cartridge rarely helps
seeing as it is a deeper issue
Sep 12, 2013 | Sharp SF 2540 Copier
Jan 11, 2011 | Sharp AR-275 Copier
Code F2:72
F2:72 is for Toner cartridge improper cartridge detection (MAGENTA).
Check and see if the right toner cartridge is installed. If it is the proper cartridge I would suggest placing a service call.
Oct 12, 2010 | Sharp MX-2700N Color Copier
F2-02 Error on Imagistics ZB35 machine
Sharp AR-5620N getting f-2 error. What is the solution
Mar 03, 2009 | Sharp AR-M237 Copier
Shart AR-M208N Toner Replenishing
Have you removed the seal from the toner before installing it in the machine? If so, make sure it's all removed. If that looks ok there may be a problem with your machine.
The 208 is a fairly new machine, you might still have warranty on it. I'd check with Sharp or with the company you bought it from for repair info.
Oct 15, 2008 | Sharp AR-M208N Copier
May 23, 2008 | Sharp AR-M237 Copier
24 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
