Question about Toshiba Office Equipment & Supplies
Need to reset toshiba 4520c to factory settings
No matter what I try, the Toshiba 4520c print margins are wrong. I'm trying to print with the smallest margin on all sides of the paper in a 2-sided print. However, two sides will be perfect at the .167 margin, while the other two sides have margins of .5. For the life of me, no matter how I change the Publisher or PDF file, the margins won't budge. HELP! :)
Delphi51
  • 33 Answers
SOURCE: paper margin problem in pagemaker application
Do you mean the left margin is too large so all the content is shifted to the right and off the page? If this is the case, it is probably a setting in Pagemaker. In the file menu, choose "page setup" or "print setup". Check the paper size. Check the margins.
Posted on Sep 10, 2007
Blue Hammer
  • 167 Answers
SOURCE: Margin printing problems
Check your application's print settings (for e.g. MS Word). Then check the printer's properties and print settings. If nothing works you also try re-installing the latest printer driver. If you use MS word should check the page setup option, for paper size errrors. If the color of your margin is red and the red ink is out then you won't se the margin line.
Posted on Oct 09, 2007
  • 70 Answers
SOURCE: Blue lines all over the printing
Did u clean the print nozzle's as well? If that does not solve your problem, you should try and replace the cartridge. (Colour in case of blue lines and black in case of black lines)
Posted on Dec 20, 2007
  • 2072 Answers
SOURCE: Print margins too large on Xerox DocuColor 12 - How do I reset?
Not sure this is what your needing but ,,
The Edge Erase default setting is No Erase, which enables the copies to print within 2 mm of each page edge. This is normally sufficient to remove shadows from the edges. If the dark edge is closer than 2 mm, you must set Edge Erase at Variable Erase.
The Variable Erase option enables the copier / printer to vary the amount of erasure from 0 to 50 mm in 1 mm increments. The same amount of erasure is applied to both top and bottom edges or right and left edges of the document.
  1. Select [Edge Erase] on the Added Features tab. The Edge Erase screen is displayed.
  2. Select [Variable Erase]. The Variable Erase screen is displayed.
  3. Under Top & Bottom Edges, use the [Up] arrow to increase the amount of erasure at the top and bottom edges. Use the [Down] arrow to decrease the amount of erasure at the top and bottom edges.
  4. Under Left & Right Edges, use the [Up] arrow to increase the amount of erasure at the left and right edges. Use the [Down] arrow to decrease the amount of erasure at the left and right edges.
  5. Under Original Orientation select the page orientation that most closely resembles the orientation of the document on the Document Glass.
  6. Select [Save]. The Edge Erase screen is displayed.
  7. Select [Save]. The Added Features tab is displayed and shows the new Edge Erase values.
Posted on Feb 13, 2008
  • 25 Answers
SOURCE: Lexmark E232
If this model has separate toner and photoconductor then the photoconductor is at end of life and needs to be replaced. Follow the directions that come in the new photoconductor package to install and reset the PC count this is important.
Luck
Posted on Mar 11, 2008
Toshiba e-studio 305 copies are cut off how can we reset margin
margins are set from the software doing the printing
look at print options and print preview before you print
Nov 16, 2016 | Toshiba Office Equipment & Supplies
Need to reset administrator password for toshiba a200-1vo
To get Windows Administrator password reset can be a little trouble if you don't have a prepared Windows password reset disk. In this case, you 'd better choose a powerful and safe password reset application like Windows Login Recovery. It is not recommended to re-install your system. 8d68d702-98b7-49df-8562-88a2dafeec12.jpg
Nov 12, 2012 | Toshiba Computers & Internet
Faint lines
Try replacing the roller, or maybe you moved it and is not in place- in the exact position.
Jun 29, 2012 | Toshiba E Studio 3520c 3530c 4520c Copier...
Hello, I have Toshiba P305D-S8900. My son was playing some games on the computer. The screen display automatically changed to really bright. I am not able to reset it no matter what I try. I uninstalled...
hold fn key and tap f8 decrease brightness
hold fn key and tap f7 increase brightness
last resort
to restore to factory defaults
turn off computer hold the zero key turn on computer
should boot to factory reset menu, this will erase your data
May 22, 2017 | Toshiba Satellite P305D-S8900 Notebook
We have a Toshiba 4520c copier that beeps while printing jobs
My Toshiba vendor indicates that this is a "feature" and NOT a bug (we haven't signed, so incentive to find an explanation is high). He says that the beeping is to alert you that you've left something on the glass or the document feeder. Likely, this would happen if a sensor is going bad. Look for the toll-free number on the sticker, and the Unit code, call them and tell them to send a tech to fix your bad sensor, no need to bother IT, we usually have bigger fish to fry, especially in this economy.
Feb 03, 2010 | Toshiba Office Equipment & Supplies
THIS IS NOT AN ISSUE WITH MY MARGINS. I have Microsoft word 2007, an HP Officejet Pro 8500 Premier and windows vista. After some research I found a commonality with my problem and these three operating...
The problem may lie in the printers setting for the margins. Do you set the margins only in word 2007 or do you check the printers margins too?
Also the issue may lie with the printer having the incorrect paper size
Have a look in the printer properties (When you go to print, its beside the printer selected) and look through there and see if there are any issues.
Dec 02, 2009 | Toshiba Satellite P205D-S7454 Notebook
48 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
