Question about Moen Home
I have a moen hand hand held bathroom shower arm sprayer and head. I am in need of the suction cup piece that holds the arm to the shower wall. Where can I find that piece
  • 8 Answers
SOURCE: bathroom stall shower
Most handheld showers use a hose to connect from the existing shower arm down to the hand held option.  Some units come with attachment points on the shower arm, but I believe that you are looking for a unit that has a hook that you can mount where ever is comfortable for you.
Posted on Oct 16, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: WHY SHOWER HEAD WILL NOT STICK
Make sure you clean and dry the wall that you are sticking the shower head to. It is OK for water to touch the exterior, but not the interior. Also, make sure there is no cracking or degradation of the suction cup. Also, this is posted in the wrong section.
-Tha Mp3 Doctor
Posted on Jan 09, 2009
  • 1044 Answers
SOURCE: shower - Rain head won't turn off so hand held can be used solo.
Probably the fitting is not working properly. Please change the fitting.
Posted on Apr 17, 2010
  • 118 Answers
SOURCE: Hi, the acrylic piece that holds
lowes has a replacement
Posted on Dec 05, 2010
  • 82 Answers
SOURCE: Moen model 3867 has a
recheck all the washers and try a little teflon tape if necessary
Posted on Dec 09, 2010
Clubmaster shower not holding temperature. Hot water not coming through.
There's only there things that are clubmaster, a shower head, and two hand held sprayers.
They all spray water, they don't heat water.
Did someone install a new part, the one that's behind the wall ?
If they did, most have a safety so people don't get burnt and they need to be adjusted.
Apr 16, 2013 | Hansgrohe Clubmaster Showerhead, Steel
The suction cups on my oil rubbed bronze soap dish are no longer tight enough to sick to the wall of my shower. it's been fine for over two years until now. can you buy new suction pieces or do i have...
Sometimes this happens when the suction cups are somewhat dirty.
Wet the suction cups, leave for some time, and wipe with a clean cloth until the suction side is shiny. If it is not shiny at places that suggest those places are not cleaned thoroughly. Wet again and wipe again until you get a shiny surface.
Check the wall where it was attached. If you see any patches wet the area and wipe with a clean cloth.
You can apply just a tad bit of oil (I use coconut oil) to the suction cups.
Try this - and let us know the results.
Thanks for using FixYa!
Sep 05, 2011 | Allied Brass Soap Dish - 432.ORB - Oil...
I have a Moen shower faucet that is six years old(copper sweated plumbing). My wife noticed water dripping profusely from the downstairs ceiling during my shower. The screws holding the face plate were...
Try removing the handle, then the face plate. With a flashlight handy, check inside the wall around the valve to see if you see any leaks. Then, try the valve by pulling the stem (may need a plier to grab this). Keep checking inside the wall. Next, try the shower, and again watch in the hole you have. You may find that the connection(s) to the valve is/are leaking, particularly at the top of the valve where the shower pipe heads up the wall. Or, it may be that the shower head's arm is leaking somewhere above. If you only see water dripping down from above, try the flashlight with a small make-up mirror to see if you can see where it's coming from. Sometimes the pressure in the shower head builds up from the flow restrictor, or the head's spray holes may need cleaning out (try soaking the head in a solution of CLR [stands for Calcium, Lime, Rust] available at most home improvement/ hardware stores). Sometimes the shower arm (the bent 1/2" diameter pipe that the shower head mounts to) isn't fastened in tightly enough. A good trick to help here is to wrap the threads with teflon tape, then apply teflon paste also. Wrap the tape clockwise around the threads so that it doesn't unwrap when you screw the pipe back into the fitting in the wall. Also, make sure the threads in the fitting in the wall are cleaned out, and don't let any debris contaminate the new teflon paste as you slip it back through the hole in the wall. If you find that the pipe out of the top of the valve is leaking, I recommend you call the plumber. He/she can likely fix it without taking the wall apart.
Aug 27, 2010 | Moen & One Handle Tub & Shower Faucet
Flow restrictors
Remove the shower head from the arm and look inside the connector on the showerhead. You should see a plastic or metal piece that will either unscrew or need to be pulled out with needle nose pliers. Once that's been removed the flow should be improved.
Apr 19, 2010 | Moen & One Handle Tub & Shower Faucet
Moen Hand Shower repair
  2. start unthreading centre of head. I used a paint scraper to leverage at first. The threads get loose soon to hand loosen.0588438c-31ce-4428-9378-28140fa37adb.jpg
  3. loosen the spray ring using a lever to get threads started. Hand loosen after that.It's got right hand thread so the outer ring will be turning counter clockwise.3e2cc1ab-35f5-4521-a05f-e1167596fb04.jpg
  4. Take flat rubber gasket out of centre of head and take screw out, then pry white nylon part out with tool. I used tweezer.a1f4f121-e0e1-450a-a9b8-8777342a3262.jpg
  5. Clean scraped parts in hot CLR solution or any vinegar will work as well. Reassemble with lubricant so it works like new. Most likely need for disassembly is clogging or a broken "o"-ring.6fff7106-1b7b-4330-a3c6-089ea42233cf.jpg
Apr 13, 2010 | Moen 3867 Four Function Hand Shower With...
Our shower has not been used for a while. Now when we turn it on
Do you have good flow if you remove the shower head, y/n if not how old is house,galvinized plumbing?? or copper plumbing. Sounds like you have a clogged valve and if so this link will be good.
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Thanks and Please Rate jj505
Apr 02, 2009 | Moen 3175 Legend One Handle Shower Faucet...
-Tha Mp3 Doctor
Dec 28, 2008 | Cuisinart DCC-1200 Coffee Maker
Bathroom stall shower
Oct 16, 2008 | Home
Home Logo
29 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
