Question about Ovens
My Dimension 4 Genius made a dzzzzzt sound when start button pressed, a burning smell emitted from the right side of the oven. It ran, but no heat and then the front panel LCD display went off.
Can you possibly indicate what component has failed, please
SOURCE: oven failed to work; F5 error message
please tell about the make & serial no. of oven.
Posted on Sep 30, 2007
  • 213 Answers
SOURCE: GE JRS04BOW3BB Will not turn on.
turn the broil on high by itself wait a couple min. and see if it comes on. if it does the your bake element needs to be replaced or you may just have a burned wire where the bake element plugs in. just remember to turn the breaker off to the oven before trying to pull out the element
Posted on Nov 25, 2007
  • 1314 Answers
SOURCE: jenn-air expressions 27" convection wall oven model wm27460 won't heat
reset your breaker reprogram the clock try again what happend last time it was working self clean broiling etc
Posted on Dec 29, 2007
Sea Breeze
  • 4655 Answers
SOURCE: GE Profile JT952 Touch Pad Button Issue
Try this link
http://www.fixya.com/howto/h155060-dreaded_f7_error
Posted on Mar 28, 2009
SOURCE: Whirlpool electric double oven #RBD305PDQ14 control panel blank
The control panel part on my Whirlpool double oven (part #8302319) went blank six months back. Replaced it. Asked if there was a warranty on the part, was told no there was not. Yesterday, the six month old control panel went blank. Disappointed that Whirlpool manufactures such garbage.
Posted on Feb 01, 2010
Popping noise, flames between oven and wall and burning plastic smell from Kenmore gas oven. We had noticed the smell off and on for 2 months, but the oven still worked properly until last night. I...
sounds like the insulation on the cord has been worn through and is shorting out. turn off the breaker pull out the oven and look where the cord goes into the oven and look for black burn marks.
Apr 09, 2017 | Kenmore Ovens
Random intermittant crackling sound from Hotpoint electric oven
This could be insulation on the wiring or more importantly the connecting spot might be frying. In any event, disassemble it and check into it.
Feb 24, 2013 | Hotpoint Ovens
My dacor microwave convection oven won't turn or heat but but the exhaust, time etc. works.
I found the answer on other posts on this website and it saved me $500! I had the same problem with my Dacor Model ECD2278 double oven. After I ran the self cleaning the top oven would not come on and the lower oven ran almost double the temp that was set. To fix: disconnect power to the oven at the circuit breaker. Open the oven door. You'll see the grille/grate/steel cover in front of the door latch mechanism, and it should have about 4 screws holding it in place. Remove the screws then remove the grille cover. On my model the tiny red reset button was on the right side on top of a black plastic round piece which is about 1" in diameter. Press the little button down til it clicks.
Oct 25, 2012 | Dacor ECS127 Epicure Stainless Steel...
My gas range/oven emits a toxic smoke that burns our eyes WAY different than spilled food. The smoke comes out the right side vent rahter than the usual left side vent and only when we cook higher than...
When the oven gets dirty and you don't run the clean cycle, dirt builds up and burns away the hotter the oven gets. Run the clean cycle if you have a self clean mode on the oven. throw the metal burner and grates in the oven too. (no plastic) open a window because it will stink and it takes a few hours to run. If not, use oven cleaner then run the oven to the hottest temp for at least 1-2 hours to burn the old dirt out..
Good Luck, Bill
Jan 07, 2018 | Ovens
Oven not working
fan oven element video. 1, If the fan motor . in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the element .you will have to remove the back plate from inside the oven. Once removed you will see the fan and element,. if you look closely at the element .you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your oven thermostat
4, A quite common and easily overlooked answer is if your oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
For all Free appliance repair videos visit our VIDEO TUTORIALS
Jan 12, 2010 | GE Ovens
Smoke and fumes coming from oven
Sounds like you need to clean the whole oven as old grease and spillages will keep on burning and smoking.
Jan 03, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Just recently, I have had the smell of wires burning and a small amount of white smoke coming from behind the control knob area on the right-hand side of the stove. All burners work and the oven heats. ...
Since you didn't include make and model of your range, no one can hazard a guess or research it. Please include those details next time.
You might try the manufacturer's website to see if there might be recall for that problem.
Dec 14, 2009 | Ovens
Smeg oven not working. only clock and thermostat light working
It sounds like you have either one of the following things that need attention. First, turn off both breakers to the oven and then back on. Next check the wiring from the receptacle to the back of the oven. Next, check your internal fuses. Most ovens have them. Last, check the wiring to the elements and control switches. Somewhere you have a wire burned off the terminals or control switch. That smell you referred to is probably one of the wires that may be burned.
Feb 11, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Microwave emits a burning smell when on
there is a transformer dont use it and get it serviced
Dec 28, 2007 | KitchenAid KEHC379JSS Electric Double Oven
Ovens Logo
32 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
