Question about HP Office Equipment & Supplies
Hp printer 7520 all in one, won't prink black, new black ink cartridges installed, alignment cartridges failed, printer set in default quality
leroyal
  • 2120 Answers
SOURCE: Printer Alignment Failed in HP C5280
You must replace both with new GENUINE HP ink cartridges at the same time or alignment will fail.
This is how HP makes their money.
Posted on Jan 18, 2009
Joed911
  • 4338 Answers
SOURCE: Won't accept non-HP cartridge
You ask "Is this a common problem with non-HP cartridges? " It is a possiblity.
Where did you purchase the cartridges from?
This error might be caused by defective printhead or sensors
Are you removing the 2 protective caps from the cartridges?
Read this HP page:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01451117&lc=en&dlc=en&cc=us&lang=en&rule=17507&product=3203059
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Apr 23, 2009
  • 55 Answers
SOURCE: The MP620 printer has 2 black ink cartridges. The
With these types of printers they will use all 4 colors to make black unless you configure it other wise. The link below will take you to the printers support page. In the box that says "please enter your question" type "how to use only 1 black ink". it will give you top results, just click #1 and it click on your operating system. Follow the instructions given and that should take care of it. If you have any other questions feel free to ask.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=238&modelid=17406#SupportDetailAct
Posted on Aug 03, 2009
  • 5 Answers
SOURCE: installed new hp black cartridge 56 ink but won't print
it shows if your using refill cartridge. & if you r using refill cartridge clear cartridge sensor with soft hands your problem would be resolved.
Posted on Jan 22, 2010
mediastormer
  • 135 Answers
SOURCE: I am setting up a
Step one: Load the correct type of paper Remove all the paper from the tray. NOTE: Colored, photo, or used paper can cause the alignment to fail. Load unused, plain white, letter, or A4-sized paper with a brightness level of at least 85 into the tray. NOTE: Look for the brightness level on the paper packaging. Step two: Align the All-in-One Press Setup . Press 5 . The product opens the Tools menu on the control panel display. Press 3 to select Align Printer . The product calibrates, aligns the printhead, and then prints an alignment page. Recycle or discard the alignment page. Video of aligning the All-in-One The following video demonstrates the steps for fixing a carriage or paper jam. The product shown in the video is the HP Photosmart C7280. The outside of the product might look different, but the steps are similar for the same for the HP Photosmart 3100, 3200, and 3300 All-in-One series products. If you have trouble viewing the video or to view the video in a different size, click here to play the video (in English) on YouTube. If these steps resolved the issue , there is no need to continue troubleshooting. If the issue persists , see the next step. Step three: Clean and reinstall the cartridges If the contacts on a cartridge are dirty or do not seat correctly, the alignment might fail. Follow these steps in the order presented to clean and reinstall the cartridges. Gather the following materials: Soft, lint-free materials, such as foam-tipped swabs, that do not stick to the electrical contacts Clean, lint-free paper to rest the cartridges on (coffee filters work well) Distilled water Press the Power button to turn on the product. Open the cartridge door. Squeeze the tab below the black cartridge on the far left side of the carriage, and then lift the cartridge latch. 1 - Cartridge latch for the black cartridge 2 - Cartridge latches for the color cartridges Remove the cartridge by pulling it toward you and out of its slot. CAUTION: Do not remove multiple cartridges at the same time. Remove, clean, and then reinstall each cartridge one at a time. Do not leave a cartridge outside the HP All-in-One for more than 30 minutes. Inspect the cartridge contacts for ink and debris buildup. Dip a clean foam rubber swab or lint-free cloth into distilled water, and then squeeze any excess water from it. NOTE: Hold the cartridge by its handle. Do not touch the copper-colored contacts with your hands or anything other than a foam rubber swab or lint-free cloth. Clean only the copper-colored contacts. 1 - Copper-colored contacts Slide the cartridge back into the empty slot. Secure the cartridge in the slot by pressing down on the latch until it clicks into place. Repeat steps 2 through 5 for each of the cartridges. Close the cartridge door, and then try to align the product again. If these steps resolved the issue , there is no need to continue troubleshooting. If the issue persists , see the next step. Step four: Check the ink levels Empty or nearly empty cartridges can result in alignment failures. Follow these steps in the order presented to check the ink levels in the cartridges. Press Setup Press 5 , and then press 1 . The Tools menu displays. Click Display Ink Gauge . The gauges for the six cartridges display. Check the gauge for empty or almost empty cartridges, and then replace any you find. The product automatically performs an alignment and prints an alignment page. If these steps resolved the issue , there is no need to continue troubleshooting. If the issue persists , see the next step. Step five: Replace the cartridges Follow these steps to replace any cartridges that are empty or low on ink. Open the cartridge door. Squeeze the tab below the black cartridge on the far left side of the carriage, and then lift the cartridge latch.
1 - Cartridge latch for the black cartridge 2 - Cartridge latches for the color cartridges Remove the cartridge by pulling it toward you and out of its slot. CAUTION: Do not replace multiple cartridges at the same time. Replace each cartridge one at a time. Do not leave a cartridge outside the HP All-in-One for more than 30 minutes. Remove the new cartridge from its packaging, and then, holding it by the handle, slide the ink cartridge into the empty slot. Slide the new cartridge forward into the empty slot. Repeat 2 through 5 for each of the cartridges. Close the cartridge door, and then try to align the product again. If these steps resolved the issue , there is no need to continue troubleshooting. If the issue persists , see the next step. Step six: Reset and relocate the product A power reset drains power from the product and returns the product to the same settings after restarting. Moving the product to another location and plugging it directly into a wall outlet can eliminate any potential power deficiencies that might prevent a successful alignment. Make sure that you have the product turned on. If necessary, press the Power button to turn on the product. With the product turned on, disconnect the power cord from the back of the product. Relocate the All-in-One to a different power outlet, preferably in a separate room Plug the power cord directly into the wall outlet. Do not use a power strip. Reconnect the power cord to the back of the product. Press the Power button to turn on the product. Load plain white paper into the tray. Try the alignment again.
Posted on Oct 30, 2010
My HPDeskjet says alignment failed. Cartridges are set to default quality. I just replaced the ink cartridge.
Are they refills? HP will not accept refills at all . I know from experience.
If they are HP cartridges then the print head is probably clogged. ( the big square tray that the cartridges fit into)
You'll have to remove it (just a latch or clip. Look in manual) and replace it. They can't be cleaned. I've tried on several different models.
Jul 14, 2016 | HP Deskjet 3050A e-All-in-One -...
Installed new black ink cartridge in HP PSC 2110 color printer, scanner, copier. Followed instructions to align cartridges. Printer printed paper that had additional instructions. Placed second printed...
hello, machine will need to finish calibration so it will not come back, so if machine failes it could be that the color cartridge is not printing, because this machine uses yellow to calibrate with.
Oct 06, 2010 | HP PSC 2110 Color Printer
How do you install an ink cartridge on an HP Officejet 4315 All in one Printer that I have had given me, with everything but the instruction book. Can you also confirm that the cartridge numbers are 27...
Working with print cartridges
To ensure the best print quality from HP All-In-One, you will need to perform some simple maintenance procedures and when prompted by a message on the display replace the print cartridges.
A) Handle the print cartridges
Hold the print cartridges by their black plastic sides, with the label on top. Do not touch the copper-colored contacts or the ink nozzles.
Note : Handle the print cartridges carefully. Dropping or jarring cartridges can cause temporary printing problems or even permanent damage.
B) To replace the print cartridges
1) Make sure the HP All-In-One is off whenyou open the print cartridge door to access the print cartridges, the Hp A-ll-In-One will not release the cartridges for changing. You might damage the HP All-In -One. If the print cartridges are not docked safely on the right side when you try to remove them.
2) Open the print cartridge door.
The print carriage should now move to the far right side of the HP All-In-One. If the print cartridge does not move to the right side, close the door. Then trun the HP-All-In-One offm and then on again.
3) Wait until the print carriage is idle and silent, and then lightly press down in a print cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
If you are replacing the black print cartridge, remove the print cartridge from the slot on the right.
4)Pull the print cartridge toward you out of its slot.
5. If you are removing the print cartridge because it is low or out of ink, recycle the print cartridge.
6. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab.
Caution Do not touch the copper-colored contacts or ink nozzles.
Touching these parts can result in clogs, ink failure, and bad electrical connections.
7. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black print cartridge, slide it into the right slot.
8. Close the print cartridge door.
9. If you installed a new print cartridge, the print cartridge alignment process begins.
10. Make sure you have plain paper loaded in the input tray, and then press OK.
The HP All-in-One prints a print cartridge alignment sheet.
11. Load the print cartridge alignment sheet print side down and top first in the center of the document feeder tray, and then press OK.
The HP All-in-One aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
Align the print cartridges
The HP All-in-One prompts you to align cartridges every time you install or replace a print cartridge. You can also align the print cartridges at any time from the control panel or by using the software you installed with the HP All-in-One. Aligning the print
cartridges ensures high-quality output.
To align the print cartridges from the control panel when prompted
1. Load letter, A4, or legal unused plain white paper into the input tray.
Note If you have colored paper loaded in the input tray when you align the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.
If the alignment fails again, you might have a defective sensor or print cartridge. Contact HP Support. Go to www.hp.com/support. If prompted, choose your country/region, and then click Contact HP for information on calling for technical support.
2. Load the print cartridge alignment sheet print side down and top first in the center of the document feeder tray, and then press OK.
To align the cartridges from the control panel at any time
2. Press Setup.
3. Press 6, then press 2.
This selects Tools and then selects Align Print Cartridge.
4. Load the print cartridge alignment sheet print side down and top first in the center of the document feeder tray, and then press OK.
Black Cartrige no . :27/21
Tricolor Cartridge no . 22
Hope this helps.
have a good day.
Dec 04, 2009 | HP Officejet 4315 All-in-One Printer
How to align my HP DeskJet 694C ink cartridge
Hi, have you tried another cartridge? Sometimes if a cartridge has been sitting around for a while, they become blocked with dry ink and print quality gets poor.
Dec 16, 2008 | HP DeskJet 694c InkJet Printer
Print Cartridge Alignment Failure
two option:-
1. cartridge is not proper. or
2. not proper installed.
Nov 29, 2008 | HP PSC 2355 All-In-One InkJet Printer
Can you set default to print using only black ink?
Wow, what an incredibly unhelpful answer. Thanks, HP shill.
The answer is no. Selling ink is how printer companies make money, and they will do everything possible to make you buy more ink, even when you don't need it.
Mar 08, 2008 | HP Photosmart C5180 All-In-One InkJet...
Ink cartridge alignment problem
well, what i did, and it seemed to work, in the short run anyway. i took and threw my hp in the back of a waste management truck,  then i called amazon.com and i ordered a new epson printer,
Oct 26, 2007 | HP PhotoSmart C4180 All-in-One Color...
Color Cartridge Failure
You know, I'm not going to read the other solution. I know 100% FOR SURE, when a cartridge fails, it is dead and there is nothing you can do about it, but there is a good side. HP ink cartridges have a year warranty. Call them and tell them it failed, they'll send you a new one!
Sep 18, 2007 | HP PhotoSmart 7760 InkJet Printer
32 people viewed this question
Seeker5211
Seeker5211
