Question about Bosch Food Mixers
My Bosch universal mixer, smells mouldy from the hole that the bowl fixes to. How can I prevent this smel
    Sergeant:
  • 197 Answers
Spray vinegar into it vinegar kills all moulds
Posted on May 04, 2017
4 Suggested Answers
defrankond
  • 65 Answers
SOURCE: Mixer stuck
You will have to have the transmission serviced. sounds like the gears were ground out. you can do the service work yourself its not to difficult.
Posted on May 05, 2008
SOURCE: bosch universal mixer
Sounds like the belt came off when you tried to mix the frosting while it was cold. Just too much of a load. It will have to be taken apart and the belt put back on.
Posted on Aug 29, 2008
SOURCE: My Kitchenaid mixer (k5ss lift bowl?) smells hot
I think you have a K45SS. It sounds like there is a problem with one of the gears, probably the worm gear. The worm gear is designed to be the first to fail if the mixer has struggled with a heavy dough or other difficult to mix substance. The best way to establish the cause will be to open the head up and check the gears for signs of damage.
Posted on Jan 25, 2010
Never used new bosch universal plus making bread started rattling sound
I do not know a lot about this machine. I am a DIY fix anything. It sounds like one of the mounting points on either the motor or the gearing gave way. Regardless it is new, send it back & have it fixed or replaced. Sorry, I know that is not what you wanted to hear, but is safest considering your investment.
Mar 10, 2014 | Bosch Universal Plus 6 Qt Mixer With 800W...
Will not start
I am having the same problem. I just noticed the piece of a part in the bottom of the machine. The hole where the bowl fits into is supposed to have a stop feature. Mine broke off and is in the hole beneath the lift arm. If you raise the bowl lift without a bowl in it, you will see a hole with screen mesh. That is where I found the broken parts. Now I have to find out where to get it fixed.
Jan 11, 2014 | Avantco Equipment Avantco MX10 Gear Driven...
Drive Shaft stopped kneading dough
To give the mixer strength it has planetary gears. Something may be wrong in the gear section
Nov 26, 2013 | Bosch 800-watt Universal Plus Mixer with...
Does anyone know how I could open the base of a Bosch universal mixer MUM6N11 to expose the wires as they come into the machine.
Just take the screws off the bottom. Several need a long screwdriver to access. Then the top will lift off.
Mar 02, 2010 | Bosch MUM6610 Universal Series Stand Mixer
In middle of kneading dough, the machine stopped! I noticed that the gears that connect the bowl to the machine, stopped turning, when machine goes on, it makes a noise, but nothing turns.
Hi HENNY346. Your Bosch mixer is belt driven and from the description of your mixer’s symptoms I suspect that the drive belt has come loose or failed completely so it stopped driving the dough hook. You say that when you turn the mixer on, it makes a noise, which may be the motor running without any load, but your description of ‘noise’ is very vague.
The good news is that you should be able to diagnose and fix this quite easily (OK, maybe with a little effort) by yourself, if you are a DITY type person, feel adventurous, and your mixer is not under warranty.
Here are links to two online parts vendors for your Bosch mixer that also provide an exploded view diagram along with part names, numbers and prices. They are: Cook's Quarters and AppliancePartsPros.com It can be very gratifying to go “under the hood”, figure out what’s wrong and fix it yourself. Good luck , I hope this helps. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
Feb 23, 2010 | Bosch MUM6612 Universal Series Mixer
My mixing bowl seems to be locked onto my Bosch Universal machine, cannot get it off. Anybody have a solution. I've tried turning it, using a crow bar, etc. the drive shaft still turns but bowl is "...
I had (have) the same problem with mine. It would stick occasionally and then one day it wouldn't come off at all. The bowl would unlock and turn like it should but wouldn't lift off. After much time and effort I did manage to get it off and found that the splines on the shaft were scored. When I examined the receiver part, the lugs (splines?) on it were worn allowing the shaft lugs (splines) to overlap the base lugs and thus becoming jammed.
I cleaned everything completely and made a batch of bread dough and it's stuck again.
I think the base receiver needs replaced but it may be part of the transmission and maybe the whole thing needs replaced, I don't know.
I sent an email and left a message with Bosch service and will post again when I hear from them.
I have used the mixer for about 4 years and love it but this problem shouldn't happen I don't think. It seems like a design flaw to me.
Dec 15, 2009 | Bosch MUM6610 Universal Series Stand Mixer
Where can I buy a Bosch hand mixer, it comes in a pack with a separate mixing bowl . I bought one years ago but it has only just ceased working.
No I havent found a dealer because Bosch no longer make the hand mixer. I cant afford to pay anyone to help me find an outlet for the Bosch mixers.
Sep 14, 2009 | Bosch Food Mixers
May 29, 2007 | Bosch MUM6630 Universal Series Stand Mixer
Food Mixers Logo
76 people viewed this question
Top Bosch Food Mixers Experts
Oscar Netto
Oscar Netto
Paul Bade
Are you a Bosch Food Mixer Expert? Answer questions, earn points and help others
