Question about Juki MO-655 Mechanical Sewing Machine
When I serge around outside corners I always get "hairy edges" or a choppy look. I've tried changing my lower knife, shortening stitch length at the corner, sewing extremely slow, it doesn't matter the corner never looks smooth.
Zenqi
  • 208 Answers
SOURCE: Inspiration 4205 stitch length won't change
Are you certain that the pattern selector is set for straight stitch and not buttonhole?
Turn the handwheel so that the needle is up and the take-up lever is in it's highest position. Then turn the pattern selector knob through all of the patterns back and forth a few times. Finally, select straight stitch and see if the length works. If not, need to take it to a repair person to determine the course of action.
Posted on Feb 21, 2010
  • 1116 Answers
SOURCE: Changed thread on serge pro SW 432. Now no chain or stitch.
Sergers can be tricky to thread.
Remove the thread.
Raise the antenna to it's highest position.
Open the tensions - setting zero.
Lift the presser foot.
Open the door on the serger and turn the handwheel until the upper looper is at it's highest point.
There should be a threading guide on the front of the machine or on the inside of the door.
Follow the threading sequence as this greatly affects the stitching.
Posted on Mar 13, 2010
Testimonial: "Did as you suggested--no luck. Then watched chaining process carefully--needle was too long to catch a loop. Reinserted needle. Voila!"
sewinsnap
  • 135 Answers
SOURCE: stitch length des not stay
What model do you have? If it is a computer model then I say that it needs to go back to the dealer
Posted on Aug 11, 2010
  • 10 Answers
SOURCE: How do I shorten the stitch to make a rolled hem? ...
For the rolled hem: the needle is in the O2 or right position, the length is 1.5 in the rolled section- you will see this, if you look on the side of the bottom knob- you can decrease this to 1, but you have to stay within the rolled section, the width is 3.5. the stitch selector is on D, the upper looper selector is UP, the blade is engaged and the subsidiary looper is to the right. You can use a decorative thread in the upper looper- Madeira Decor, Superior Threads made for bobbin work, or YLI Pearl Crown Rayon- or use a wooly nylon for excellent coverage and not need to decrease stitch length. I usually don't need to change the length with these threads.
  • 201 Answers
SOURCE: I have a designer 1
Make sure the u-shaped arm that is on the walking foot is "over" the needle screw i.e. the needle screw should be inside the u shape. The feed dogs need to be up also. Use the SET menu to set the machine for the correct fabric and function.
Is the walking foot new? I had one that I used a lot and it went nutty and had to be replaced. I pulled it apart and could not find anything out of place/worn out/broken but it just did not do the job any more. The new one works great.
Posted on Nov 19, 2010
How to applique with my Quilters Dream sewing machine
You should practice on scrap fabric until you can get the technique down well. There are different kinds of applique.
To cover raw fabric edges, you can do a smooth line of zig-zag over the fabric edge. Set the stitch width to a wide stitch and shorten the stitch length until the thread lays nicely next to each other with no gaps of fabric showing but also not so close that the stitches are on top of each other. There are methods for turning corners or curves that are nice for making a great looking edge.
Some tutorials may be helpful.
How to Applique
How to Do Applique How to Make and Apply Appliques
How to Appliqu Like Pro Sew4Home
Sep 05, 2016 | Sewing Machines
How can I use my Bernina 640 Artista to applique
Perhaps I'm not understanding your question. When doing applique, I use a very tight zigzag stitch with a satin stitch foot or open-toe embroidery foot (so the thickness of the stitches do not create buildup under the presser foot). Set the tension so the bobbin thread stays mostly under the fabric so the top thread is the only thread that shows on the top (sometimes threading the bobbin pigtail will help).
Fuse the cutout fabric to the backing fabric. Then zigzag so the raw edge of the fabric is covered by the zigzag (helps to use a thicker thread so the coverage is easier).
Some newer machines have the ability to miter corners. On my 930, I set the needle position to the outside of the raw edged. Then when I near the corner, I gently, but consistently, narrow the stitch width to an an outside point, since the needle on the outside edge, turn the fabric and gently, but consistently, widen the stitch to full width. This creates a nice mitered corner.
When making curves, stitch small lengths and then sink the needle on the outside of the curve, and gently turn the fabric to follow the curve and repeat while going around the curve.
https://books.google.com/books?id=MQneD8cQ5KAC&pg=PA13&lpg=PA13&dq=mitered+applique+corner&source=bl&ots=1sHsUrkVAz&sig=1WZ-i2-T3RtvUEW797sHxTKiq4E&hl=en&sa=X&ved=0ahUKEwiaoZeiwunKAhVslYMKHewdDFEQ6AEIKzAC#v=onepage&q=mitered%20applique%20corner&f=false
How to Appliqu Like Pro Sew4Home (FWIW, IMHO, the satin stitch on the bird is really a poor example. The stitch is not very even at all--could be the sewing machine.)
How to Make and Apply Appliques (The giraffe is a better example, although choosing a simple design to applique usually yields better results.)
Practice, practice, practice!
Feb 08, 2016 | Bernina Artista 640E Sewing, Quilting and...
Sewing a topstitch
Top stitching is usually done with straight stitch, ie stitch width on zero and stitch length on 2.5 but it depends on the application and the effect you are trying to get. Normal top stitch is where you might be stitching a facing down on the outside of a neckline, so you might want to stitch about 5mm away from the edge of the fabric. Always stitch from the outside of the garment, the finished side so you can turn on corners and control the fabric. If you have a clear pressure foot, then this will make watching the stitching easier. Not sure what your problem is with this technique so feel free to add more in comments if I've missed something.
Oct 02, 2011 | Janome Memory Craft 5700
When sewing with the brother serger 1034d, loops of thread stick out beyond the fabric-it is not nice and close like it's supposed to be. the settings from left to right are: 4,4,3,3. this is what my...
Can you wind the lower cutting blade to the right to cut less fabric and therefore fill out the stitching? On most sergers the lower blade position can be adjusted sometimes with a little knob or dial. You need to raise the top blade out of the way first, usually you put pressure onto it to release the spring holding it up against the lower blade, then swing it up to do this. Then wind the adjustment on the lower blade and move it to the right to cut less fabric then test serge. Your manual should give you more specific information on this and should be your first 'go to".
I would adjust my looper tensions to suit the fabric and width of the stitch I'm trying to achieve so yes, the settings you've been given are average tensions but its okay to vary these too. From left to right, I'd set 4, 4, 4, 4 and test serge again and see if this pulls the looper threads in against the fabric if moving the blade hasn't tightened up the stitching.
Sergers are more variable than a straight stitch sewing machine so its okay to move tension knobs a bit, just turn each a half number each time you adjust, then test serge and look at the stitch formation. Your needles tension should be fine at 4, leave them alone.
I'd suggest if you can find one, go to a "Getting to know your serger" type class as there is lots of techniques such as seaming on a curve, turning right angles, both inside and outside and making rolled hem edges that are very helpful serger skills to learn along with making adjustments and troubleshooting. Or go to you-tube and search some of these techniques for videos. Also www.sewing.about.com is a great sewing resource and Debbie has pages on sergers/overlockers here too.
When I'm starting a new dressmaking project I will spend 10 mins on the overlocker/serger, changing the thread colour to suit the garment, then test serging and adjusting the stitch tensions to suit the fabric. I have 4 cones of thread each in white, black, beige, grey, pink and pale blue and these threads will give a suitable finish on most fabric colours and prints. Then there is wooly overlocker thread, this is a fluffy thread that you can use for rolled hems as the thread relaxes once stitched and "fills" out the closely stitched edge covering the rolled fabric edge and is another whole area of fun to try out.
Often I'll just use a three thread to neaten the raw edges of a seam I will press open. Or I will assemble a whole knit garment using the four thread stitch, so much faster then stitching seams, then neatening. Jersey knits and sergers are made for each other.
As an aside the D on your machine model would denote "differential feed" too - briefly differential feed is adjusting the amount that the two feed dogs move under the foot and means you can "hold back" the fabric as it is stitched (0.5), or "stretch" it out (1.5 or 2 setting). Really handy for loose weave fabrics that stretch as you serge them, you can compensate using the differential feed setting. And in reverse, you can create a "lettuce" or wavy edge by turning the differential feed up.
I hope that this helps you out with your Brother 1034D and hasn't just confused you. Good luck.
Aug 01, 2011 | Brother 1034D Mechanical Sewing Machine
My serger keeps rolling the edge as I serge. I've tried to make several adjustments. Where do you get instruction manuals. Is it online?
Possibly you need to adjust the knife. It sounds like the knife is positioned too far to the right which is causing the cut fabric to extend further than the edge of the stitching. The thread chain is probably so tight against the edge of the fabric that it is folding it over.Move the knife a little to the left and try it again. If the thread chain is hanging past the cut fabric then the knife was moved too far to the left.
Jul 05, 2011 | Janome MyLock 644D
I am trying to do a rolled hem using a singer ultralock 14sh654. Do I disengage the knife? The stitches are uneven and some are quite loose no matter how much I adjust the tension. I am positive I...
no, you need the blade in place and cutting to give an even cut fabric edge. Set up for a three thread using the right hand needle, take out the left hand needle. move blade over to the right so it is cutting wide. Most overlockers there is also a thread finger you need to change on the foot, or a little lever you flick to move this finger forward into the stitching area. Check this on your manual as each make is a bit different.
If you can source it, put wooly nylon thread into the upper looper (knot it onto existing thread and just chain it through, the knot should go through the looper eye fine). Now turn the tension on top looper down so it is looser and tighten up tension on bottom looper, so needle 5, top looper 2 and bottom looper about 7.
Now test serge, the fabric cut edge should be wider than the overlocking seam so the fabric rolls under inside the stitching. Adjust the two looper threads so that this is happening, you want the bottom looper thread to nest right up against the needle stitch and the top looper thread to wrap all the way around too.
Once you've got this happening, turn the stitch length down to 0.5, to close the stitching right up. On some fabrics you'll need to adjust the differential feed too if the fabric is "waving" a bit.
Uneven stitches or sometimes loose when serging could indicate that one of the tension devices is faulting, so if this machine is not new and its doing this, it could need a service. Can you get a regular smooth three or 4 thread seam out if it???
It is always good to just recheck the threading path, make sure the thread aerial is up and that a thread hasn't got caught back on the thread stand somewhere if you're getting something wonky happening, threads stream off overlocker cones through the machine so anything wrong in the thread path will throw off the stitching.
Jun 25, 2011 | Singer 14SH654
How do I adjust the stitch length on a Janome "My Lock" 234?
Is there a dial on the right above the flywheel? This is where you adjust the stitch length on most sergers. It might be numbered from 0 to 5 or 4.
If it has differential feed, there would be a dial there for this too, possibly under the stitch length knob - it would have numbers like -1, -0.5, 0, 0.5 and 1 on it.
If you are new to sergers/overlockers I highly recommend a class, demonstration or investing in a good book to get you started as they are not like sewing machines and many of the techniques are best demonstrated such as rolled thread edging and flat lock seams.
I've borrowed he Singer book "Sewing with an overlocker", or "Serge with Confidence" by Nancy Zieman from my library but there would be other titles too.
Apr 13, 2011 | Janome 2049LX Mechanical Sewing Machine
I have a Baby Lock 5280E. Can you tell me how to set the machine for rolled hem?
Assuming you mean a narrow rolled edge:
  1. Remove the left needle and thread.
  2. Open both the front and side covers.
  3. Raise the presser foot and the upper knife to the highest position.
  4. Clear the stitch fingers.
  5. Push the stitch with former release lever and remove the stitch former from the lower knife base. (Don't lose it!)
  6. Turn the stitch with adjusting dial until the "M" on the dial matches the red indicator on the needle plate.
  7. Set the stitch width length to "M".
  8. Close the covers, lower the presser foot and the upper knife.
This gives you a narrow edge. To roll the edge, increase the tension of the lower looper (the green knob) about three numbers higher than normal.
Nov 03, 2010 | Baby Lock Evolve
How do you lower the knife so you don't have to cut through the fabric? I'm trying to serge a waistband in but don't want to cut he fabric.
there should be a cutting blade lock switch that you have to turn, it should be in the area where the stitch length & stitch width are
Oct 26, 2010 | Brother 1034D Mechanical Sewing Machine
Instructions for threading Baby lock eclipse BLE1LX for 2 thread sergering
I have just learned this :)
Either needle thread may be engaged for 2-thread serging.
1. Open the front cover and cutting blade cover, cut the upper looper thread just above the threading guide ( this is plate that has two holes for the threads) Raise the presser foot and pull out the clipped thread from under the foot. Remove upper thread from the machine (or you can leave the cone thread on, it doesn't matter).
2. Rotate the handwheel to bring the upper looper to its lowest position.
3. Rotate the subsidiary looper up and to the left, then slip the end into the upper looper thread eye from backside.(this sounds complicated, yes? but it is very simple : the looper has a counter part that is spring-locked to move from left to right and right to left. This is the little claw-looking part of the looper that when in the postion to serg with four threads is to the right side of the looper. It looks like a scorpion's tale. If you can't figure which part it is, use your finger to probe the looper and you'll feel it give a little. This part needs to be moved to the left - it will not slide over, but swing up and over and down, like an arch. Then, where the thread comes out of the looper is where you want the little claw-like part to hook into.)
4. Close the covers. Decrease the needel tension - this depends on what the stitch length is. Stitch length: 2-3, stitch width: 3.0 = L needle n/a, R needle 1; upper looper n/a, lower looper 5
stitch length: 2-3, stitch width: 5.0 = L needle 0, R needle n/a, upper looper n/a, lower looper 3.5
Those are for a flatlock stitch - for a 2-thread rolled edge :
Stitch length: 0.5, stitch width: M = L needle n/a, R needle 4.5, upper looper n/a, lower looper 3.5
Stitch lenght: 1.0, stitch width: M = L needle n/a, R needle 4, upper lopper n/a, lower looper 3.0
If you have any questions, e-mail me at knowgodnofear@bex.net
Aug 10, 2008 | Baby Lock Eclipse Serger
Juki MO-655 Mechanical Sewing Machine Logo
148 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
