Question about Garden
My tractor turns over won't start runs on starter fluid ran go last year only 1 year old
    Top Expert:
  • Garden Master
  • 15,387 Answers
Either bad fuel , fuel filter clogged or carb needs cleaning or repair
Posted on May 04, 2017
Ford tractor
How old is the fuel in the tractor? is it petrol or diesel powered?
Apr 14, 2014 | Cars & Trucks
Kawasaki 17hp fh500v won't start.
Did you try to use a little starting fluid to get it going. If you did and it would not fire, then you have no spark at the plug. If you did and it did fire, then you have no gas getting to the carb.
Mar 10, 2012 | Garden
Where is the timming point indicator on an old 3800 series
You have a failed fuel pump, if it was timing related it would not run on starting fluid. The fuel pump ids located inside the fuel tank, the fuel tank must be removed to access the pump
Feb 21, 2012 | Cars & Trucks
95 softail classic started and was warming up and just died and wont start, will fire with starter fluid but thats it, will not keep running, has appr. 30,000 miles
If the bike will fire with starter fluid but won't run on it's own, I'd say you have a fuel problem. In 1996, Harley introduced a vacuum operated fuel petcock. I see that you say your bike is a '95 model but Harley has always been known for crossing over year models with certain parts. Say you bike was built in late '95 and they ran out of the "old" style petcock. They just switched to the "new" style at that time instead of making more "old" style parts. That's where the term "transition model year" came from. So, check your fuel petcock and the vacuum line running to it. Pull the fuel hose off the petcock and spin the engine. Watch for the fuel flow and determine whether it is sufficient. If not, replace the petcock. Personally, I went to a Pingle manual fuel petcock. Of course, you have to plug the vacuum hose as it's no longer used. But, that was the end of petcock problems on my bike. Just turn your fuel on and off manually, "old school" style.
Good Luck
Steve
Sep 13, 2011 | 2000 Harley Davidson FLSTC Heritage...
I replaced the carburetor, spark plug, and put in new gasolone on a Toro Recycler (5 yrs. old) and it still won't start. The ignition is only one year old. Seems like I'm not getting any spark and the fuel...
Hi. Replace the air filter. Then use some starter fluid and an assistant. Spray some starter fluid into the air intake as you start it up and keep spraying so that it runs on the starter fluid for a few seconds until it really takes off. J.
If this does not do it then you will have to have the carburetor rebuilt as it has hardened gunk in it.
Aug 01, 2010 | Garden
Tractor wont start
For a small gas engine than won't start, think FAST -- Fuel, Air, Spark, Timing. You've replaced the filters and spark plugs and squirted in some starter fluid, eliminating the simple common fuel, air, and spark problems -- but I because of the backfiring I think your problem is in the timing -- like a sticking valve. Probably more than you want to tackle at home, but might not be as expensive as an engine replacement. Take it to a good small engine mechanic -- best bet is a lawn equipment shop that has been around many years. Drive a little farther to get to one if necessary.
Jul 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cub Cadet LT 1045 - Not starting, the engine does not turn.
remove the starter...use jumper cables to "run the starter manually...red to big lug, black to body (anywhere is fine) should torque hard at initial run and continue to run smooth...if it buzzes or vibrates, it's bad...replace...
Apr 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
I have a 42 in. 12.5 hp lawn tractor. It stopped running. I have replaced the battery, alternator, and had the started checked. Now, when I turn the key, all there is, is a click. I have been told the...
Have you checked the starter motor? It sounds like it is bad. You might be able to remove the blower housing cover and physically turn the starter teeth and then try to start (after putting the cover back on). If it tries to start then you have a bad starter (dead spot on the winding). Just replace the starter and you should be good.
Jun 04, 2009 | Garden
14 hp dynamark tractor that won't start
Have you checked the inline fuse?. Also you could unplug the ignition switch and clean the terminals, particuarly the one with red wire in it. That the one that has constant power to it and tends to corrode over time. Hope that helps.
May 23, 2009 | Garden
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
