How to program it for volume on tv - Televison & Video
Remote volume will not work
HAD SAME PROBLEM RE PROGRAM FIOS REMOTE ENTER 4 DIGIT CODE AFTER LIGHT BLINKS PRESS VOLUME UP AND DOWN IT SHOULD WORK THEN PRESS ENTER OR OFF BUTTON FOR PROGRAM TO WORK TURN TV BACK ON.....FIOS PROGRAM MANUAL HAS SECTION FOR THAT PROBLEM...MINE WORKS FINE AFTER I DID THAT..
May 25, 2013 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
We have also lost the manual for the RCA DTA800B1 converter box and need instructions to program the remote to work with a Sharp TV.
Press PGM on the remote control. The signal indicator on it remains lit.Enter the 3-digit program code with the number keys. Press OK The signal indicator will be o when the program is one.Press the volume keys on this remote control to check if they can adjust the volume of your TV set.• If you fail to control your TV set,repeat steps 2 to 4 to program again. Try another program code if there is more than one for your TV brand.• If the signal indicator remains lit after blinking four times, you may have
entered the wrong code. Repeat steps 3 to 4 to program again. Make sure you have correctly entered the code.• You can still use your TV remote control to turn on your TV set, select input source and control the volume.for conrmation.your sharp tv code is 005, 021, 071, 085, 087, 092, 128, 183, 208, 274, 298
Sep 16, 2011 | Televison & Video
I have a Vizio 47 inch LCD HDTV hooked to a Dish system. The volume fluctuates from very loud to very soft between ads and programs. It also goes from moderate volume to very soft within a program. Help!
Either unplug dish from tv or use the antenna side which is HD and program channels and see if volume the same, if not and is OK then it's your Dish bring your sound down or audio cables bad.
Feb 18, 2011 | Vizio E470VA 47 in. HD-Ready LCD TV
Remote doesn't control. batteries are good, but there is no apparent connection between the remote and the TV. It is in use with a Comcast turner-DVR, which works fine, but I have to turn on and adjust...
Are you using Comcast remote to control the TV? When you program the Comcast remote to control your TV, it will do two functions: on/off, and Volume control. The Comcast can also be programmed not to control the volume of the TV (TV volume will have to be set at about mid level manually, then the Comcast box will send out variable sound level to the TV), just on/off ONLY.
Oct 27, 2009 | Olevia 227-S11 27 in. LCD TV
Spectroniq PLTV-20NW32 volume only works on some channels
Hi lisadean767,
It is possible that without realizing, your TV is programmed to receive SAP or Second Audio Program audio. When this happens, your TV responds like this: when SAP is not being broadcast, you'll receive regular program audio. However, when the SAP audio is sent along with the regular, (English) program audio, your TV will automatically switch to the SAP channel. You'll know your TV is programmed to receive SAP because you'll hear the commercials in English and any other program in English if the SAP is not being sent.
Check and see if your tv is setup for SAP. Let me know if this helps and if I can be of further assistance, Please rate this solution.
Lone99star
Jan 22, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Cable Set-Top Box remot won't change sound vol. Only TV Rem. does
They volume indicator you are seeing is meant to show the volume of content if it were to be recorded on the cable's dvr. This indicator has no effect on the volume of content as it is being watched. This feature allows recording of sound at a set volume even while the tv is off. It sounds as though you'll just have to use the volume buttons on your tv's remote, though you might want to try seeing if there is alternative set-up for those cable volume buttons.
Jan 05, 2009 | Samsung LN19A330J LCD TV
Tv remote
Advent ADR-560 codes for a Sony TV are:
1002, 1218
Oct 20, 2008 | Recoton Advent Advent ADR-560 Remote...
Volume
You have programmed the wrong code. If this is a 3 digit code try 189 or all the Funai/Emerson codes for the RCA remote.
Apr 30, 2008 | Durabrand DWT1905 TV
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
