Question about Ovens
Leaning the inner glass of the main oven please.
I can take off the top glass, but not the main oven glass.
ginko
  • 19396 Answers
SOURCE: how do i replace the inner glass on the oven door?
moz-screenshot-7.jpgmoz-screenshot-8.jpgTo replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
See diagram below , click on picture to enlarge:
Part here: _.gif PS2087058
Posted on Apr 08, 2009
ginko
  • 19396 Answers
SOURCE: replace inner oven door glass on kitchenaid wall oven
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
Part here: Inner Door Glass
ginko
  • 19396 Answers
SOURCE: broken inner glass on Model # NGSG3PZAQA
SOURCE: My Stoves EFa600H inner glass recently shatterd
Hi Sorry- i do not how to do this BUT the eaxct same thing has happened to us! Cna i ask where you got the replacement glass, how much it cost and how long it took to deliver?
Thanks
Posted on Jan 27, 2010
  • 18 Answers
SOURCE: the inner glass door on my zanussi oven has come
You should be able to repair your existing door. Have a look around the perimeter of the door to see if there are any screws, particularly near the handle. You are looking to take the front fascia off the door, so that you can access the inside. Most doors have the front fascia held on by small brackets glued to the back of the glass that clip on to a fixing on the internal door. The top of the fascia is normally held in place by the handle. Once you have the front of the door off you can retrieve the piece of glass that has fallen out. You will almost certainly find that the glass has come away from the adhesive that was used to hold it in place. You will need to clean up the glass and the metal door and re-stick the glass using a high temperature oven door glue
Posted on Feb 18, 2010
I need a replacement inner glass door for my main oven on my bosch hbn43m5 1b
Fixya does not sell replacement inner glass for ovens.
Nov 15, 2016 | Bosch Ovens
Please tell me if Electrolux EKG5547XN Cooker Main Oven Glass Door would fit my EOB6632U
Glass oven door is not compatible.
First of all, the oven door EKG5547XN has only two glasses, inner and outer, while the oven door EOB6632U has three glasses; inner, middle and outer.
EKG5547XN
Inner glass oven door, part number: 349 00 30-01/6, silkscreened; dimension: 456 x 323 mm, tempered glass.
Front glass oven door, part number: 349 10 45-14 / 6, stainless.
EOB6632U
Inner glass oven door, part number: 899661 92 68-78 / 3,
silkscreened; dimension: 479 x 391 mm, tempered glass.
Middle glass oven door: dimension: 447 x 380 mm.
Front glass oven door: dimension: 589,5 x 466 mm.
Dado
Mar 28, 2015 | Electrolux Ovens
Replece glass oven door kitchenaid kebs278dss8
Oven doors have at least two panes of glass (air gap between so little ones touching outer glass do not get burned). You remove the screws around edges of door (top, sides, & bottom) and lift frame up and forward to get outer face off. The glass in ovens is tempered to take heat so you can not just use regular glass. You will find outer piece is sometimes the entire size of door but is painted black with the "dot" pattern that lines up with inner piece. Once you get face / frame off you will usually find the handle screws and mounts for inner glass. Sometimes inner glass sealed with high temp sealant. But make sure you use correct glass or someone could get hurt.
Jan 21, 2015 | KitchenAid Ovens
Neff B6774.0GB replace inner glass panel
open the door, loosen the two large screws (t20x or large flat head) near the top of the inner door, this will loosen the main outer door and you can slide it up and off. Look to the hinges and you will see retaining brackets held with two t20x screws, remove these and you then slide the rest of the door off enabling you to work on it on a flat surface. Lie it down with the broken glass as the lowest part. Remove two t20x screws from the two plastic holders near the top of middle frame, slide them out and remove the middle angled frame. Pay attention to which groove in the bottom of the door they are positioned for reassembly. You are now faced with a frame with absolutely mountains of t20x screws which will all have to be removed. when this is done, lift off the frame and you are left with the inner frame, broken glass and mesh panel. carefully take off the mesh screen and discard the broken glass ensuring that you do not inadvertently throw away the black thin seal (looks like a large rubber band). Use a toothbrush to ensure all glass is removed from the inner frame and that the inner edge of the frame is free from food debris etc (This is probably what caused the glass to shatter as the microwaves are attracted to food debris and would have cooked the glass causing a hotspot, this is usually evident if you look at the starting point of where the glass broke). Give the seal a clean also and reposition in the groove around the inner edge of the first frame. position the new glass panel, position the mesh screen and the middle frame. When putting all the screws back in, alternate them. left right top bottom until they are all back in (do not over tighten). Then reassembled the rest of the door by reversing the dismantling info. Let me know how you get on, please leave some feedback.
Nov 22, 2011 | Neff Ovens
Glass panel missing on grill (top oven) door?
if there seems to be a hole there and not a solid door then yes there should be glass there. try doing a goggle search on the brand . there might be a pic there to show you what is should look like.
Nov 12, 2011 | Ovens
Tecnick tck 8522/2 oven
power to the main oven has to go through the oven clock if time is not set main oven will not work also if clock set on auto time rather than manual oven will not work conversley if clock is faulty it will not work top oven is unaffected as oven clock auto timer cannot be used on top oven.try resetting power of and on again reset time on clock if clock not faulty oven will now work.
Jun 05, 2010 | Tecnik TKC8522 Electric Double Oven
The main oven inner glass door panel has shattered
Unfortunatey, it happens quite frequently, there is no one reason for it to do so.
The only solution is to replace it.
Over a number of years use, the glass looses it's properties, and this is what can happen.
Jan 24, 2010 | Zanussi Ovens
Broken inner glass doo
Hi.
Generally speaking it is not a manufacturing fault.
Can be caused by many reasons.
The main reason is because of a cold surface coming into con tract with the inner door glass, for example, wiping the hot glass door with a cold damp cloth, or banging thr door to hard to close it, there are other reasons as well, but to reiterate, it is not a manufacturing fault.
Please rate my solution.
Thanks.
Jul 19, 2009 | Ovens
How do I replace the inner glass on the oven door? I have taken the door off and it is apart, but the glass assembly looks to be one piece. How do I remove just the inner glass for replacement? JenW30400W
Mar 14, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Cooker
HI THERE SKI IS THE GLASS DOOR PANEL THE INSIDE DOOR GLASS OR THE OUTER DOOR GLASS PANEL AND IS IT THE MAIN OR TOP OVEN.
THE GLASS PANELS INTERNALLY ARE HEAT BONDED IN THE FACTORY AND CANNOT BE REPAIRED YOU WILL NEED A NEW DOOR GLASS.
IF INTERNAL ONE COME AWAY THEN U WILL HAVE TO HAVE A COMPLETE INNER PANEL.
Feb 13, 2008 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
