Question about Hozelock Garden
How do I set up my hozelock hose pipe to the reel it is free standing
SOURCE: Hozelock Auto Reel
I took it apart by unscrewing the 2 halves of the plastic cover making sure the hose was fully wound up as the spring mechanism can be dangerous. Extreme care must be taken. I can now get lubrication on to the spring. The manufacturers will not tell you how to do this due to health and safety rules.
Posted on Sep 30, 2008
  • 569 Answers
SOURCE: Bought a Hoselock Hose Reel today and cant figure
You need to purchase a Hoselock tap connector. There are two basic types, one has a thread that screws on to a theaded tap and the other type is a compession fitting that can be secured to most other taps.
The full range of connectors can be found on their website
http://www.hozelock.com/watering/hose-fittings/connect-to-tap.html
Posted on Mar 16, 2010
Testimonial: "Excellent thanks. The instructions that came with this product were v unhelpful. A nozzle missing and no explainations re Stop nozzle.A v poor leaflet"
SOURCE: how do you assemble 2in1 hozelock wall mounted
how do you assembly the 2in1 hozelock compact reel
Posted on Jun 16, 2010
  • 7 Answers
SOURCE: I was rewinding the Hozelock
Hi simon from hozelock - not sure what has broken, can't be the spring as a. They almost never break , and b. It wouldn't rewind at all. Suggest you contact our customer service team for help as it sounds terminal. Sorry. They are at info@hozelock.com
Posted on Aug 03, 2011
My hozelock auto reel has stopped locking. Have tried pulling it all the way out and then releasing but it does not solve the problem.
40 meter Hozelock auto reel would not lock when winding back into the drum.
1, Make sure the Hozelock hose has fully retracted into the drum.there should be no tension on the hose reel spring.
2, Use a Black & Decker Workmate.
3, Carefully opened the side cover taking out all of the Torx screws (10 in total) remove handle.
4, Turned the reel over and placed the auto reel onto the Black & Decker Workmate.
5, Placed a socket into the Workmate vice then line up the centre shaft bolt on the auto reel onto the socket, this will hold the steel spring in place so that I could undo the 2 security Torx screws. Slowly remove the 2 screws- there will be a little spring tension when removing the 2 screws, take care.
6, Lever up the centre shaft up out of the reel to expose the internal hose reel, take note the rotation of the plastic cog inside the cover.
7, Remove the brake locking arm from the side cover.
the arm had broken in half, I used a soldering iron to weld the two halves of the brake lever back together.
8, Rebuild in reverse order.
8, When rebuilding the auto reel use the ratchet and socket to tension the steel spring, I unwound the hose out of the drum then slowly wound the spring using the ratchet and socket. This wound in the hose onto the drum up to the hose stop then a couple more turns on the ratchet for a little more tension.
9, Whilst holding the ratchet keeping the tension on the spring. Replace the 2 security screws on the centre shaft .
10, This link on Youtube I found very helpful (46 sec into video) you can see the internal working and the brake lever.
Apr 24, 2015 | Hozelock 2490 Auto Reel 20m Hose 12.5mm
How to open casing on Hozelock hose pipe to replace spring
Peter send me a picture there might be a snap ring in the middle . Heavy Duty Hose Heavy Duty Garden Hose Pipe Hozelock check their support
Mar 22, 2015 | Vacuums
How can I fix a hozelock hose reel that has been pulled out too much and jammed?
you have to take the cover off and redo the hose you can re reel back in
Jul 19, 2014 | Hozelock 2490 Auto Reel 20m Hose 12.5mm
Hozelock
There is usually a retensioning screwdriver slot at the center of the back., you have to take off a small cap at back.
Jul 09, 2013 | Garden
How can i fix a leak inside my hozelock auto reel
adcccc13-7653-4a1a-83fe-508669c9a82e.jpg3187e97b-8b8e-4ed3-a2a0-0cad5211d982.jpg94e5325e-ed0d-4067-ba2e-15c982ded717.jpg350c6d53-8941-4e5f-937d-9425b18f4c89.jpgb9a1ffa9-99fa-4f32-9be1-717dd9251c09.jpg961cd592-0df3-420b-b7df-1b0ff17df252.jpg79809fc2-3e1f-4099-a3c7-00615892aa40.jpgd539f880-39af-40f4-850d-ad70e7f5948f.jpg7ce9923d-118a-4f30-9f13-20afc72d3ee9.jpg6d0fe000-779a-4d41-b1cc-81a243223d36.jpg2123ca49-4e92-4d43-a6cb-d6dab2644c3d.jpg9bcb85f0-f600-42e0-a249-d54524038b72.jpgea7bcfd2-840a-4496-a010-53e4229d922a.jpg6b9a17a9-5cc9-4ef8-8b28-3ddaee1a2172.jpgf3a3c78c-6856-4c78-bf68-90484825b7a0.jpgJust replace the O-rings inside. See pictures how to take it apart.
Jun 01, 2012 | Hozelock 2490 Auto Reel 20m Hose 12.5mm
Lost return tension when replacing hose
Where can I get a replacement tension spring for my auto reel hoselock 2490 ? I have tried everywhere but without success. Any help is much appreciated
Mar 19, 2012 | Hozelock 2490 Auto Reel 20m Hose 12.5mm
I have a Hozelock 2475. Which I need to have just bought a new hose for but i've mislaid the original assembly instuctions can I get same on line.
This is a link to a downloadable PDF file on our website , hope it helps http://www.hozelock.com/uploads/pdf/instructions/watering instructions/33714-002 2N1 REEL.pdf you can also get help from us on Facebook or at info@hozelock.com
Apr 19, 2011 | Garden
Mar 16, 2010 | Hozelock Garden
How do you assemble 2in1 hozelock wall mounted compact reel
Mar 10, 2010 | Hozelock Garden
Garden Logo
Top Hozelock Garden Experts
richie46
J Walsh
Level 1 Expert
Bill Boyd
Are you a Hozelock Garden Expert? Answer questions, earn points and help others
