Question about GPS
Who can ifind somewne - GPS
Why wouldn't my ifinder h2o c gps not pick up any satalite signal
The most common reasons are thus
1) You do not have the right PORT and BAUD set
Consult the manual for the software.
2) You are noit in a location where the sky is visible to the unit)
move outside and away from buildings or electrical items
3) Your battery power is too low to get a fix
4) nThe SIIRF chip is damaged
Please rate my help++++Thanks for using FIXYA
May 20, 2010 | Lowrance iFINDER H2O C Plus GPS Receiver
I have moisture under the screen of my ifinder expedition c after getting caught in the rain. How do I get rid of it?
usually the displays are sealed so this doesn't happen.
About all you can do is open anything you can and then place it where it will be warm but not hot, out of direct sunlight and hopefully with some air movement. It might take a week or more before the water is gone.
I would also have a chat with lowrance and see if you can get this replaced under warrenty. If it leaked once it will again.
Mar 30, 2010 | Lowrance iFinder Expedition C Handheld GPS...
How large of an SD card will a Lowrance IFinder express accept? Can a 1gb card be used?
iFinder is the king of GPS devices with respect to memory. Though 1 gb looks a little bit too much for it in the time being and may well hang the phone .
You can purchase MMC cards with up to 128MB or SD cards with up to 64MB of memory
Hope this helps
Mar 07, 2009 | Lowrance iFinder Express GPS Receiver
Ifinder go 2 frozen!
But a Garmin!
Jun 05, 2008 | GPS
Lowrance iFinder H2Oc analog speedometer...
I found that it works better to push exit three times from the map view.
Mar 08, 2008 | GPS
Map loading from SD card
Yes go to the Lowrance web site and down load the fix to a sd card , put the sd card in the i finder and it will update it automaticlly. I have not done it for map create 7.0 but have for map create 6.3. On the web site look under suport or downloads and you should find it. There is also a lot of free lake maps that you can download to sd card also. Good luck
Feb 11, 2008 | Lowrance iFinder GPS Receiver
Can't get position fix
Check to see if the date and the start point location where you are located are properly set. The GPS needs close enough location and date to know where it is starting from.
Read the instructions about the initial setup.
Jerry G.
Nov 28, 2007 | Lowrance iFinder GPS Receiver
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
