Question about ifrogz Cell Phones
How to pair my ifrogz plugz to my phone - ifrogz Cell Phones
Reset ifrogz plugz wireless
My ifrogz plug wirless earbuds got wet in the washer how can i fix them?
Oct 29, 2016 | ifrogz Audio Players & Recorders
My left earbud was hit against my desk and the circular metal piece disconnected from the speaker, how do I fix this?
push it back on and if it does not stay,use a very small amount of A-B epoxy glue. Apply glue with a sowing needle.
Apr 30, 2016 | ifrogz EarPollution Plugz Headphones
Solder headphone jack
If the wires can be joined see the attached pics for re-joining, just connect the same colours together. Test them to make sure there are no other breaks in the wire. Then solder them together and seal with a waterproof tape or similar. DONT just tape them together this will lead to them coming apart easily.
If they came out of the jack it would be best if you bought a new jack and soldered the wires onto this. Trying to open a factory fitted jack is difficult and you wont be able to seal again properly unless you superglue the jack once you've reconnected it and test them to make sure there are no other breaks in the wire solder the wires to the jack. see attached pics for jack wiring.
Hope this helps
Nov 16, 2013 | ifrogz EarPollution Plugz Headphones
Ear cushion is off the product at time of purchase
You can try returning the headphones to the store for replacement but if that doesn't work the cushion can be reinstalled unless it is damaged
May 31, 2013 | ifrogz EarPollution Plugz Headphones
How Do You Take Apart ifrogz Headphones
For the problem with winch ckt, ur solenoid is
almost worn out,2 possible solutions, 1, purchase another solenoid, leave original 1 in, connect the 2nd solenoid as follows, move the wire that comes from ign start ckt to the 2nd solenoid,leave all other connections as they are, run a cable from the battery to the 2nd solenoid's hot terminal and the cable that was originally from the hot battery terminal to the 2nd solenoid's starter output terminal. By doing this the original solenoid will not have to handle the 200 amp starter current directly, but will now be controlled by the contacts on the 2nd solenoid,reducing the load drawn by original solenoid by at least 60-70 %, that way the 2nd solenoid becomes the primary control ckt, this setup is used on International over the road trucks and works very well. I have connected a Case 580 C forklift that way for Mitchell Hardwoods Co. in Waterford, Pa.
Dec 04, 2012 | ifrogz EarPollution Plugz Headphones
I have the $25 headset...they just stopped working.
i've been through countless pairs of headphones and repairing them is often not worthwhile, once you've had the problem, it usually is recurring. it is suggester to just invest in some headphones that are ware-proof, meaning; fabric-encased wiring and waterproof earphones. most headphones go out because of tangling and untangling the cords because the wires inside are very brittle, are coated in a verry thin layer of plastic that when bent too many times or too far, or too rough, will break off and expose the wiring to the separated other wires causing a short.
May 01, 2011 | ifrogz EarPollution Plugz Headphones
One of the ear buds on me ifrogz earpollution headphones just stopped playing music. I haven't been dragging them around or getting them wet or anything, and they're only a couple of months old. The other...
I had same problem. 1 of earphones stopped working. If i turn up volume, some sounds gets through, but then the other earphone would be blasting. Used them running so maybe sweat or earwax clogged them, but the problem didn't start until 1 month after stopped running.
Mar 07, 2011 | ifrogz EarPollution Plugz Headphones
The left ear of my ifrogz headphones stopped working! Please help!
one or more of three things might have happen 1. the wire came off the speaker itself 2. the wire has been crushed in some part along the line in some shape or form 3. the wire came off the headphone jack in terms that it was built weak and ment to break to get you to buy more. In all three cases it just takes a bit of soldering and black tape.
Mar 03, 2011 | ifrogz EarPollution Plugz Headphones
I can't get sound to come out of the right earphone
Hi. Try to check if it is properly connected to the sound source. If it is, check for the wires. Look for damaged parts especially near the ends. If all these look fine then the earphone speaker itself is defective and that means you need a new pair.
Feb 04, 2011 | ifrogz EarPollution Plugz Headphones
Cell Phones Logo
52 people viewed this question
Top ifrogz Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an ifrogz Cell Phone Expert? Answer questions, earn points and help others
