Question about Irons
I bought a Steamglide 17880 in 2013 but never used it as we moved and it was put straight into storage. Now unpacked, the iron heats up, the pump makes a noise but no steam comes out. Any tips please?
  • 944 Answers
SOURCE: Philips Azure self-cleaning steam iron
philips do not have a manual for this iron online, sorry contact them if you want; The best way to clean these irons is with neat vinegar - try to get white vinegar and you have less smell to get rid of - fill the iron, give it a good shake and leave it overnight, then use the iron as normal (use it on a kitchen drying up towel or similar) then leave it for another few hours/overnight and then empty out any remaining vinegar and rinse through with water a couple of times. this normally solves any problems caused by limescale - if not then just leave the iron a little longer with the vinegar, also try to pour a little vinegar into the steam vent holes with the iron upturned and leave for a while. Hope this helps :)
Posted on Mar 13, 2007
  • 1074 Answers
SOURCE: Heats up but no steam coming out.
take down the iron and clean it the holes at the bottom of the iron are clogged up.good luck.
Posted on Apr 18, 2007
SOURCE: No steam
It appears that your rocker switch is broken, I am attempting to find a source for the switch and the screw driver that removes the screws holding the unit together
Posted on Feb 25, 2008
SOURCE: Russell Hobbs Steamglide 2200 - no steam
Same with mine! What you have to do is keep taking the water cannister off and pushing back on until its lined up correctley. Also have the whole unit at the same height as the ironing board, that should do it! Can you help with filters? I cant find them anywhere.
Posted on Mar 24, 2009
  • 137 Answers
SOURCE: lost instructions on how to use self clean on my iron
It probably needs to be de-calicified, you can find the stuff to do it at most any hardware store.
Posted on Mar 28, 2009
My steamglide model 20393 remains in constant steam mode.
Shot mode? My suggestion is to never use tap water. It will cause your Iron to stain your khakis. Use distilled.water. Water evaporates it develops calcium.
Sep 11, 2016 | Top Irons
Get the red light off, no heat and so no steam.
check main wire or main plug of wire
Dec 22, 2014 | Irons
Steamglide 2200 not heating up fuse ok
The internal element may have shorted out and thus the sole plate with heating elements will not operate any longer. The cost of repair exceeds the cost of replacement.
Dec 09, 2014 | Irons
I have lost my instructions on how to "self clean"
Straight from the manual:
Fill the iron with tap water to the max mark on the water tank.
Be sure that variable steam lever is set to minimum.
Stand iron on heel and plug in. • Set thermostat to ••• setting.
Once heated, unplug iron.
Hold iron horizontally over the sink with the soleplate pointing away from body.
Move the variable steam lever completely to the right and hold in the self clean position for one minute.
Warning: Doing this will cause steam and hot water to be ejected from the soleplate. Take all proper precautions and hold iron away from body.
• Move the iron gently back and forth and side to side until all water has run through plate.
• Carefully wipe all water and material from the soleplate with an old towel, as the water and minerals can stain the soleplate (although this has no effect on glide or performance.)
Warning: Iron and soleplate may still be very hot. Exercise care while wiping.
• Place iron on heel and leave to cool. Before using iron after self cleaning, test steam and burst
of steam on an old towel or cloth than can be discarded.
May 04, 2011 | Rowenta Professional DX8800 Iron
Russell hobbs steamglide 2400 iron water solenoid
So am I. Did you manage to source one?
Jan 26, 2010 | Irons
I have a Russell Hobbs Steam Generator iron - less than two years old. It has started to leak water - not really sure where it's coming from - it just pours out and eventually fuses the plug.
My Russel Hobbs Steamglide iron has stopped pumping steam , iron itself heats up but no steam...has the pump gone and can it be reapired
Oct 08, 2009 | Irons
I have a steamglide 2200 iron with water tank, it won't heat up. I have tried with the tank full to max and halfwy but it still won't heat up. There is a green flashing light on the side of the base with a...
sir, this is the rare problem. you need to replace your iron's heating coil. due to this these type of problem arisses.
thanks for contacting fixya
Sep 12, 2009 | Irons
Russell Hobbs Steamglide 2200.Iron and steam station seem to be heating correctly, but will not dispense steam when trigger on iron pressed.
is the water in your area heavy? it may have clogged your iron with stone. soak plate in something like clr .
Aug 10, 2009 | Irons
Mar 23, 2009 | Irons
Irons Logo
46 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
