SOURCE: Eddie Bauer watch.
these watches are waterproof so the stem is screwed down to seal out water. Try turning the stem to unscrew it somewhat , then pull out the stem to set.
SOURCE: get the back off my eddie bauer watch
when you look at the back are there three small rectangular indents evenly spaced on the edge on the back? If so you'll need a special tool for opening waterproof watches. the tool adjusts to fit the three indents then press down as you turn counterclockwise. you can find the tool on amazon.com or your local jewelry store. make sure the gasket is in place and not damaged before screwing the back on.
here is a link to the tool
http://www.amazon.com/Pavilion-Professional-Waterproof-Adjustments-Caseback/dp/B000K3SK0Y
SOURCE: Eddie Bauer wireless thermo clock - Time zone problem
TIME ZONE SETTING
The cefault time zone is PACIFIC. lf your location is not in the Pacific zone, set the
time zone as follows:
1. In normal time mode, press the "[,4ODE" key to enter the alarm time mode. 2. ln aiarm time mode, press and hold the ADJ . 'Cl"F" key for 2 seconds to enter
the time zone setting mode.
3. Press ihe "ADJ "C/'F" key to select the proper time zone: P=Pacific
M=Mountain C=Central E=Eastern 4. Press the f,'lODE key to save and exit the time zone setting mode, or let it exit
automaiically 30 seconds later without pressing any key.
SOURCE: How do I enable the alarm on the Eddie Bauer world
From the normal time position, press Mode and the AL function will come up which is where you set the alarm. Instead of pressing SET, press the up arrow. Each time you press the up arrow it changes function. When the alarm function is on a little bell appears above the colon in the time. The snooze has a ZZ that appears below the colon.The unique feature of this clock, is that it is the only one I have seen where the alarm works in the time zone selected. Most others, the alarm only works the home time zone, not the selected time zone. This is a huge improvement.
SOURCE: How do I set the temperature from centigrade to
its very easy, actually.
all you have to do is this:
while being in the regular clock mode, just press the DOWN arrow.
when you do this, different functions will appear.
when you press it once, you will star seeing, instead of the weather in farenheit, the seconds of the watch going by.
press it again and ou will see the temperature in celsius.
you can keep on pressing it and see that there are 3 modes:
-Temperature in farenheit
-Seconds of the clock
-Temperature in celsius.
Hope this helps you
