Hi,,, my nikai washing machine is making noise as some beads and stones are stuck in it.. we are not able to remove its rotater that down part that rotates clothes.. pls help
Nikai washing machine NWM1210T5 top load
  • 136 Answers
SOURCE: washing machine won't spin
The lid switch is likely defective. Test with a VOM meter and replace as needed.
Posted on Sep 21, 2007
the dr
  • 447 Answers
SOURCE: grinding noise when drum rotates
may be a foreign object trapped in between the inner and outer tub. Major Disassembly required to split the outer tub. May also be the rear bearing in which case back half will have to be replaced.
Posted on Oct 04, 2007
  • 126 Answers
Check the brushes in the motor.
Posted on Jan 28, 2008
  • 33 Answers
SOURCE: Clothing stuck on agitator with top loading washing machine
Dear Whitworth,
please rate this solution if it meets ur needs, else choose fixya...
The agitator's movement back and forth is important for the cleaning of your laundry. If it doesn't function properly, your clothes won't be as clean as possible. If your agitator does not move, moves only in one direction or its movement is very weak, you will probably need to remove the agitator. Furthermore, in order to inspect the tub for leaks, the clutch assembly, the splines, or to remove the spin drum, you will have to remove the agitator.
The agitator is fastened to the agitator shaft and its movement is driven either by splines or a simple clutch assembly. The splines are usually plastic or rubber nubs on a cylinder that fits over the agitator shaft. If the nubs wear down, the shaft will not turn properly or it will turn weakly. If the agitator is moving in only one direction, the likely cause is the clutch assembly. The clutch has dogs that depress and pop up with each turn. If those dogs are worn, they will not engage properly and the agitator will turn only in one direction.
Various makes and models differ in how the agitator is removed. In some newer models, the agitator just lifts straight up and out. However, in most models you will have to do some combination of the following steps. First remove the fabric softener dispenser, if any. It should either lift or screw off. Next remove the cap. It may lift off, screw off or failing that, it may need to be pried off.
Beneath the cap some agitators are secured in place by a bolt. Use a socket wrench with an extension to remove that bolt. Some Maytags may have a screw near to the bottom of the agitator post that must be removed. Now try to lift the agitator straight up, possibly with a little back and forth rocking motion. Use caution when pulling, the agitator may come loose suddenly and hit you in the face or send you flying backward.
If the agitator is particularly stubborn, you can loop some rope under one side of the agitator at the bottom and then up over a broom handle. Now loop it again under the other side of the agitator and back up to the broom. Brace one end of the broom handle against the top of the washer and lift up on the other end. Double check that you have removed anything that may be securing the agitator in place. Do not use too much force or you may damage the washer cabinet, agitator or injure yourself.
Click here to order replacement parts.
please rate this solution if it meets ur needs, else choose fixya..Thank you.
Posted on Dec 17, 2008
  • 850 Answers
SOURCE: The drum is stuck - it will not move
overloaded & unballanced has mabe pulled drum away from the rear bearing!
& jammed iself!
only way now is to disconnect power & water & undo cabinet to inspect it!
Cheers rob.
Posted on Jul 28, 2009
Bosch Maxx WFL 2260 making intermittent noises. Our machine works well but of late it has taken to making a graunching noise (similar to what you get in a car when you don't use the clutch properly). It...
you have a coin or a hairclim or metal part of a zip that is stuck in the filter where the wings of the water pump rotates against it.
Open the filter and try to remove it. Unplug the power first.
Good luck
Jan 24, 2015 | Bosch Washing Machines
Clothing stuck in washer machine
Is it stuck in the center agitator or the out tub?
Jul 04, 2008 | Washing Machines
Drum won turn
Wow, check around the bellows, gray rubber seal in front between the stainless basket, remove any item. Didn't find anything now unplug unit remove top and lower machine covers. Run the flashlight along the outer tub while looking inside the stainless basket, locate any items that may jam rotation of the inner basket and remove.
Oct 01, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine gets stuck in the rinse cycle
try cleaning the valve filter on the cold inlet
Apr 21, 2012 | Washing Machines
User guide washing machine nikai
I have nikai top loading washing machine6.5 kg, machine showing error code E8 , what is the problem, i have no manual booklet , so please tell the problem to solve.
Jan 28, 2011 | Washing Machines
My front load washer started making a very loud noise, as if rocks were being tumbled in the agitator. I did open the washer and found a small stone (probably from one of the children's pockets). However,...
HI- It is possible that one of the stones got stuck between the stainless basket and the tub. This is not a good scenario as the whole from panel and tub boot have to be removed and whatever is stuck has to be fished out. I would look as well for a nail or something long that is stuck down though one of the holes in the stainless basket and is rubbing on the tub. If you only notice during the drain or spin then likely there is something in the drain pump. You can check this by opening the pump cover at the bottom of the machine and removing the pump filter. Your Owners Manual should have an explanation of this procedure. It's pretty easy, just be ready to catch the water that will come out of the pump. Hope this helps, good luck.
Sep 24, 2010 | Asko W6021 Front Load Washer
My washing machine is making a loud screaming's still washing my clothes but when it's on the spin cycle it's almost unbareable.
As the washing machine is making a loud noise I think the first thing I would request you to do is lift up the washer from the front, remove the belt and check the pump by rotating the pump pulley manually. If does not move freely then replace the pump.
Let us know if you want any further clarification.
Thanks for contacting
Dec 06, 2009 | Estate ETW4400VQ Top Load Washer
My dyson D17 is making an incredibly loud noise, like grinding, when the bottom brush rotates.
Remove the bottom cover plate and rotate the brush by hand. Look for things that make noise like stones caught in the brush path, bad brush bearings, bad drive belt.
Aug 02, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Driver side wheel makes noise, it gets more rapid as I go faster
There are a few reasons why a wheel will make noise when it's rotating. The most serious would be a bad wheel bearing. I would have the front wheel bearings checked, and if the driver's side needs replacement, I recommend that you have the passenger side replaced as well.
Other less serious causes for a noise at the wheel can be a small stone stuck inside a hub cap or a stone lodged in the tire tread.
Jul 29, 2009 | 2003 Chevrolet TrailBlazer
LG/ westinghouse lifestyle font loader
what you will need to do is wright down the model number and go to ebay and put in bearings for a lg then put your model number in and it will come up with very cheap bearings thats where i get all my stock from. good luck £4.50p very cheap
Jan 06, 2008 | LG WM2077CW Laundry XL Front Load...
Washing Machines Logo
Top Washing Machines Experts
