Question about The Computers & Internet
This code modi method is not working it is giving an junk value can any send the correct c program to implement transportation problem using modi method
  • 48 Answers
SOURCE: code for method parseInt() in java
parseInt(java.lang.String, int)
This code takes two arguments, a string constructor from the Java language and an integer. Its purpose is to parse (meaning de-construct or disassemble into component parts) one data type into another.
Here is an example of a Java program to specify and print out the dimensions of a rectangle, taken from the page http://www.roseindia.net/java/beginners/entervaluesfromkeyboard.shtml:
class Rectangle{
int length, breadth;
void show(int x, int y){
length = x;
breadth = y;
int calculate(){
return(length * breadth);
public class EnterValuesFromKeyboard{
public static void main(String[] args) {
Rectangle rectangle = new Rectangle();
int a = Integer.parseInt(args[0]);
int b = Integer.parseInt(args[1]);
rectangle.show(a, b);
System.out.println(" you have entered these values : " + a + " and " + b);
int area = rectangle.calculate();
System.out.println(" area of a rectange is : " + area);
Posted on Apr 13, 2009
  • 51 Answers
SOURCE: i need a c++ or c programming code for transportation problem
Hey i'm no programmer but i can point you in the right direction if you want to learn how to use C++. http://www.youtube.com/view_play_list?p=925C4CBD7CEEEE08&search_query=C%2B%2B+anti+RTFM This guy is really good. Hope this helps. If it does can you please rate me.
Posted on Jun 24, 2009
SOURCE: Java code for Solving system of linear equations
2x-3 = 3-3(x + 3)
Posted on Oct 27, 2010
SOURCE: a c program to implement transportation problem
#include<stdio.h>
#include<conio.h>
main()
int flag=0,flag1=0;
int s[10],d[10],sn,eop=1,dm,a[10][10];
int i,j,sum=0,min,x[10][10],k,fa,fb;
clrscr();
/* Getting The Input For the Problem*/
printf("Enter the number of Supply
scanf("%d",&sn);
printf("Enter the number of Demand
scanf("%d",&dm);
printf("Enter the Supply Values
for(i=0;i<sn;i++)
scanf("%d",&s[i]);
printf("Enter the Demand Values
for(j=0;j<sn;j++)
scanf("%d",&d[j]);
printf("Enter the elements of the array
for(i=0;i<sn;i++)
for(j=0;j<dm;j++)
scanf("%d",&a[i][j]);
/* Calculation For the Transportation */
i=0;j=0;
for(i=0,j=0;i<sn,j<dm;)
if(s[i]<d[j]) // Check supply less than demand
x[i][j]=a[i][j]*s[i]; // Calculate amount * supply
d[j]=d[j]-s[i]; // Calculate demand - supply
i++; // Increment i for the deletion of the row
or
column
else if(s[i]>=d[j]) //Check the supply greater than equal to
demand
x[i][j]=a[i][j]*d[j]; // Calculate amount * demand
s[i]=s[i]-d[j]; // Calculate supply - demand
j++; // Increment j for the deletion of the row
or
column
/* The Cost Matrix is Estimated here */
printf("Given Cost Matrix is :
for(fa=0;fa<sn;fa++)
for(fb=0;fb<dm;fb++)
printf("%d ",a[fa][fb]);
printf("
/* The Allocated Cost Matrix is */
printf("Allocated Cost Matrix is
printf("%d ",x[fa][fb]);
sum=sum+x[fa][fb];
printf("
/* Transportation Cost Estimated and Sum is Printed*/
printf("The Transportation cost:%d
",sum);
getch();
Posted on Dec 09, 2010
ByteGP
  • 45 Answers
SOURCE: when i insert a sim card then shown give lock code but idn't implement any lock code before.
Factory lock code is 12345 unless you have changed it. Go to settings and set lock code to off.
Posted on Apr 11, 2012
What do you mean recurrence relation in computer science? advantage and disadvantages in recurrence relation in computer science? what do you mean sequence? in computer science? what are the importance...
Recursion in computer science is a method where the solution to a problem depends on solutions to smaller instances of the same problem. The approach can be applied to many types of problems, and is one of the central ideas of computer science.Most computer programming languages support recursion by allowing a function to call itself within the program text. Some functional programming languages do not define any looping constructs but rely solely on recursion to repeatedly call code. Computability theory has proven that these recursive-only languages are mathematically equivalent to the imperative languages, meaning they can solve the same kinds of problems even without the typical control structures like "while" and "for".In computer science, a list or sequence is an abstract data structure that implements an ordered collection of values, where the same value may occur more than once. An instance of a list is a computer representation of the mathematical concept of a finite sequence, that is, a tuple. Each instance of a value in the list is usually called an item, entry, or element of the list; if the same value occurs multiple times, each occurrence is considered a distinct item.
Jun 30, 2011 | Computers & Internet
What difference between genricServlet and httpServlet
public abstract class GenericServlet extends java.lang.Object implements Servlet, ServletConfig, java.io.Serializable
  • GenericServlet defines a generic, protocol-independent servlet.
  • GenericServlet gives a blueprint and makes writing servlet easier.
  • GenericServlet provides simple versions of the lifecycle methods init and destroy and of the methods in the ServletConfig interface.
  • GenericServlet implements the log method, declared in the ServletContext interface.
  • To write a generic servlet, it is sufficient to override the abstract service method.
javax.servlet.http.HttpServlet
Signature: public abstract class HttpServlet extends GenericServlet implements java.io.Serializable
  • HttpServlet defines a HTTP protocol specific servlet.
  • HttpServlet gives a blueprint for Http servlet and makes writing them easier.
  • HttpServlet extends the GenericServlet and hence inherits the properties GenericServlet.
May 12, 2011 | Computers & Internet
Configure.csv
CSV means:
A comma-separated values or character-separated values (CSV) file is a simple text format for a database table. Each record in the table is one line of the text file. Each field value of a record is separated from the next by a character (typically a comma, but some European countries use a semi-colon as a value separator instead). Implementations of CSV can often handle field values with embedded line breaks or separator characters by using quotation marks or escape sequences. CSV is a simple file format that is widely supported, so it is often used to move tabular data between different computer programs that support the format. For example, a CSV file might be used to transfer information from a database program to a spreadsheet.
Dec 27, 2010 | Acer TravelMate 2300 Notebook
How to convert infix to postfix using stacks in java programming?
u can try the follwing coding
import java.io.*;
import java.util.*;
//begin coding for the stack interface
interface Stack<E>
public boolean isEmpty();//tests is current stack is empty. Returns true if so, and false if not.
public E top() throws StackException;//retrieves value at the top of the stack. Stack cannot be empty.
public void push(E value) throws StackException;//pushes a value on the top of the stack.
public void pop() throws StackException;//removes a value from the top of the stack. Stack cannot be empty.
}//terminates coding of Stack interface
//begin coding for the objArrayStack class
class objArrayStack<E> implements Stack<E>
//constructor
public objArrayStack()
topValue=-1;
}//terminates constructor
public void push(E value)throws StackException
if(topValue<ArraySize-1)//currrent stack is not full
++topValue;
Info[topValue]=value;
}//terminates if
else //current stack is full
throw new StackException("Error: Overflow");
}//terminates push method
if(!isEmpty())//current stack is not empty
--topValue;
else //stack is empty
throw new StackException("Error: Underflow");
}//terminates pop method
return topValue==-1;
}//terminates isEmpty method
if(!isEmpty())//stack is not empty
return (E)Info[topValue];
}//terminates top method
//declare instance variables
final int ArraySize=10;
private Object Info[]=new Object[ArraySize];
private int topValue;
//begins coding for the StackException class
class StackException extends RuntimeException
//constructor
public StackException(String str)
super(str);
}//terminates text of constructor
}//terminates text of StackException class
//method to convert from infix to postfix notation
public static String InToPost(String infixString)
//operator stack initialized
objArrayStack<Character> operatorStack = new objArrayStack<Character>();
//postfix string initialized as empty
String postfixString = " ";
//scan infix string and take appropriate action
for(int index = 0; index < infixString.length(); ++index)
char chValue = infixString.charAt(index);
if(chValue == '(')
operatorStack.push('(');
else if(chValue == ')')
Character oper = operatorStack.top();
while(!(oper.equals('(')) && !(operatorStack.isEmpty()))
postfixString += oper.charValue();
operatorStack.pop();
}//end while loop
}//end else if
else if(chValue == '+' || chValue == '-')
if(operatorStack.isEmpty()) //operatorStack is empty
operatorStack.push(chValue);
else //current operatorStack is not empty
while(!(operatorStack.isEmpty() || oper.equals(new Character('(')) || oper.equals(new Character(')'))))
}//ends while loop
}//end else
}//end else if
else if(chValue == '*' || chValue == '/')
else
while(!oper.equals(new Character('+')) && !oper.equals(new Character('-')) && !operatorStack.isEmpty())
}//end while loop
}//end else
}//end else if
else
postfixString += chValue;
}//end for loop
while(!operatorStack.isEmpty())
if(!oper.equals(new Character('(')))
}//end if
}//end while
return postfixString ;
}//terminates text of InToPost method
public static void main(String[]args)
objArrayStack mystack = new objArrayStack();
System.out.println("Enter a string");
Scanner scan = new Scanner(System.in);
scan.nextLine();
String str = scan.nextLine();
InToPost(str);
}//terminates text of main method
}//terminates text of objArrayStack class
Mar 16, 2010 | Sun Java Programming Language (cdj-275)
Sir, give me sample java problem! for i can solve.
Look at the method below which finds prime numbers. public class Primes { private static void findPrimes(int nValues, boolean printPrimes) { boolean isPrime = true; for (int i = 2; i <= nValues; i++) { isPrime = true; for (int j = 2; j < i; j++) { if (i % j == 0) { isPrime = false; break; } } if (printPrimes && isPrime) { System.out.println(i); } } } // REMAINING METHODS NOT SHOWN }Implement the method findPrimesFaster in class Primes by copying the code from the findPrimes method and modifying it to have the following features:
  • Uses labeled continue instead of break.
  • Does not require the isPrime variable.
  • Only tries to divide by integers up to the square root of the number being tested.
Sep 25, 2009 | Sun Java Programming Language (cdj-275)
I want to read text file which is located in c drive using java code can anybody help me out
import java.io.*;
import java.util.Scanner;
public final class ReadWithScanner { public static void main(String... aArgs) throws FileNotFoundException {
ReadWithScanner parser = new ReadWithScanner("C:\\Temp\\test.txt");
parser.processLineByLine();
log("Done.");
* @param aFileName full name of an existing, readable file.
public ReadWithScanner(String aFileName){
fFile = new File(aFileName);
/** Template method that calls {@link #processLine(String)}. */
public final void processLineByLine() throws FileNotFoundException {
Scanner scanner = new Scanner(fFile);
try {
//first use a Scanner to get each line
while ( scanner.hasNextLine() ){
processLine( scanner.nextLine() );
finally {
//ensure the underlying stream is always closed
scanner.close();
* Overridable method for processing lines in different ways.
* <P>This simple default implementation expects simple name-value pairs, separated by an
* '=' sign. Examples of valid input :
* <tt>height = 167cm</tt>
* <tt>mass = 65kg</tt>
* <tt>disposition = "grumpy"</tt>
* <tt>this is the name = this is the value</tt>
protected void processLine(String aLine){
//use a second Scanner to parse the content of each line
Scanner scanner = new Scanner(aLine);
scanner.useDelimiter("=");
if ( scanner.hasNext() ){
String name = scanner.next();
String value = scanner.next();
log("Name is : " + quote(name.trim()) + ", and Value is : " + quote(value.trim()) );
else {
log("Empty or invalid line. Unable to process.");
//(no need for finally here, since String is source)
scanner.close();
// PRIVATE //
private final File fFile;
private static void log(Object aObject){
System.out.println(String.valueOf(aObject));
private String quote(String aText){
String QUOTE = "'";
return QUOTE + aText + QUOTE;
Jun 22, 2009 | Sun Java Programming Language (cdj-275)
Code for method parseInt() in java
class Rectangle{
length = x;
breadth = y;
int calculate(){
Apr 09, 2009 | Sun Java Programming Language (cdj-275)
A c program to implement transportation problem
#include<stdio.h>
#include<conio.h>
main()
int flag=0,flag1=0;
clrscr();
scanf("%d",&sn);
scanf("%d",&dm);
for(i=0;i<sn;i++)
scanf("%d",&s[i]);
for(j=0;j<sn;j++)
scanf("%d",&d[j]);
for(i=0;i<sn;i++)
for(j=0;j<dm;j++)
i=0;j=0;
or
column
demand
or
column
printf("
sum=sum+x[fa][fb];
printf("
",sum);
getch();
Apr 08, 2009 | Computers & Internet
Sending mails using asp.net
ASP.net is a programming environment, not a freaking e-mail MTA. If you knew why the transport connect failed, that would give you a clue how to fix your program. I imagine you are not; however, programming. Are you trying to use a .Net Mail program?
Stop calling for Sir, too; smart girls might hook you up, and then you'll be behind even if you can send e-mail. Which I also suspect; really, you should not.
Mar 10, 2008 | Microsoft Windows XP Home Edition
Computers & Internet Logo
26 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
