What is a path
Computer
    Top Expert:
  • Computers & ... Master
  • 50,533 Answers
A path in a computer is a set of directions that take the computer commands along a set process to reach the end instruction
it is like C:\-----\-- another is HPTT:/ www.google .com-- for search engines
Posted on May 04, 2017
How come I am not able to install on my computer,
An example of a path would be c:\windows\programs\redbook
Everything starting at the c is the path. Change the destination to a folder/path that is shorter than the current one. The path starts at the hard drive then goes from folder to folder until it reaches the destination.
Jun 06, 2014 | Avanquest Checksoft 2007 Home & Business ...
Tip
An error message informs you that you cannot move or rename the Documents and...
To specify a different folder for the Documents and Settings folder during installation, follow these steps: 1. Run Winnt.exe or Winnt32.exe by using the /unattend option, and then insert the following entry into the Unattend.txt file, where z:\foldername is the path and folder name you want: [GuiUNattended]
ProfilesDir = z:\foldername 2. Install Windows. The path that you included in the Unattend.txt file is used instead of the default Documents and Settings folder.NOTE: This method does not relocate any key Windows components. Use this method if you require only user-specific data to be moved.
After you install Windows XP, to specify a folder other than the Documents and Settings folder for a particular user's data, follow these steps: 1. Identify the user's profile path. You can identify the profile path either by user security ID (SID) or by user path settings. The user SID method is preferred. To identify the user's profile path by the user SID loadTOCNode(3, 'moreinformation'); a. Use the Getsid tool from the Windows Server Resource Kit to obtain the SID. At a command prompt, use the following syntax: getsid \\ComputerName UserName \\ComputerName UserNameFor example: getsid \\windowsxp joedoe \\windowsxp joedoeThe results look something like this: = The SID for account WINDOWSXP\joedoe is S-1-5-21-1708537768-1993962763-1957994488-1003 b. After you obtain the user SID, start Registry Editor (Regedit.exe or Regedt32.exe), and then select the user SID under the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList To identify the profile path by the user's path settings loadTOCNode(3, 'moreinformation'); a. Log on to the computer as the user, and then type set at a command prompt. Note the setting for UserProfile, and then quit the command prompt. b. Log on to the computer as an administrator. c. Use Registry Editor to add the UserProfile setting to the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList d. Click the registry key, and then click Find on the Edit menu. e. In the Find box, type the value of the UserProfile setting, and then click Find Next. 2. In the HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList registry key, change the ProfileImagePath value to reflect the new path that you want to use, and then quit Registry Editor. 3. Log on to the computer as the user, type set at a command prompt, and then verify that the path has changed.
Moving the entire folder loadTOCNode(2, 'moreinformation'); NOTE: This method does relocate key Windows components. Use this method only if you require the Documents and Settings folder to be moved or renamed and you cannot use the Unattend.txt file to change the name during installation.
To specify a different folder for the entire Documents and Settings folder, including key system components, follow these steps: 1. Log on to the computer as an administrator, and then create a new folder. 2. In the current Documents and Settings folder, on the Tools menu, click Folder Options, and then click the View tab. 3. Under Advanced settings, click Show hidden files and folders, and then click to clear the Hide extensions for known file types and Hide protected operating system files (Recommended) check boxes. 4. Click OK. 5. Click and drag all the folders in the Documents and Settings folder to copy them to the new folder, except for the folder for the currently logged-on administrator. 6. Log off and then log back on, using a different administrator account from the one that you just logged off from. 7. Open the Documents and Settings folder again, and then copy the profile of the administrator that you just logged off from to the new folder. This extra step is needed because you cannot copy the profile of the account that is currently logged on. 8. Log off the computer, and then again log on to the computer as an administrator. 9. Start Registry Editor, and then click Find on the Edit menu. 10. Type documents and settings, and then click Find Next. 11. For every registry key or value that contains the original path, replace the value data or rename the value or registry key to the new path.IMPORTANT: You must complete this change in the registry for every instance of the original path, or your computer may not start. It is imperative that you update all registry keys and values with the new path.
12. Restart the computer. You can now safely remove the original Documents and Settings folder.
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
Path length too long
The Windows error is complaining about the length of the full path. The full path includes the entire path as well as the file name. If that 'Full Path' is longer than 256 characters, then you may run into this error.
Feb 07, 2014 | Iomega 1TB Desktop USB 2.0 Hard Drive
What path do i select to install rainbow six 3
You can let Rainbow Six choose the default path. It is probably something like...
c:\\Program Files(x86)\Ubisoft\
Otherwise, you can use that path. The path really doesn't matter as long as the application knows where to find all of it's relevant files.
Dec 09, 2012 | Ubi Soft M Clancys Rainbow Six 3 Raven...
Taken a photo on my mobile and now want to tranfer to my computer
whicht handset ur using and which oprating system
solution is hare
use mermory card reader and locate tha path of ur pic and copy
or
connect the usb cable in phone and select mass storage option in phone after computer will detect and u will see drive im my computer locate tha path and copy file
Sep 23, 2011 | Computers & Internet
Problems changing variables on windows 7 for Java jdk1.7.0. I have no path variable any ideas thankyou
If your trying to add javac.exe to your path variable do the following
  • Right Click Computer
  • Select Properties
  • On the left select Advanced System Settings
  • Select Environment Variables
  • Under System Variables scroll down to Path
  • Append the path and exe to the Path variable
If memory serves javac.exe is located in C:\Windows\System32 so append ;C:\Windows\System32\javac.exe
Comment if you need more help
Sep 13, 2011 | Sun Computers & Internet
I am trying to unistall elibrary software and i am getting an error message 1324 the path sony reader contains an invalid character
Hi!
You can try to manually remove the software and reinstall, BTW there is no operation system detailed. But here's a solution for windows XP, Vista and 7
Windows XP:
Open My Computer .
In the My Computer window, go to the following path
C:\Documents and Settings\All Users\Application Data\
Delete the folder called "kinoma"
Then go to the following path:
C:\Documents and Settings\"your user name"\Local Settings\Application Data \
Delete the "Sony Corporation" folder
Windows Vista® and Windows® 7 operating system operating systems:
Open Computer on your Desktop
Go to the following path:
C:\ProgramData\
Now go to this path:
C:\Users\"your username"\AppData folder\Local\
Delete the folder called "Sony Corporation"
GoodLuck!
eBookBoy
http://digialreader.freeforums.org/
Jul 18, 2011 | Sony PRS-505 eBook Reader
Printer is not printing with these pages alternating"online single load" and "load paper from single"
The printer is indicating that the paper path has been changed (either via the control pannel on the printer or by escape command) to the single sheet feeder.
I guess you are using Continuose Paper fed into the tractors at the front of the printer (Tractro 1), if this is the case you need to go into the menu on the printer and change the paper path back to Tractor 1.
Take the printer off-line by pressing the Online key
Press the Setup key
Press the key under "Paperway" in the display
Select Tractor 1
Press the key under "Set"
This should change the peer path to the front Tractor, if this does not work power the printer OFF and disconnect it from the computer system. Then power the printer back on again and again try changing the paper path as described above.
If you get the message LOAD SINGLE only when you send data to the pritner you need to check the paper path selected on the computer system.
Jan 25, 2010 | TallyGenicom 2280 Matrix Printer
I have a cd with pics on it that someone from greece burned for me, but no computer will read them. Any possible way to get them up.
hi this is john...
i know ur cd is not working in any system but if u know how to go in command prompt so i will give u two command which u have to use and apply to copy ur cd otherwise u have lost of cd data
COPY [/Y|-Y] [/A][/B] [d:][path]filename [/A][/B] [d:][path][filename] [/V]
or
COPY [/Y|-Y] [/A][/B] [d:][path]filename+[d:][path]filename[...] [d:][path][filename] [/V]
use it and share ur feelings with me in future..
bye bye
Oct 25, 2009 | Kodak Picture Maker Kiosk Printer
How do I find the sound unc path to file download
I don't know what 'Sound' unc path you are referring to, but if you want to find the UNC path to a networked share, it is \\computername\sharename
So if your computer is named say Johndoe and you have already mapped a drive to the folder you are wanting to access called itunes share then your UNC path is going to be \\Johndoe\itunes share
Good Luck!
Oct 22, 2009 | ASUS P4P800SE Motherboard
Computers & Internet Logo
David Payne
David Payne
