Question about Refrigerators
Can't adjust temp on my schmick wine/beer fridge on the beer side only
  • 66 Answers
SOURCE: the refrigerator section is freezing. the temp adjust is at 1
This could be the actuator is not closing the door that controls how much cold air from the freezer is ciculated into the fresh food section. It could be something broken or there could be ice biuldup on the door itself, not allowing the door to open or close.
Posted on Nov 12, 2008
  • 333 Answers
SOURCE: I want to install two beer tap faucets in the side of my fridge
All of wires are located in the bottom. The side walls are just filled with foam. HAPPY DRINKING
Posted on Dec 05, 2008
  • 750 Answers
SOURCE: Haier Wine Fridge problem
Hello bano24
Welcome to Fixya
My name is Huum,
You have a faulty cold control (temperature control)
The cold control is a temperature actuated switch and should open when the set temperature has been achieved. If the control does not open and turn the compressor off, it will continue to run and all items in the fresh food section will begin to freeze.
Check the control for continuity.
And or need a hands on service tech to diagnose this fault
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Posted on Dec 31, 2008
SOURCE: lost manual for wine fidge
Push the red and white buttons at the same time for about 3 seconds-the temp will start to flash-then press the white button to lower the set temp-when you have it where you want it then push the set buttom
Posted on Jun 11, 2009
  • 255 Answers
SOURCE: Westinghouse fridge thermostate replacement
Without drawing a diagram, and assuming you have the controller, you need to do two things: Power the controller by finding a wire pair in the fridge that is always hot, and finding the wire that the resident thermostat uses to interrupt the operation of the compressor. This thermostat is usually located behind a panel in the top part of the refrigerator section and has a bulb that resides in the freezer. . Your controller should have an on and off range; that is, it should cut the fridge on at, say 61, and cut back off at, say, 60. You'll need some kind of range, thereby giving the compressor some "off time" of more than a couple of minutes. If you don't do this, you will reck the compressor, or it simply won't start. (Refrigeration systems need to equalize so that the compressor motor won't have to start when the pressure is really high. At equal pressure between evaporator and condensor, the motor can start easily.) . You have quite a project ahead of you. I suggest when you get into the nitty gritty of it, enlist your neighborhood MacGyver type. It shouldn't be that hard to pull off this project.
Posted on Nov 25, 2009
Testimonial: "tks very much for the advice pj, I have the new controller, it appears to be quite sophisticated & has delays. It is a KI&BNT model MTC-2120"
My wine/beer two door schmick fridge won't adjust down on the beer side. Wine temp adjusts but beer side won't and is staying on 50 f
Sounds like the thermostat for the beer side of the fridge has stuffed up grr! I feeel for ya!!!! i think they are automatic but if it is a manual switch may be playing up
May 04, 2017 | Furniture
Hi. I have a Dihl WF-21SS Reviews and the temperature LEDs doesn't display correctly. Can it be fixed???
Here are the possible solutions if they don't fix it, you will want to find the authorized repair company as it is a control board issue.
1. Remove all your wine and beer and place it in your regular refrigerator.
2. Unplug this refrigerator and leave it alone for 24 - 48 hours.
3. Go purchase a refrigerator thermometer and put in in the refrigerator.
3. Plug the refrigerator back in and set it to the temp you like to keep it at. Do not put anything back into the refrigerator yet.
4. Check the temp of the refrigerator against the refrigerator thermometer - it is not unusual for the thermometers to be a couple of degrees in difference. If everything is acceptable, only place the wine back on the racks, leave the beer in the other refrigerator. Let it run for a week and see if it stays balanced.
Or - if upon initial check you find the two thermometers not agreeing you can do one of two things.
A. Best option - contact authorized repair and have them come fix it.
B. Leave the refrigerator thermometer in the fridge and adjust the display panel until the temp in the refrigerator is where you want it on the refrigerator thermometer.
C. Dispose or replace the refrigerator.
Note: I don't suggest overloading your refrigerator.
The original owner's manual is available here (I believe the last two letters designate the finish for example SS = stainless steel).
DIHL WF 21BD Instruction Manual
Best wishes,
Aug 25, 2016 | Washing Machines
What is the correct temperature for beer? Or wine. Or pop? Please
Hi Laraine:
- If you're British, warm. Canadian, wet. Otherwise, who cares?
- white - chilled, red - warm. If you're Canadian, wet.
-Pop - cold, but if you're Canadian, stick to beer and wine so....... Who cares?
Jun 06, 2016 | Furniture
True T-49 refrigerator/freezer temperature calibration
Contact the manufacture, it is most likely going to be covered under warranty. If the knob is not removable, (check for a set screw on the side of the knob it will take a small allen wrench) Then the thermostat (temp controller) will need to be replaced, if it isn't a style that you can calibrate.
Jan 30, 2014 | True Refrigeration True T-49 2 Door Bottom...
Why is there water in the bottom of my wine cooler
cos you have condensation inside due to the fact that it is not frost free OR you have a seal leak.....OR the door is constantly open and closed (my beer fridge is like that.....)
Jun 25, 2010 | U-Line Wine Captain (2015WC) Wine Cooler
Freezer was freezing ice cream rock hard and refrigerator liquids( ie. milk, beer) was only a little cool. how should i adjust the number settings?
Don't do anything too quickly here. Move the freezer number one digit warmer and fridge one digit cooler today.
Check temp (and icecream) tomorrow. If not satisfied, move one more digit on the freezer or fridge until you are happy.
Mar 18, 2010 | Maytag MSD2756G Side by Side Refrigerator
Liquids frozen in refrigerator, no water from water dispenser
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 22, 2009 | Kenmore 53642 / 53644 Side by Side...
Can the U-Line 15WC Wine Captain be converted to a beer cooler? Can it be adjusted so that it gets colder?
Here is a couple of reason that answer is no. One the thermostat is designed for 45 - 60 degrees. 2 The door is only design for those temperatures as well. I believe you are going to need the bee around 34 degrees. A wine captain would never make it. Its also design for 3 different temps at once. coldest on bottom and warmest on top.
Aug 22, 2009 | U-Line 15WC Wine Cooler
My fridge is freezing my cans of beer even tho it is on low? It is a phillips 360L cycle defrost (fairly old)
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Here's a diagram with your damper parts.
Jul 10, 2009 | Whirlpool ET1FHTXM Top Freezer...
Does anyone know how to lower the temp below 45 degree's.
Dear friend,
ngfam at you service! happy to assist!
No they have no bypass!
How old is this wine cooler! MY ADVICE BUY ONE NEW!
It cost $241 to buy a new one at the site below!
If the dishwasher is 10 years or older its not worth investing money tofix it! The new ones are mush more efficient and clean better!
Either way this is a service problem to remedy!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Jul 07, 2008 | Haier BC112G Wine Cooler
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
