Question about Furniture
My wine/beer two door schmick fridge won't adjust down on the beer side. Wine temp adjusts but beer side won't and is staying on 50 f
  • 197 Answers
Sounds like the thermostat for the beer side of the fridge has stuffed up grr! I feeel for ya!!!! i think they are automatic but if it is a manual switch may be playing up
Posted on May 04, 2017
I have a wine enthusiast wine cooler model 272 03 27. Not cooling,compressor kicks on. The fans are running.The temperature never gets below 64.Is it the temp sensor or Control board? Thanks Randy
It sounds like it is in the correct temperature range. You may ned to adjust the temperature to a lower setting.
°C °F Wine Style 19 66 Armagnac, Brandy, Cognac 18 64 Full Bodied Red Wines, Shiraz 17 62 Tawny Port 15 59 Medium Bodied Red Wines 14 57 Amontillado Sherry 13 55 Light Bodied Red Wines 12 54 Full Bodied White Wines 11 52 Medium Bodied White Wines 10 50 Ros?, Light Bodied White Wines 9 48 Vintage Sparkling 8 46 Fino Sherry 7 45 Non-Vintage Sparkling
Dec 01, 2016 | Furniture
Hi. I have a Dihl WF-21SS Reviews and the temperature LEDs doesn't display correctly. Can it be fixed???
Here are the possible solutions if they don't fix it, you will want to find the authorized repair company as it is a control board issue.
1. Remove all your wine and beer and place it in your regular refrigerator.
2. Unplug this refrigerator and leave it alone for 24 - 48 hours.
3. Go purchase a refrigerator thermometer and put in in the refrigerator.
3. Plug the refrigerator back in and set it to the temp you like to keep it at. Do not put anything back into the refrigerator yet.
4. Check the temp of the refrigerator against the refrigerator thermometer - it is not unusual for the thermometers to be a couple of degrees in difference. If everything is acceptable, only place the wine back on the racks, leave the beer in the other refrigerator. Let it run for a week and see if it stays balanced.
Or - if upon initial check you find the two thermometers not agreeing you can do one of two things.
A. Best option - contact authorized repair and have them come fix it.
B. Leave the refrigerator thermometer in the fridge and adjust the display panel until the temp in the refrigerator is where you want it on the refrigerator thermometer.
C. Dispose or replace the refrigerator.
Note: I don't suggest overloading your refrigerator.
The original owner's manual is available here (I believe the last two letters designate the finish for example SS = stainless steel).
DIHL WF 21BD Instruction Manual
Best wishes,
Aug 25, 2016 | Washing Machines
What is the correct temperature for beer? Or wine. Or pop? Please
Hi Laraine:
- If you're British, warm. Canadian, wet. Otherwise, who cares?
- white - chilled, red - warm. If you're Canadian, wet.
-Pop - cold, but if you're Canadian, stick to beer and wine so....... Who cares?
Jun 06, 2016 | Furniture
Why does my wine cooler run too cold?
If after adjusting your thermostat to desired temp and is still cooling. The thermostat is bad or your relay is bad
If you disconnect the thermostat and the compressor stops it most likely a bad thermostat
If you disconnect the relay from
The thermostat and it stay running it is the relay. It is sticking
If possible store you wine somewhere else and shut the unit down and unplug for 10 to 20 minutes this may cause some melt of condensation some water may be on the floor if is to cold
This may also reset the system.
Jul 26, 2015 | Marvel 61WC Wine Cooler
Beeping will not stop on wine cooler - red wine side
Beeping usually indicates that something has gone wrong. Probably not cooling properly. The water coming out would indicate that the unit has defrosted. Turn the unit back on again and see if the red side is cooling properly. Some wine fridges have independent evaporators which allows different cooling temps in different parts of the cabinet.
Jun 26, 2014 | Danby DWC2727BLS Silhouette 54-Bottle...
Why is there water in the bottom of my wine cooler
cos you have condensation inside due to the fact that it is not frost free OR you have a seal leak.....OR the door is constantly open and closed (my beer fridge is like that.....)
Jun 25, 2010 | U-Line Wine Captain (2015WC) Wine Cooler
Freezer works great, but fridg. will not get below 50
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 17, 2009 | Maytag MZD2766GES Side by Side...
Can the U-Line 15WC Wine Captain be converted to a beer cooler? Can it be adjusted so that it gets colder?
Here is a couple of reason that answer is no. One the thermostat is designed for 45 - 60 degrees. 2 The door is only design for those temperatures as well. I believe you are going to need the bee around 34 degrees. A wine captain would never make it. Its also design for 3 different temps at once. coldest on bottom and warmest on top.
Aug 22, 2009 | U-Line 15WC Wine Cooler
Haier wine cooler
Haier BC112G service & user manual:
To adjust the temp of your unit:
  • Push & hold the red wine & white wine button at the same time.This will start the temp adjust. You will notice the plus sign & the negative sign on these same buttons, use them to adjust temp. When you are done hit the light button & it will record the new temp.
Nov 25, 2007 | Haier BC112G Wine Cooler
Furniture Logo
972 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
