Question about Coffee Makers & Espresso Machines
Sprada smart coffee machine parts (printed circuit)
Where do I find a Faema Smart A2 replacement touch pad? The left push panel is not working and the guy fixing it wants me to order a new one but I can't find a matching part anywhere on the internet.
You're looking for part number 3301135601. I've come across a few Smarts with Due front panels - so measure your keypad: if it's 68x58mm you need a Due version instead.
Feb 09, 2015 | Faema Smart A2 Automatic Espresso Machine...
Making coffee this morning and I was frothing the milk and the system just shut down.
More than likely your internal components has failed, particularly it sounds like the power supply portion of the circuit. This is due to faulty part or short circuit due to leakage or stress on electrical components. More than likely even if you are "tech savvy" coffee pot are usually difficult to repair depending on the type. The circuit boards are printed and the microprocessor (the brain) more than likely is a glob of black epoxy coupled with micro parts you can barely see. To stop my rambling I would say replace it, or take it back to store for replacement, find another exact coffee pot that is damage but internal electrical components remain in tac, or just trash it and buy another...Good Luck
Jan 27, 2013 | Coffee Makers & Espresso Machines
How to replace fuse?
follow where the power cable tracks are and you will find it near the positive wire track.
Sep 21, 2017 | Gaggia MDF Coffee Grinder
I have a Capresso CoffeTEAM GS # 464. I decalcified the machine in the last several weeks with Durgol and replaced the water filter - have done this every 6-8 weeks for the life of the machine. I had...
Hi
Probably an internal Element has gone open circuit.
Machine is smart & senses not heating up so don't let water through.
Mine did the same thing. So I pulled it apart (with photos)
Found the heater element (Open). Found a replacement element after 6 weeks and replaced it in 2 hours.
Back to getting great coffee.. Ahhh
Aug 14, 2011 | Jura Capresso CoffeeTEAM GS 46405
RE Starbucks Barista Aroma Grande Coffee Maker - the part that holds the coffee basket has a spring and a rounded ball-like plug in the bottom that presses down a button on the top of the coffee caraf. ...
Hello Tjreindl,
That is just to keep the machine from spilling COFFEE
all over the place if the OPERATER yanks out the
CARAF WHILE THE COFFEE IS BREWING...
(before it is done...
(About as smart as fast frying BACON... *****)).
In the OLDEN DAYS... (when life was simpler)
we just let the machine finish making coffee...
THEN pull out the CARAF.
I like strong coffee... Steeping is part of the
BREWING...Tastes a little more like COFFEE
rather than just BROWN water.
(No point in drinking a quart of water
just to have a cup of coffee).
But hey... It's your money.
Carnac the Magnificent
Oct 21, 2017 | Starbucks Barista Quattro Coffee Maker
Bunn keeps blowing the circuit when pulled in
If the circuit resets with the coffee maker unplugged, the coffee maker is at fault. There is a defective part in the unit that is shorted causing an overload in the circuit. You will have to isolate the bad circuit and replace or replace the coffee maker.
Oct 30, 2009 | Bunn 10 Cup Home Coffee Brewer
Coffee dispenses extremely slow
try to change the grinder to little more coars, if it not help then i think it can be something with the printed circuit card.
Best regards
/Mirran
Sep 21, 2008 | Saeco Vienna Espresso Machine
Loud ratchet sound - coffee tamping problem perhaps -
I think you have a leakage in your machine, it can also be your printed circuit card there is a short circuit.
Try to take off the top and look inside the machine.
/Mirran
Aug 18, 2008 | Gaggia Syncrony Compact Coffee...
Just lost contact with George... on a coffee maching problem
I think you have to replace the printed circuit card.
Jul 20, 2008 | Coffee Makers & Espresso Machines
Same problem
The printed circuit card is the problem, on some models the printed circuit card loose from the chassis.
Jul 06, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Coffee Makers & Espresso Machines Logo
54 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
