How do I connect ir3300 to computer using a network switch?
  • Office Equip... Master
  • 9,783 Answers
3 Suggested Answers
canontech
  • 1219 Answers
SOURCE: hi when i connect my ir 3300 with computer the
Wich kind of problems, you are unable to ping the copier or you cant print, or ...
If you connecting the PC directly use the croswired cable if you are connected over HUB, or other network device you must use normal UTP patch cable, from copier to the HUB, and from the HUB to PC.
Do you have right IP, subnet and gateway?
Check the network cards on copier and PC, if you crimp the cables by yourself check the cables,...
Do you have printer FLASH on your copier?
When did errors occured? Were you able to print before?
Posted on Apr 30, 2010
muntejaya
  • 10421 Answers
SOURCE: how to install canon ir3300
Hi, please get new driver here: www.driversdown.com/
www.nodevice.com/driver/company/Canon/Printer.html
www.usa.canon.com/cusa/office/products/.../hs_1200ts
Jay kjhags
Posted on Feb 12, 2011
How to connect this ir3300 xerox machine to computer plz tell me sir i request u
you need to have a driver installed on each P.C
http://www.usa.canon.com/cusa/support/office/b_w_imagerunner_copiers/imagerunner_2200_2220i_2220n_2800_3300_3300i_3300e_3300en_3320i_3320n/imagerunner_3300#DriversAndSoftware
You need an ethernet network of computers
You need to set up the ip addess and subnet mask in the printer via its setup menu . At the very least a ethernet network Switch with static ip addesses for each device , or A router with DHCP server to dynamically assign ip addresses.
you need an rj45 socket on the ir3300 which it should have 802.3 ethernet 10/100 tbase ethernet according to ir3300 specs if it is missing you need a network card to be added to ir3300 by Xerox / Cannon
Sep 05, 2015 | Xerox Office Equipment & Supplies
How to solve the code E00000000 in the Canon IR3300
The error code states that the machine doesn't sense the temperature of the fuser getting hotter. Usually this calls for the fixing film unit to be replaced because the thermistor has gone bad.
Jul 04, 2014 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
Canon ir3300 showing paper jam in 2nd tray but thre is no paper jam in it
i m using canon ir3300 , showing paper jam at left side , but i checked there is no any paper, although there is showing jam. what to do.
Jul 17, 2012 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
IR3300 copier drivers
You might want to post this question in a different section. This is the computer section.
Jun 28, 2012 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
I want canon ir3300 model scan drivers and how use instructions manual setup window xp os. color and b/w mode.please request send scan drivers to my mail
Does your IR3300 have the network kit installed?
If so you can use Canon Network ScanGear Tool v2.30 (you can find the download on canon websites e.g. http://software.canon-europe.com/software/0040589.asp?model=). The IR3300 is a B&W copier with B&W scanning, so don't use the colour version of the tool.
The tool comes with a manual on how to use it. I recommend using it with Adobe Acrobat.
Jun 16, 2011 | Canon imageRUNNER 2200
I had insttalled a network card and when i press the Counter Check button i see IR3300(IR2200N) and i have probably set the network settings on the copier and computer still they can not communicate. what...
Do you have the Network Guide?
Go to page 2-11 and follow the instructions there.
You can click the DHCP icon and hopefully you'll get an IP address etc. (you may have to restart using switch on right hand side of copier to turn off, wait a while then turn back on). Once you have an IP address click on the DHCP icon again to make sure it's not filled in with black and save settings.
IP address must be in same range as other devices on your network e.g 192.168.1.x or 192.168.0.x (only specify a number for x between 1 and 254, must not be used by another device). Subnet mask must be same as for other devices. It's probably 255.255.255.0 If connecting using a crossover cable you should set a static IP address on each machine, with the subnet mask 255.255.255.0
Dec 24, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Hi when i connect my ir 3300 with computer the ir3300 is showing network problem. even i had change two no. of cross cables.
Dec 18, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Hi I have been asked to setup used IR3300 to be used as shared printer with Active Directory. I assigned right ip adddress with subnet mask and default gateway, but from any PCs within LAN i cannot ping...
Are you possitive that your iR3300 has printer kit installed. That series of Canon copier comes with NIC installed, but the print DIMM and network firmware is an additional option that needs to be installed. If I remember correctly, there is a way to display the firmware levels...you would see iR3300n (network).
Nov 07, 2009 | Canon imageRUNNER 5000 Copier
jasbo
jasbo
