Question about Vacuums
I want a vacuum cleaner , how does 20volts Compare to 1250 watts
My vacuum cleaner power is 1250 watts, I am looking to buy a new one what is the equivalent power in volts?
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
You may look here for different models from different manufacturers with pros/cons comparison Best Vacuum Cleaners 2018 Shopping Guides
Posted on Dec 15, 2017
    Top Expert:
  • 2,044 Answers
You need to understand what you are asking. One is the Maximum Draw (20 Amp) which is quite Stout in the power usage. There are better "EFFICIENCY" Vacuum cleaners that use less power. What you should be asking yourself is what is a GOOD VACUUM compared to a GREAT VACUUM and what Vacuum will do its job and last. Then you have to take into consideration that if you do not take care of your Equipment, you can burn it up prematurely. SILVER KING/RAINBOW/KERBY are High end vacuum that you are going to pay well over $1000 for. You can go to Walmart and buy their High End vacuum for less than $200.... Your Call
Posted on May 04, 2017
My problem is that Model 16N5-K, 120v 60Hz 12 amp Bissell Vacuum cleaner has no wattage indication in the unit itself, in the box, in the product brochure. our power output in the Philippines is 220v. I...
All the information you need is in your text :>)
Volts, Amp Watts To determine the wattage, use a simple multiplication formula. The ampere (or amps) is the amount of electricity used. Voltage measures the force or pressure of the electricity. The number of watts is equal to amps multiplied by volts.
How to Calculate Wattage (Formula and Tools) - wikiHow
To find a step down transformer for 1440 watts, you will buy a new vacuum cleaner cheaper.
volts amps watts equation Google Search
Oct 01, 2017 | Vacuums
Power is not coming on
see this causes and fix it. God bless you
If the vacuum cleaner motor doesn't run the on - off switch might be turned off or defective. Test the switch with an Ohm meter or continuity checker.
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced.
Sep 27, 2012 | Wagner Spray Tech Wagner 915 1,500-Watt...
2200 watt dirt devil
If it has a belt it may be stretched out and need replaced
Dec 02, 2017 | Vacuums
My roomba going in circule, backward a few than stop. it is not going a normal vacuum forward
tear it down and clean the dirt and dust inside of it thoroughly. Also blow compressed air in the entire motor and circuit area at 5 PSI
Reassemble and it should work like new again
Mar 24, 2011 | iRobot Roomba 530 Robotic Vacuum
Hi. Miele 5310 motor appears to have burnt out. Red light with ! is on and vacuum cleaner won't switch on
have a look at the switch first they can get worn but if thats not it look at the motor brush's if you have power to the motor but no "get up and go" no broom broom like! buy a new hover as a motor will cost you both arm's and one leg!!! plus its still needs to be fitted
hope this helps you? mike.t
Oct 20, 2009 | Miele Vacuums
I want to know the suction power of henry is it the most powerful
Because of the traditional means of suction, air watts can only be justified in vacuums like Dyson that have 100% suction all the time. Therefore even the most expensive bagged upright (or bagless that doesn't have Dyson technology) will lose suction the moment a new bag is put in. Don't believe that air watts are true unless you have a Dyson.
Mar 24, 2009 | Numatic Henry Bagged Canister Vacuum
About kirby carpet extracters
The heritage 2 pulls 5.5 amps or 660 watts in hose mode and 4.5 amps or 540 watts in carpet mode.
Volts to Watts
The conversion of Volts to Watts is governed by the equation Watts = Amps x Volts
Mar 24, 2009 | Kirby Heritage II Vacuum
The vacuum won't turn on
it could possibly be a short in the power cord. try replacing the power cord. if that doesn't fix it, it would probably be cheaper to buy a new vacuum cleaner.
Oct 12, 2008 | Bissell 6594 PowerForce Bagless Upright...
Vacuums Logo
51 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
