Hi i cant seem to drain the water from my washing machine? tried looking for the filter had no luck need some assistance in either locating it or what else i can do
Washing machine HJA 8703
    Habit-Forming:
    New Friend:
  • 82 Answers
Drain pump either stuck up with something or doesn't work at all.
Posted on May 04, 2017
After washes it displays check detergent. some washes are also not spinning properly and cloths are still quite wet. Can you help I have a miele gala grande w 3000
Hi dear.
Basically you can check fluff filter otherwise you may need to have a technical assist. Fluff filter located on front LHS bottom corner of your machine.. Open plastic cover. Place small bowl under fluff filter area to collect about 2 Lt of water. Slowly turn fluff filter anticlockwise to let it drain remaining water in there.. Then remove it and check for blockage. ( Step by step You can get full instruction from your machine's user manual on cleaning and care section.) If that does not solve the issue you may call Miele to assist you or local repairer. I hope that helps.Thanks.
Jan 16, 2016 | Miele Washing Machines
Will not drain
HI, COULD BE BLOCKED FILTER/ PUMP, IF THE MACHINE STILL HAS WATER IN IT, I UNPLUG THE MACHINE, TILT IT BACKWARDS AGAINST A WALL, GET A STRONG ADULT TO ASSIST, THEN YOU CAN HAVE A LOOK IF THERE IS ANY OBSTRUCTION IN THE FILTER ( BOTTOM FRONT OF THE WASHER ) IF THERE IS REMOVE IT, REASSAMBLE, STAND THE WASHER UPRIGHT, PLUG IT IN AND TRY AGAIN. GOOD LUCK....
Dec 30, 2013 | Hotpoint Washing Machines
We have a LG washer, model wm2487hwm, seems like it is not spinning oiut the water like it used to, clothes seem to be wetter than previously, whats the problem?
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
Aug 08, 2011 | LG WM2487H Front Load Washer
Mt Bluesky Washing Machine (Part Number BLF1017ES) does not seem to pull in sufficient water, resulting in poorly rinsed clothes which smell stale when worn. I can't find a user manual in English, so have...
I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters, even smelly garments because the drain motor has been unable to drain all of the waste in the time allotted.
If you are unsure where the filter is, it is normally behind the front lower (kick) panel and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP ANY WATER!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Hope this is the problem and good luck!
John C
Feb 11, 2011 | Washing Machines
I am having an issue with my LG front loader washing machine model number WM1815cs. The water will not drain and the clothes will not spin out. Everything works fine until the rinse/spin cycle and it just...
Hi
Thanks for using FixYa. OE is a Drain Error which indicates that the water was not fully drained within 10 minutes. To start with check the drain pump filter for any clogs/foreign materials and try to clean the filter. Also if you have already checked the drain hose for any blockage then check the pump for any blockages, if still its not resolved then it seems to be the pump that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 28, 2010 | LG WM1815CS Front Load Washer
Hi there, i got a hot point washing machine who will not drain water,need help to diy thanks for any assistance
Remove the rear lower panel of washer, locate and remove large black hose fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Please rate my solution.
Thanks.
Nov 10, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hi, My zanussi washing machine model z221w does not seem to be draining properly - any ideas? Also I want to check the filter at the bottom rhs of the machine but I cant seem to open it can you help? A...
If you have located the filter at bottom right front of washer, firmly grasp filter handle, and turn anti-clockwise to remove and clean. if it does not come out, then something is jammed in filter, so just keep trying to pull it out.
Thanks.
Nov 06, 2009 | Washing Machines
Draining water from washing machine
Filter is normally down r/h side of machine it unscrews anti clockwise..Good luck
Oct 10, 2009 | Whirlpool AWM6100 Front Load Washer
Maytag washer sav2555aww
It could either be the filter (most likely), the drain pump (likely) or the drain hose/tube (least likely).
Normally, there would a filter somewhere at the bottom of your washing machine with the primary function of keeping loose clothing, torn fabric, lint, fluff and foreign objects away from the impeller/pump. Most current washing machine have self-cleaning filters and therefore regular cleaning is no longer a concern. However, some other washing machine need to have the filter manually removed and cleaned regularly or as even in your case. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your washing machine and may cause the problem as you have described; water doesn't leave the tub.
To check the filter and/or the drain pump, the bottom has to be exposed, the filter/pump located and cleaned. In some instances, the drain could be a valve operated by a solenoid.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 10, 2008 | Maytag Washing Machines
Washing Machines Logo
Top Washing Machines Experts
