Question about Garden
My oil leaks out under the bar oiler after i use it.What can i do to fix it?. This is my 2nd saw , the first one stopped running so i bought a new one . it is less than 1 year old.
  • Garden Master
  • 10,291 Answers
There are O-rings sealing the bar to the oiler passages. Replace the O-rings and keep the bar tight.
Posted on May 04, 2017
I have an MS660 and the bar oiler has not functioned on my last take of fuel. is there a way to trouble shoot the oiler problem without taking it into the shop. I hate to loose a weekend of cutting.
Start by removing the bar and chain and start the saw with a full tank of fresh Stihl bar oil.
If you are or have used a low grade oil or used oil you may have worn the oiler out.
Watch for oil to come out of the oil port.
If it does at a steady rate of about 10-21cc per min at 13,000 rpm or about 1/2 oz. per min then the bar is clogged with saw dust and needs to be cleaned.
If oil does not come out of the hole you will need to trace back the problem. the oiler is under the clutch. To remove the clutch remove the c clip that holds clutch drum ,washer and bearing remove those comonents and you are to the clutch. the clutch comes off reverse threads (right to loosen)
The problem is that the engine wants to turn, so remove the spark plug and put something soft in the sparkplug hole like 2 ft of starter rope. the clutch will come off and you will be able to see the oiler gears and hoses. worst case you will need a new oiler which is held on with a few t-27 screws.
Again I stress the point of good oil.
find parts at a local dealer like www.arcolawn.com
joe
Feb 19, 2011 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
My husqvarna automatic chain oiler doesn,t work...235 husqvarna any fixes?.
You may have gotten some saw dust particles inside the oil resevoir that got sucked into the delivery tube, thus clogging up the oiler...you can drain the oil out of resevoir and run some seafoam thru the oil resevoir to see if you can get it unclogged
Jan 23, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Jonsered cs 2250 fixed flow oiler can the oiling rate be increased i think its not getting enough as the chain is running almost dry
Remove the housing that covers that bar and sprocket. There are two plates on each side of the bar that set over the studs.They may be identical or slightly different depending on the saw but at least one of them will have a hole in it for the oiler. If you remove the bar and both plates you will see the oiler hole on the saw housing. This oiler injects oil through the plate and into a small hole in the bar where the chain picks it up and carries it around the saw. If this hole becomes plugged with sawdust it will keep your saw from oiling the bar proplerly. This hole should be cleaned out periodically. It's not a bad idea to remove the whole chain periodically and clean the chain guide all the way around the bar and get any sawdust buildup out so the oil can flow better.
Dec 03, 2009 | Garden
Flymo 2200 chain oil leak when machine is running
That chainsaw should leak oil off the bar. A small amount of oil flipping off the chain is how it is suppose to work. If it is a large amount of oil dripping from near the sprocket then you probably need to do some cleaning.
Dec 01, 2009 | Garden
Chainsaw leaks chain oil when not in use
You might try loosing the oil cap on the chain oiler filler cap to release any preasure that might have built up during use and is forcing oil out as it sits. It sounds like a simple fix but it might just work.
May 06, 2009 | Garden
Husqvarna 359 leaking chain oil
Remove the sprocket cover, bar, and chain. Find area where oil is discharged from case--is any part of the rubber seal damaged? Next, use compressed air to clean sawdust and dirt from oiler ports in rear of bar as well as the chain slot. Are you using motor oil instead of bar oil? Make sure there is nothing to prevent bar from making close contact with oiler port in case. Reassemble all parts and adjust chain tension.
Apr 10, 2009 | Garden
Makita DCS51018 Chain Saw Oiler
OK found a complete oil pump for this saw, part number is 181245250 and if you would like to download a copy of the breakdown go to Makitatools.com and in the bottom go to Makita Canada and you can find it there. I don't know why they don't have it in the US version but that is where I got it from Good Luck and let me know if I can be of any more help
Feb 22, 2009 | Makita DCS51018 18" 45cc Chain Saw 2 Cycle
Chain oiler
Depends on the vintage, turn the saw upside down and you can see a screw to turn, 3 settings, right under the clutch and shaft. use a screw driver if it is adjustable. I like to keep mine set on high, oil is cheaper that new chains and bars. Use a bar oil, not old used motor oil.
Nov 01, 2008 | Husqvarna Chain Saw 20" Bar
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
