My account does not want to connect - Computers & Internet
I cannot access my emails in my outlook account on my Toshiba CB50 Laptop it keeps saying theres a problem with my account why is this?
Solution: Make sure that your computer is connected to the Internet or your network. Use a Web browser to see whether you can access Internet sites. If you are on a local network, see whether you can access intranet sites. For information about checking the status of your network connections, see Mac OS Help. Solution: Verify that Outlook is online. On the Outlook menu, make sure that Work Offline is not checked. Cause: Some POP and IMAP e-mail accounts use an outgoing mail (SMTP) server that requires authentication. Solution: Turn on SMTP authentication for the POP or IMAP account. Some e-mail services, including MobileMe mail accounts, require authentication for their SMTP server. If you verify that all your account settings are correct, but you still can't send messages, try turning on SMTP authentication. On the Tools menu, click Accounts. In the left pane of the Accounts dialog box, select the account. Under Outgoing server, click More Options. On the Authentication pop-up menu, select the authentication type, and then enter your credentials as necessary. Cause: Your ISP or network has a firewall that blocks connections to your e-mail service's outgoing mail (SMTP) server. Solution: See if your ISP or network administrator can provide an alternative SMTP server to use for your POP or IMAP account. If you have the address of an alternative SMTP server, enter it in your account settings. On the Tools menu, click Accounts. In the left pane of the Accounts dialog box, select the account. In the Outgoing server box, type the server name or address. NOTE: If you use a laptop computer in multiple locations, such as at home and at work, the SMTP server that you use in one location may not work in other locations. Each Internet connection that you use may have a firewall with its own restrictions. Cause: Your credentials or account settings are incorrect. Solution: Verify that your account user name, password, and other settings are correct in Account preferences. On the Tools menu, click Accounts. In the left pane of the Accounts dialog box, select the account. Make sure that you have entered the correct e-mail address, user name, and password. If your account still does not work properly, check with your e-mail service provider for details about how to configure your account in a mail application. Your account may require that you use special settings such as Secure Sockets Layer (SSL) to connect, or that you override the default port. Cause: Your network requires a proxy server to connect with the mail server. Solution: Specify a mail proxy server in your computer's System Preferences. If you use a network to connect to the Internet, you might have to specify a mail proxy server. Ask your network administrator for the correct settings for your mail proxy server. For instructions about how to enter these settings, see Mac OS Help. Cause: Your e-mail server is unavailable. Solution: Make sure that the mail server is online. If you successfully connected to the account before, the mail server might be offline. Contact your e-mail provider or network administrator to see whether the mail server is available.
Mar 25, 2016 | Toshiba Computers & Internet
I want to add this account to this computer without connecting accounts
You won't be connecting the accounts, you will only be adding a different account to the same gmail browser. When you get on gmail from the same computer all of the accounts that have been accessed from that same computer will all link to the same page. However, they will still all be separate accounts. When logging in you will still have to provide a password for which ever account you're logging into.
Click "sign in with a different account" and you will be prompted to put in the different gmail, and password.
Mar 11, 2016 | gmail.com
Error 815
First you have to make sure you should have working internet connection. Error 815 mostly related to ISP side so suggest you to contact ISP first.
You can also try below steps if ISP says everything is fine.
If the connection can be established by using other device/system, please create a new administrator account on the Windows Vista machine to troubleshoot the issue:
1.Click Start > type user account and click the User Accounts control panel.
2.In the User Account control panel, click Manager another account.
3.Click Create a new account, type an account name > select Administrator and then click Create Account.
4.Logoff and logon with the new account and try to establish the connection to check if the issue persists.
Mar 15, 2013 | Microsoft Windows Vista Home Premium...
What is the gprs/mms setting for sony ericsson X8? my network provider is globe philippines. i went to their customer service but even the representatives there can't help me with my problem.
Just follow this Guidelines
GPRS SETTINGS
1. Go to Menu>Choose Settings>Connectivity
2. Go to Data Accounts
3. Create New Account. GPRS/ PS Data
Account Name: MyGlobe GPRS
APN: www.globe.com.ph
4. Save Account
5. Go to Browser, Slect Options and click Internet Settings
6. Add New Profile
Connect Using: MyGlobe GPRS
IP ADDRESS: 203.177.042.214
ADVANCED
Chg. Homepage: MyGlobe GPRS
Address: http://www.globe.com.ph/globe.asp
Save Profile
MyGlobe Internet Settings
Account Name: MyGlobe INTERNET
APN: internet.globe.com.ph
4. Save Account
MyGlobe MMS Settings
Account Name: MyGlobe MMS
APN: mms.globe.com.ph
4. Save Account
5. Go to Messages>Picture Messages>Option>Internet Profile
6. Create New Profile
Connect Using: MyGlobe MMS
7. Save Profile
8. Select the profile MyGlobe MMS in Internet Profile
9. Save Settings
10. Go to Messages>Picture Messages >Options
11. Edit Message Server
http://192.40.100.22:100.21/mmsc
12. From Message Settings, make your Internet Profile: MyGlobe MMS
Hope it helps...
Jul 15, 2011 | Sony Ericsson XPERIA X8 Cell Phone
Manual configuration of my "MY
Manual Configuration for Globe Subscriber:
GPRS Settings
GPRS Data Account 3 Account Name: myGlobe MMS Access Point Name (APN): mms.globe.com.ph GPRS Data Account 4 Account Name: myGlobe GPRS Access Point Name (APN): www.globe.com.ph WAP Network Settings
Rename Profile: myGlobe WAP Homepage: http://www.globe.com.ph/globe.asp Data Account: myGlobe GPRS Connection Type: HTTP Proxy Address: 203.177.042.214 Proxy Port: 8080
MMS Network Settings
Rename Profile: myGlobe MMS Homepage: http://192.40.100.22:10021/mmsc Data Account: myGlobe MMS Connection Type: HTTP Proxy Address: 203.177.042.214 Proxy Port: 8080
Manual Configuration For SMART subscribers:
GPRS Settings
GPRS Data Account 1 Account Name: Access Point Name(APN): GPRS Data Account 2 Account Name: SMART GPRS Access Point Name(APN): Internet Exit and save settings WAP Network Settings
Rename Profile: Smart WAP Homepage: http://wap.smart.com.ph Data Account: Smart GPRS Connection Type: HTTP Proxy AddressL: 010.102.061.046 Proxy Port: 8080
Rename Profile: Smart MMS Homepage: http://10.102.61.238:8002 Data Account: Smart GPRS Connection Type: HTTP Proxy Address: 010.102.061.046
Jun 27, 2011 | Cell Phones
How to open Globe gprs to Nokia 6303
  • For a complete listing of compatible MMS & GPRS phone handsets — send Nokia, Ericsson or Samsung (your handset model) to 2365.
  • To get your phone’s settings, text GO (handset model) to 2951. Example, GO N3650. (For a list of compatible handsets, refer to #1) Note: For Nokia 6220, 6600, and 6820, text GO < handset model >,1234 and send to 2951. Make sure to type in the two commas before the 1234 PIN. Regular text messaging charges will apply.
  • Enter 1234 when asked for PIN to save settings.
  • Send an MMS message for only Php 5.00 to activate the service
GPRS SETTINGS
1. Go to Menu > Choose Settings > Connectivity
4. Save Account
5. Go to Internet Settings
7. Save Profile
8. Select the profile MyGlobe WAP in Internet Profile
9. Click Right Soft Key to Choose More and Select Settings
Internet Mode: HTTP
Use Proxy: Yes
Port Number: 8080
10. Save Settings and repeat Step 9 but this time choose Advance Settings
11. Change Homepage
Title: MyGlobe
12. Save Changes
3. Create New Account. GPRS / PS Data
4. Save Account
4. Save Account
7. Save Profile
Internet Mode: HTTP
Use Proxy: Yes
Port Number: 8080
10. Save Settings
11. Click Right Soft Key to Choose More and Select Advance Settings
12. Change Homepage. Enter the following parameters and save the settings
Address: http://192.40.100.22:10021/mmsc
13. Go to Messaging>Settings> Picture Message
14. Edit Message Server : http://192.40.100.22:100.21/mmsc
15. From Message Settings, make your Internet Profile: MyGlobe MMS
MyGlobe Stream Settings
3. Create New Account. GPRS/PS Data
Account Name: MyGlobe Stream
APN: real.globe.com.ph
4. Save Account
5. Go to Streaming Settings
6. Make MyGlobe Stream your default APN.
Connect Using: MyGlobe Stream
Jun 26, 2010 | Nokia 6303 Cell Phone
HOW TO CONNECT WLAN IN MY W960I MOBILE - PLS ANSMER ME STEP BY STEP
Go to:
Tools
Control Panel
Connections
WLAN
..this shall help you search for available wireless networks with their respective SSIDs (Service Set IDentifiers).
There are 2 kinds of wireless networks: Hotspots and configured networks. When connecting to the Internet using a Hotspot, no further configuration is needed. When you connect using a configured network, a WLAN account is required in your phone. For configured networks, you may or may not use the New Account Wizard in your phone.
Setting up Internet Account using New Account Wizard:
1. Go to:
Tools
Control Panel
Internet Accounts
2. Click "More" on the lower right part of your screen.
3. Select "New Account", then "WLAN".
4. Enter the details required in accordance with your preferred wireless network.
Setting up Internet Account without using the Wizard:
1. Connect to the WLAN first.
2. Prompt for encryption keys of the network you are attempting to connect to (passwords).
..Hope this helps. =)
Apr 23, 2010 | Sony Ericsson W960i Cellular Phone
I want to set up wlan in my sony ericsoon w960i please step by step
Go to:
Tools
Control Panel
Connections
WLAN
1. Go to:
Tools
Control Panel
Internet Accounts
Jul 10, 2009 | Sony Ericsson W960i Cellular Phone
Airtel gprs settings for chinamade mobile
Here is the Mobile Office, Airtel Live and Airtel MMS settings for ALL CHINA Mobiles ==>
1) Mobile Office
first click SERVICES icon in main menu==>DATA ACCOUNT==>GPRS==>EDIT any
existing account==>
Account Name--> MO
APN-->airtelgprs.com
Auth. Type-->Normal
save all the settings.
Come back to SERVICES==>WAP==>SETTINGS==>EDIT PROFILE==>EDIT any existing account==>
Rename Profile==> Mobile Office
Homepage==>Google
data account==> MO (which we created previously)
Connection Type==>
Here u find three option
a) Connection-oriented
b) Connectionless
c) HTTP
choose a) Connection-oriented==>
IP Address==>202.056.231.117
Security==> off
Again save all the settings and click BACK button and choose "Activate Profile"
Come back to SERVICES==>WAP==>Homepage
and you r
ready to use Mobile Office...
2) Airtel Live
first click SERVICES icon in main menu==>DATA ACCOUNT==>GPRS==>EDIT any existing account==>
Account Name--> LIVE
APN-->airtelfun.com
Auth. Type-->Normal
Rename Profile==> Airtel Live
Homepage==>http://live.airtelworld.com
data account==> LIVE (which we created previously)
Connection Type==>
b) Connectionless
c) HTTP
choose c) HTTP==>
Proxy Address==>100.001.200.099
Proxy Port==> 8080
and you r ready to use Airtel Live...
3) Airtel MMS
Account Name--> MMS
APN-->airtelmms.com
Auth. Type-->Normal
Rename Profile==> Airtel MMS
Homepage==>http://100.1.201.171:10021/mmsc
data account==> MMS (which we created previously)
Connection Type==>
b) Connectionless
c) HTTP
choose c) HTTP==>
Proxy Address==>100.1.201.172
Proxy Port==>8799
and you r ready to use Airtel MMS...
Enjoy....
Irshad
Jul 08, 2008 | Cell Phones
Cannot connect to another user account on the same computer
Your internet setting should same at your primary account..to find out ; Go to internet option and connection tab and the LAN setting. and then do the same in the second account.
Dec 27, 2007 | Westell Wirespeed VersaLink...
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
