G
Glenys Jones Posted on May 04, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Identify and calculate the area and perimeter for triangle, a=8.1mm, b= 4.5mm, c=9.27mm
Bill Boyd
Level 3:
Top Expert:
  • The Master 53,816 Answers
  • Posted on May 04, 2017
Bill Boyd
The Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11948318
Points
172802
Simple maths
to get the perimeter simply add a + b + c
to get area the formula , 1/2 base by perpendicular height
2answers
How many feet in a half acre of land?
Since acre is a measure of area and feet is a measure of distance, you need to calculate the perimeter of a lot with an area of half an acre. Here are the formulas:
1. If the lot is a square (all 4 sides of equal length), multiply the length of one side by 4, to get the # of feet required to walk a half acre piece of land.
2. If the lot is rectangle: (heightx2)+(widthx2).
3. If the lot is a triangle, add up all three sides.
Regular pentagon QRSTU has a side length of 12 cm and an area of about 248 square cm. Regular pentagon VWXYZ has a perimeter of 140 cm. Find the area of VWXYZ. Round to the nearest tenth.
Find the scaling ratio
Perimeter of first pentagon is 12*5=60 cm
Scale factor (2nd/first)=140/60 =7/3
Ratio of areas varies as the square of the scale factor for the lengths
Area of second / area of first =(7/3)^2 =49/9
Area of second pentagon =248 *(49/9) cm^2
Finish the calculation.
Volume of triangular pyramid
Here is to get you started. To increase the size of the image do a CTRL Plus (+) in your browser.
You need to calculate the slant height of the pyramid for the formula of the lateral area. You should find a value of (1/2)*SQRT(203) or about 7.1239 cm
You need to calculate the altitude (height) of the pyramid from the apex (summit) to the center of the base triangle (center of inscribed circle, barycenter, orthocenter). The hypotenuse of such triangle is the slant height. One leg is the altitude (to be found), the measure of the second leg is (1/3) the altitude of the equilateral triangle that forms the base. You should find (1/3) m MH= (1/3)* (11/2)*SQRT(3)
1. Calculate the area of the base (use a formula for the equilateral triangle or the general formula for a triangle: you have its height MH ).
2. Lateral area = 3 times the area of triangle Triangle ECD (in yellow above).
3. Total area = area of base + lateral area.
4. Volume= (1/3)(Area of base)* (height of pyramid)
If you can see the details on the screen capture below, fine, Press CTRL + in your browser to increase the size.
Khan academy
Since you have the coordinates of the three vertices, the most straightforward method is to calculate the length of the sides using the distance formula
d(P_1,P_2)=SQRT((X_1-X_2)^2+(Y_1-Y_2)^2)
where SQRT is the square root function, X_1, Y_1) are the coordinates of point P_1, etc.
With the three lengths available, use Heron's (sometimes called Hero's) to find the area.
Here is Heron's formula.
Let's call the lengths a, b, and c
Let p be the semi-perimeter p= (a+b+c)/2
Then
Area= SQRT [ p(p-a)(p-b)(p-c) ]
Make sure that there is a matching ) parenthesis to the one in the SQRT.
Alternatively,
You can choose the base as the side opposite the vertex (0,0)
Calculate the equation of the line that supports the base.
Calculate the equation of the line issuing from (0,0) and perpendicular t the base.
Calculate the coordinates of the intersection point , call it H, of the base and its perpendicular line (coming from (0,0)).
Calculate the distance OH, that is the height relative to the chosen base.
Use the formula Area= base*height/2
Now it is up to you to choose one of the two methods and calculate the area of that triangle. The second method involves more calculations than the first, and more possibilities of errors. Good Luck
What is the area of the triangle with vertices (0,0),(-3,5),(2,-7)
Then
Alternatively,
2answers
Ratio examples
Assuming the floor is rectangular, the perimeter is 918 and the area is 50318. The ratio of these two numbers is 459:25159.
Area of traingle with tree side
All triangles have three sides.
There are two main formulas that do not call on trigonometric ratios.
The classic one:
  • 1. You need the length of a base and it corresponding height (the length of the segment perpendicular to that base and passing through the vertex (summit) opposite to that base. Area=(1/2) * (measure of the base)*(measure of the height). The base and height must be expressed in the same unit.
Heron's Formula if you have the length of the three sides. Let those measures be a, b, and c.
  • Calculate the semi-perimeter p with p=(1/2)(a+b+c)
  • Area=Square root of (p*(p-a)*(p-b)*(p-c))
  • a, b, and c must be expressed in the same unit.
1helpful
2answers
I have a lot tha is 152.95' X 119.88' X 130.00' X 50.00'. What part of an acre is this.
  1. This lot does not have the form or a regular quadrilateral (rectangle, square, parallelogram, etc.)
  2. So you cannot calculate its area, you have to know exactly the shape it has.
  3. With polygons, one usually cuts them into triangles.
  4. You have to cut it into two triangles,
  5. measure the base and the height of each triangle,
  6. use the area formula for the triangle ( area = heightX base/2)
  7. After you calculate the areas of both triangles, you add them to get the area of the the whole lot in ft^2.
  8. Using the conversion formula between acres and ft^2 which is 1 acre=43560 ft^2, you divide the area of the lot in square feet by the number 43560 ft^2 and express the result as a percentage or a fraction .
Hope it helps.
Thanks for using FixYa.
Top The Office Equipment & Supplies Experts
vince
littlewheel
Jean Thiebaux
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
