Question about Ovens
My cooker is refurbished gl3518 and i carnt get the oven and grill to work
BADBOYJAY
  • 264 Answers
SOURCE: oven does not work
its just your heater element you will need to wright down your model number and go on ebay or go to your local appliance shop they might order you 1 there about £35 pound
Posted on Jan 07, 2008
SOURCE: leisure rangemaster 55 gas cooker
It sounds exactly the same as I am experiencing on my oven of the same model. My theory is that the full flame gas is controlled by a thermostat, and that this has broken hence why the oven only stays on preheat. This will be a matter of a replacement part. Most likely the thermostat is a bi-metal strip that, because it has heated and cooled so many times in it's life it has simply finally given up. Try searching online for the correct part and get a corgi registered fitter or another suitably qualified fitter to come and replace it.
Posted on Apr 07, 2008
FixinFax
  • 3085 Answers
SOURCE: oven door open or shut when using grill?
Leave the door open in the broiler position, about 4 inches.
Posted on Jan 06, 2010
SOURCE: Hotpoint BU62 double oven, no grill functioning
keep turning the oven/grill selector past the temperature settings, it feels like it won't go any further but it does!
Posted on Feb 07, 2010
blackmar
  • 235 Answers
SOURCE: Creda Concept Solarglo Cooker. Grill
Most common problem is that the grill element is probably faulty/blown. Also check the wiring at the grill element terminals as wiring sometimes burns off. The grill controllers don't normally get faulty as they generally last a lot longer than the elements.
Posted on Feb 12, 2011
Testimonial: "Many thanks for the prompt reply. I'll follow up your recommendation!"
The grill and ovens on my Jackson Topline cooker have just stopped working, the rings work but none of the lights above the switches are on when they are working, any Ideas please? thanks.
I am not familiar with your model of cooker but I assume it is a gas cooker.
Gas cookers have safety devices in the oven and grill the hob rings do not need. I speculate even the domestic oven hasn't escaped the interference from the electronics industry and I expect the aforementioned safety devices depend on (low voltage) electronics and electronics depend on electricity - that the lights aren't working would suggest there is no (low voltage) electricity.
Even in the case of an electric oven the thermostat could be electronic and need (low voltage) electricity to work.
I suspect the internal power supply has failed.
Jun 17, 2016 | Ovens Ovens
Manual for tricity contessa cooker, double oven and grill with slow cooker button. Just brought this reconditioned cooker, but it hasnt got a manual and I need one. I can't get the oven to turn on, it...
i have a vey old tricity contesssa cooker(which i love!)
The rings are heating but the oven and grill have stopped working,any suggestions on how to fix please??
Oct 08, 2011 | Ovens
The grill on my Hotpoint EW 41 Electric freestanding cooker has stopped working after my wife put aluminum foil into the grill pan which then touched the grill element causing it to 'blow' and so...
The grill element should not 'blow' by just touching it - it should be earthed. The elements do gradually disintegrate over time & the inside wire element either fractures or touches the element casing causing the mains to trip. Sometimes this makes it trip just once & then stops working. Replace the element - not usually any fuse in circuit with this. Often held in by 2 screws adjacent to the element at back of oven and conections via Fast-ons- Rick
Jun 12, 2011 | Hotpoint Ovens
MY STOVES COOKER'S OVEN AND GRILL HAS STOPPED WORKING?THE HOB IS WORKING FINE.
The hob is normally totally independent of the oven. What is actually working or not working on the oven? i.e. does the grill still work, is the clock OK and can you set it, or is everything totally dead?
Oct 16, 2010 | Stoves 720EF Electric Double Oven
My grill element belling xou177 duel grill does not work, i carnt afford a new one was told be an oven specailist he would disconect wires for £30, i carnt afford this either, i need to know whic...
If you can locate the wires to the element, simply pull them off, and tape the ends of the wires to make them safe, make sure you mark them so you know where they go back.It will probably invlve you having to remove the rear panel to gain access.
Please rate my solution.
Thanks.
Nov 10, 2009 | Ovens
Hotpoint cooker, grill doesn't work but top oven does
If the elements 'look' okay, they probably are. The 'infinite control switch' is probably the problem. With out the use of a meter, it's guess work. Unless you can see a connection problem.
Sep 03, 2009 | Ovens
Aug 26, 2009 | Hotpoint UY46 Style Line Stainless Steel...
How can i mend the grill and oven on my electric cooker?
If the rings work o/k then could be timer if it has one make sure it is set to manual and not auto.
Another thing it could be is a faulty selector switch, which selects the different functions.
Hope this helps.
Plz rate my solution.
Thanks.
Dec 31, 2008 | Ovens
Electric oven and hood not working but grill is?
Make sure the timer is set to manual and not on auto.
Dec 10, 2008 | Zanussi ZBQ665 Electric Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
