ELECTOLUX T4290 E15 ACTIVATED BEFORE DRUM MOVE.(NO OVER LOAD & FILTER CLEAR)
2 Suggested Answers
  • 1294 Answers
SOURCE: E15 water is draining but clothes still sodden,
The problem is your pump or filter is blocked.
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me plz……………………….
Posted on Apr 06, 2009
E15 showing on Bosch dishwasher. How to clear?
The overflow switch has been activated.
It means that its a internal leakage.
Unscrew the side panels or frontpanel under the door and dry out the water with a towel and test the machine.
Check for leakage.
Feb 07, 2016 | Bosch Dishwashers
Error code e15. doesnt seem to be spinning
Hello. Is your washer draining properly? If there is water left in the drum you will get an error. Fixing this involves removing the front inspection cover and cleaning the filter.
May 26, 2014 | General Electric Profile WPDH8800JMG 4.2...
Zwf 1000m the drum will not move at all. i have checked the filter and it is is clear. the machine makes a small noise when the drum should start to move but nothing happens?
if you cant turn the drum by hand on the inside ,....there could be something trapped between the inner and outer drum........or worse.......the drum bearing mite be shot......ive fixed a few with womens knickers and bras jamming the drum as they ate flimsy enough the get between the inner drum and the door seal............good luck
Nov 02, 2013 | Washing Machines
Hi, my Hotpoint Aquarius wma56 washes, but drum wont spin in rinse and wont spin...any advice?
you need to check/clear filter, its located within sump hose @ bottom of drum quite trickey clip to remove slide it to the side to assist then withdraw nylon filter and clear.
Jun 10, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
Drain error still after making sure the washer was level, making sure the drain filter was clean, the drain was clear and replacing the pump motor assembly
LE error? Don't buy a new sensor, don't call a repairman and don't scrap it. The fix is EASY!
Turn the drum 4-5 times by hand to resettle the load, move spin speed to highest, Quick Wash, Speed Wash. It shoudl work just fine. I've had to do this a few times over the last 5 years. Why everyone wants you to BUY parts is beyond me....maybe they need to make some $$ ?
Apr 21, 2011 | LG WM-2277HW Front Load Washer
My hotpoint ultima extra washing machine says e15 check outgoing pipes i have cleaned the pipe out and is washing to a certain point then e15 shows and starts to beep continuously
hello,
what e15 indicate means an error code that there have been an over flow of water from the drum over to the panel or the wire that suppl power to the screen .
what you will have to do to fix up this problem from the screen is to unscrew the screws with screw driver care then trace the wire ,that is the power supply down to the panel and also to the screen clean up all forms of liquid around the wires and also the panel carefully . then couple it back with care to is position with this the problem is solve.
thank you.
Aug 07, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hoptopint wd72 - E15 and wont take water in
Hi, - fixed this myself. Problem was a blocked pipe from front of drum to pressure switch. - The machine was fooled in to thinking it had water in when it hadnt! - hence the error 15. that was also why it would not fill. - im guessing the heater blew because it was on with no water to keep it cool!
Jan 09, 2010 | Hotpoint Ultima WD72 Front Load...
E15 code on display of Hotpoint ultima extra WD72.
E15 means that it is not draining fast enough. As well as checking the outlet pipes, check the filter leading to the pump. Disconnect the power and pipe. If possible take outside because there will be a residual amount of water. Remove the back panel, then disconnect the locking rings holding the tubes on. Your main target should be the big downflow rubber tube from the drum, in here is a plastic filter. In mine I found a child's sock... plus buttons...plus slime. Problem solved.
Dec 20, 2009 | Hotpoint Washing Machines
Mar 21, 2009 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
